How to read Monday data in PowerBI using ODBC
Monday.com is a flexible work operating system that helps teams manage projects, workflows, and operations. Its GraphQL API allows you to access boards, items, groups, users, and activity data programmatically. In this tutorial, you will learn how to connect to monday.com using Zappysys ODBC Driver for REST APIs and query data using standard SQL.
By configuring an ODBC DSN for monday.com, you can pull data into Excel, Power BI, Tableau, SQL Server, Python, and other ODBC-compatible applications without writing custom API integration code.
  1. Windows operating system (32-bit or 64-bit).
  2. A monday.com account with API access permissions.
  3. An ODBC-compatible client tool (Excel, Power BI, Tableau, Python, SQL Server, etc.).
  4. Install the ZappySys ODBC Driver.
Generate monday.com API Token
  1. Sign in to your monday.com account.
  2. Open your profile menu and go to Admin (or Developers, depending on your plan).
  3. Navigate to Connections and click Personal API token settings.
  4. Create a new API token (personal or app).
  5. Copy the token and store it securely.
  6. Monday – create token
  1. Search for ODBC in the Windows Start menu and open the ODBC Data Source Administrator.
  2. In the User DSN or System DSN tab, click Add to create a new data source.
  3. In the ODBC Data Source Setup window, select the ZappySys JSON Driver and click Continue.
  1. Set the following connection details:
    • Base URL:
    • HTTP Method: POST
    • Body Content Type: JSON (application/json)
      Monday – ODBC JSON driver
  2. Open the HTTP settings and configure token authentication:
    • Authentication Type: Static Token / API Key
    • API Key: Paste your monday.com token
    • Header Name: Authorization
    • OAuth Scheme: none (send raw token in header)
      Monday – ODBC HTTP Connection
  3. Set Body Content Type to JSON (application/json).
  4. Use this request body to fetch board metadata:
  5. Set Array Filter / JSON Path to:
  6. Click Test Connection to verify connectivity, then click OK to save the DSN.
Preview Monday.com Data in ODBC Driver
  1. Go to the Preview tab.
  2. Select a table, then click Preview Data to confirm that rows are returned.
    Monday – ODBC Final Result
Connect Power BI to monday.com via ODBC
  1. Open Power BI Desktop.
  2. Click Get Data in the Home ribbon.
  3. Click More… and search for ODBC.
  4. Click Connect.
    Power BI – Get data from ODBC connection
  5. From the dropdown, select the monday.com ODBC data source you created earlier.
  6. You can enter a custom query for use with the ODBC JSON driver.
  7. Click OK.
    Notion – Power BI connection
  8. Click Load to import the data into Power BI.
  9. In the Navigator window, select the monday.com columns you want to load.
    Notion – Power BI final result
Connecting Monday to Power BI using the Zappysys ODBC Driver provides a seamless way to bring your workspace data into a powerful analytics platformThis setup lets you access monday.com data through SQL from your preferred analytics and ETL tools without building custom API scripts.
Explore the full capabilities of the ZappySys ODBC Drivers to optimize your data access and integration strategy. You can extend this solution to include periodic data synchronization, real-time dashboards, and advanced transformations using your preferred analytics platform.
Posted in Uncategorized.
