Create data source using Azure DevOps ODBC Driver
Watch this quick walkthrough to see how to configure your Azure DevOps ODBC data source, or scroll down for the step-by-step written guide.
When the Configuration window appears give your data source a name if you haven't done that already, then select "Azure DevOps" from the list of Popular Connectors. If "Azure DevOps" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
AzureDevopsDSNAzure DevOps
- Configure the authentication in Azure DevOps.
User Credentials
Azure DevOps authentication
Delegated access using OAuth authorization code flow. Users sign in with their Azure AD account. [API reference]
WARNING: To automate your company's processes, make sure you use a system/generic account (e.g.automation@my-company.com). When you use a personal account which is tied to a specific employee profile and that employee leaves the company, the token may become invalid and any automated processes using that token will start to fail.- Navigate to the Azure Portal and log in using your credentials.
- Access Microsoft Entra ID.
Register a new application by going to
App registrations
and clicking on New registration button:
Supported account type
- Use
- Use
Redirect URI:
- Set the type to
- Set the type to
Then copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs to use later in the configuration:
In the Scope field use the default value or select individual scopes, e.g.:
vso.project -
vso.work_full
- If tenant policy blocks user consent, an administrator must approve the requested delegated permissions.
- Optional step. Choose Default Drive Id from the drop down menu.
- Click Test Connection to confirm the connection is working. After that, choose Default Project Name in connection settings. Some endpoints (for example, work items) often work more reliably when a default project is selected; otherwise, you must supply the Project value each time.
AzureDevopsDSNAzure DevOpsUser Credentials [OAuth]https://dev.azure.comRequired Parameters Authorization URL Fill-in the parameter... Token URL Fill-in the parameter... Application (client) ID Fill-in the parameter... Organization name or Id (e.g. mycompany) Fill-in the parameter... Return URL Fill-in the parameter... Scopes (Must match with App Registration) Fill-in the parameter... API Version Fill-in the parameter... Optional Parameters Client Secret Refresh Token File Path Default Project Name (Choose after Generating Token) RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Azure DevOps Connector authentication reference.Azure App Credentials
Use Azure AD service principal credentials (client id + secret) with the client credentials flow. Recommended for automated server-to-server access instead of PAT or delegated OAuth. [API reference]
Step 1: Register the App in Microsoft Entra ID (AAD)
- Go to the Azure Portal > Microsoft Entra ID > App registrations and click New registration:
- Name it (e.g., ZS-AzureDevOps-AppCred).
- Set Supported account types to "Accounts in this organizational directory only" (Single Tenant):
- Leave Redirect URI blank (it's not used for Client Credentials).
- Click Register.
Step 2: Create a Client Secret
- In your new app, go to Certificates & secrets.
- Click New client secret, give it a name, and set an expiration.
- Copy the Secret Value immediately. You will never see it again once you leave the page:
Step 3: Set Permissions and Admin Consent
- Go to API permissions > Add a permission.
- Select Azure DevOps and click Delegated permissions.
- Check the necessary scopes (e.g.,
vso.project,vso.work_full). - Crucial: Click Grant admin consent for [Your Tenant]. Without this, the app cannot authenticate in the background.
Step 4: Map the App to Azure DevOps Organization
- Copy your Application (client) ID from the App Overview page.
- Open Organization settings > Users (you must add the Entra app here as a user). Use any of these ways to reach that page:
- Direct URL: after you sign in, open
https://dev.azure.com/YOUR_ORG_NAME/_settings/users, replacingYOUR_ORG_NAMEwith your organization name (the same value you enter in the connector Organization field). Example:https://dev.azure.com/contoso/_settings/users. - From the DevOps home page: go to https://dev.azure.com, select your organization, then in the lower-left corner choose Organization settings (gear). In the left pane under General, open Users.
- Click Add users, paste the Application (client) ID in the search box, and select the App.
- Assign an Access level (usually Basic) and add it to the relevant Projects.
Step 5: Connection Settings
In your SSIS package or ODBC data source, use the following in the App Credentials configuration:
- In the Token URL field, paste the OAuth token endpoint (v2) URL from the Azure Portal 'Endpoints' tab.
- In the Client ID field, paste the Application (client) ID.
- In the Client Secret field, paste the Secret Value copied in Step 2.
- In the Scope field, use:
https://app.vssps.visualstudio.com/.default
Step 6: Finalize Connection
- Press Generate Token button to fetch the token using the Client Secret.
- Click Test Connection to confirm the setup. After that, choose Default Project Name in connection settings. Some endpoints (for example, work items) often work more reliably when a default project is selected; otherwise, you must supply the Project value each time.
- Done! You are ready to use the API Connector!
Azure App Credentials [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
AzureDevopsDSNAzure DevOpsAzure App Credentials [OAuth]https://dev.azure.comRequired Parameters Token URL Fill-in the parameter... Application (client) ID Fill-in the parameter... Client Secret Fill-in the parameter... Scopes (Use .default for App Credentials) Fill-in the parameter... Organization name or Id Fill-in the parameter... API Version Fill-in the parameter... Optional Parameters Default Project Name RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Azure DevOps Connector authentication reference.Azure App Credentials with Certificate (Sign JWT with Private Key)
Same as Application Credentials but uses a client certificate instead of a secret. [API reference]
- Name it (e.g., ZS-AzureDevOps-CertAuth).
- Leave Redirect URI blank (it's not used for Client Credentials flows).
- Click Register.
Step 2: Upload Client Certificate
- Click the Certificates tab, then click Upload certificate.
- Upload your public key certificate (.cer, .pem, or .crt). Keep the private key secure on your system.
- Copy the Thumbprint for your configuration:
- Select the required scopes (e.g.,
vso.project,vso.work_full). - Crucial: Click Grant admin consent for [Your Tenant]. Without this, the background service cannot acquire a token.
- Click Add users and paste the Application (client) ID in the search box to find the App.
In your SSIS package or ODBC data source, use the following in the Client Certificate configuration:
- Configure your Certificate Path or Thumbprint in the Client Certificate tab of the connector.
- In the Scope field, make sure to use:
- Press Generate Token. The connector will sign the request using your certificate to fetch a token.
- Done! Your certificate-based connection is ready!
Azure App Credentials with Certificate (Sign JWT with Private Key) [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
AzureDevopsDSNAzure DevOpsAzure App Credentials with Certificate (Sign JWT with Private Key) [OAuth]https://dev.azure.comRequired Parameters Token URL Fill-in the parameter... Application (client) ID Fill-in the parameter... Certificate: *** Configure [Client Certificate] Tab *** Fill-in the parameter... Scopes (Must match with App Registration) Fill-in the parameter... Organization name or Id Fill-in the parameter... API Version Fill-in the parameter... Optional Parameters Default Project Name RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Azure DevOps Connector authentication reference.(Cloud) OAuth App - User Credentials (DEPRECATED)
**DEPRECATED:** this OAuth-based user credential flow is legacy; for new integrations prefer the Azure App Credentials options below. Connecting to your Azure DevOps data requires you to authenticate your REST API access. Follow the instructions below:- Go to https://app.vsaex.visualstudio.com/app/register to register your app.
Fill in your application and company's information as required, and then select the scopes that your application needs.
This should typically be Project and team (read and write) and Work items (read and write).
Your selected scopes when registering your app must match the scopes you enter here on the connector screen. If they don't match, the connector will not be able to work with your Azure DevOps account!If you need further information about the scopes used in Azure DevOps, or need to see what to enter into the connector screen to match up with your selected scopes, visit https://learn.microsoft.com/en-us/azure/devops/integrate/get-started/authentication/oauth?view=azure-devops.
NOTE: For Authorization callback URL use your company's OAuth Redirect URL (if IT administrator provides you one) or you can use
https://zappysys.com/oauth(it's safe). - Select Create Application and then the Application Settings page will be displayed.
Record the App ID for us to use later:
And do the same with Client Secret:
- Then go to https://aex.dev.azure.com and select relevant organization on the left.
Then copy Organization's host name part (e.g.
acmeinc, if full host name isacmeinc.visualstudio.com), save it to a file, then open that organization by clicking its name in the list (this takes you into Azure DevOps for that org):
- Back at the connector screen, enter the App ID into the Client Id (App ID) field that was recorded in the previous step.
- Enter the Client Secret that was recorded in the previous step into the Client Secret field. In order to edit the text in this field, select the ellipses (...) button that appears when the textbox is clicked, and edit the Client Secret with the dialog box that appears.
- Enter the organization that was recorded in step 5 into the Organization name or Id for url field.
- Click Generate Token. If proper authentication occurs, you will see a notice saying so. You can click Yes to save a backup file of your generated tokens.
- Select the project you want to connect to by default from the Default Project (Choose after Generating Token) field.
- Select the Security tab.
Enter
https://auditservice.dev.azure.com,https://almsearch.dev.azure.cominto the Additional Trusted Domains field. - Select the Test Connection button at the bottom of the window to verify proper connectivity with your Azure DevOps account. After that, choose Default Project Name in connection settings. Some endpoints (for example, work items) often work more reliably when a default project is selected; otherwise, you must supply the Project value each time.
- If the connection test succeeds, select OK.
To edit previously created app you can visit
https://app.vsaex.visualstudio.com/meand see Applications and services section. Click on your desired app name.
(Cloud) OAuth App - User Credentials (DEPRECATED) [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
AzureDevopsDSNAzure DevOps(Cloud) OAuth App - User Credentials (DEPRECATED) [OAuth]https://dev.azure.comRequired Parameters Client Id (App ID) Fill-in the parameter... Client Secret Fill-in the parameter... Organization name or Id (e.g. mycompany) Fill-in the parameter... Return URL Fill-in the parameter... Scopes (Use .default for App Credentials) Fill-in the parameter... API Version Fill-in the parameter... Optional Parameters Default Project Name (Choose after Generating Token) RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Azure DevOps Connector authentication reference.(Cloud) Personal Access Token (PAT) (DEPRECATED)
**DEPRECATED:** Personal Access Tokens are still supported but the new Azure App Credentials auth is recommended for security and automation. To connect to Azure DevOps using a Personal Access Token (PAT), you must first create a valid PAT:- Start by going to https://aex.dev.azure.com and selecting relevant organization on the left.
Next, click User settings icon and then click Personal access tokens:
Then click New Token button to create a new personal access token:
Continue by...
- naming your token
- selecting the right Organization
- setting token's Expiration date (it's recommended to use
Custom definedoption and make it expire after one year or later) - and setting the Scopes:
NOTE: You may be restricted from creating full-scoped PATs. If so, your Azure DevOps administrator in Azure AD has enabled a policy which limits you to a specific custom defined set of scopes.
Now click Copy button and save the newly created token into a file for quick access later:
- Go back to the connector screen, input the token you saved in a previous step into the Personal Access Token (PAT) field.
- Then enter the Organization host name part that you noted recorded in previous step into Organization name or Id for url field.
- Enter the name or Id of the project you want to connect to by default in the Default Project (Choose after above fields) field.
- Enter
https://auditservice.dev.azure.com,https://almsearch.dev.azure.com,https://analytics.dev.azure.cominto the Additional Trusted Domains field. - Select the Test Connection button at the bottom of the window to verify proper connectivity with your Azure DevOps account. After that, choose Default Project Name in connection settings. Some endpoints (for example, work items) often work more reliably when a default project is selected; otherwise, you must supply the Project value each time.
- Done!
(Cloud) Personal Access Token (PAT) (DEPRECATED) [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
AzureDevopsDSNAzure DevOps(Cloud) Personal Access Token (PAT) (DEPRECATED) [Http]https://dev.azure.comRequired Parameters Personal Access Token (PAT) Fill-in the parameter... Organization name or Id for url Fill-in the parameter... API Version Fill-in the parameter... Optional Parameters AuthScheme Bearer AuthHeader Authorization Default Project Name RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Azure DevOps Connector authentication reference.(On-Premises) Personal Access Token (PAT) (DEPRECATED)
**DEPRECATED:** On-premises PAT method is legacy; consider Azure App Credentials if your server supports Azure AD apps. To connect to Azure DevOps On-Premises Server using a Personal Access Token (PAT), you must first create a valid PAT:-
Start by navigating to your on-premises Azure DevOps Server URL.
NOTE: The screenshots shown below are from the cloud version, so your interface may look slightly different depending on which on-premises Azure DevOps Server version you’re using — however, the overall concepts and steps are very similar between the cloud and on-premises editions. -
Now open any project and capture Collection Name from the URL. For example if your URL is
https://tfs.mycompany.local/tfs/MyCollection/MyProject/
then your collection name is MyCollection usually after /tfs/. Copy this collection name and later we will enter on Connection UI. -
Continue by...
- naming your token
- Enter
- Done!
(On-Premises) Personal Access Token (PAT) (DEPRECATED) [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
AzureDevopsDSNAzure DevOps(On-Premises) Personal Access Token (PAT) (DEPRECATED) [Http]https://dev.azure.comRequired Parameters Personal Access Token (PAT) Fill-in the parameter... Collection name (e.g. MyCollection) Fill-in the parameter... API Version Fill-in the parameter... Optional Parameters AuthScheme Bearer AuthHeader Authorization Default Project Name RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Azure DevOps Connector authentication reference. -
ZappySys API Driver - Azure DevOpsRead and write Azure DevOps (Cloud or On-Premises) data effortlessly. Integrate, manage, and automate work items, projects, and teams — almost no coding required.AzureDevopsDSN
Then simply select the Delete Work Item Comment endpoint (action).
ZappySys API Driver - Azure DevOpsRead and write Azure DevOps (Cloud or On-Premises) data effortlessly. Integrate, manage, and automate work items, projects, and teams — almost no coding required.AzureDevopsDSNDELETE FROM WorkItemComments WHERE WorkItemId=6455 and Id=5284411
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Azure DevOps API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Azure DevOps servers).
Azure DevOps SQL query examples
Delete work item comment by ID
Deletes a single comment by its ID and work item ID. The comment is removed from the work item. Use when you need to remove one comment from the discussion thread.
delete_workitem_comment endpoint belongs to
WorkItemComments
Delete work item comment in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your AzureDevopsDSN DSN from the list.
Azure DevOps Connector actions
Need another use case? Pick the next Azure DevOps action in Alteryx below.
- Create Project
- Create Team
- Create Work Item
- Create Work Item Comment
- Delete Project
- Delete Team
- Delete Work Item
- Get List of Projects
- Get List of Queries
- Get List of Teams
- Get Project Details
- Get Query Fileds
- Get Team Details
- Get Team Iteration Capacities
- Get Team Iterations
- Get Team Members
- Get Work Item Column Fields
- Get Work Item Comment by Comment Id and Work Item Id
- Get Work Item Comments (by WorkItem Id)
- Get Work Item Types
- Get Work Items by Ids
- Get Work Items for Specified Query Id
- Query Work Item Comments
- Query Work Items
- Search for Work Items by Text
- Update Project
- Update Team
- Update Work Item
- Update Work Item Comment
You now know how to delete work item comment in Alteryx without writing complex code. Azure DevOps ODBC Driver handled pagination and authentication automatically.
