Create data source using OneDrive ODBC Driver
Watch this quick walkthrough to see how to configure your OneDrive ODBC data source, or scroll down for the step-by-step written guide.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the OneDrive Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "OneDrive" from the list of Popular Connectors. If "OneDrive" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    OnedriveDSN
    OneDrive
    • Configure the authentication in OneDrive.
    User Credentials
    OneDrive authentication
    WARNING: To automate your company's processes, make sure you use a system/generic account (e.g. automation@my-company.com). When you use a personal account which is tied to a specific employee profile and that employee leaves the company, the token may become invalid and any automated processes using that token will start to fail.
    1. Navigate to the Azure Portal and log in using your credentials.
    2. Access Microsoft Entra ID.
    3. Register a new application by going to App registrations and clicking on New registration button: Start new app registration in Microsoft Entra ID
      INFO: Find more information on how to register an application in Graph API reference.
    4. When configuration window opens, configure these fields:
      • Supported account type
        • Use Accounts in this organizational directory only, if you need access to data in your organization only.
      • Redirect URI:
        • Set the type to Public client/native (mobile & desktop).
        • Use https://zappysys.com/oauth as the URL.
      Register app in Microsoft Entra ID
    5. After registering the app, copy the Application (client) ID for later: Copy client ID of Microsoft Entra ID app
    6. Then copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs to use later in the configuration: Copy Auth and Token URLs in Microsoft Entra ID app
    7. Now go to SSIS package or ODBC data source and use the copied values in User Credentials authentication configuration:
      • In the Authorization URL field paste the OAuth authorization endpoint (v2) URL value you copied in the previous step.
      • In the Token URL field paste the OAuth token endpoint (v2) URL value you copied in the previous step.
      • In the Client ID field paste the Application (client) ID value you copied in the previous step.
      • In the Permissions (Scope) field use the default or pick labeled permissions. [User] scopes are enough for your own OneDrive (read-only: Files.Read). [Tenant] entries are broader and often need an admin to approve the app—use them when resolving other users’ or groups’ drives (User.Read.All, Group.Read.All) or all reachable files (Files.Read.All / Files.ReadWrite.All).
        • offline_access, openid, profile
        • User.Read, Files.Read, Files.ReadWrite
        • Files.Read.All, Files.ReadWrite.All, User.Read.All, Group.Read.All (often admin consent)
        Admin consent note:
        • Token generation can still ask for admin approval, even when delegated scopes are listed in API permissions.
        • A Global Administrator can allow user consent for selected low-impact delegated permissions.
        • Broad scopes such as Files.Read.All, Files.ReadWrite.All, User.Read.All, and Group.Read.All may still require admin consent.
        Settings: User consent settings (Entra ID > Enterprise apps > Consent and permissions > User consent settings). Docs: configure user consent, recommended settings.
    8. Press Generate Token button to generate Access and Refresh Tokens.
    9. Optional step. Choose Default Drive Id from the drop down menu.
    10. Click Test Connection to confirm the connection is working.
    11. Done! Now you are ready to use the API Connector!
    1. Set Authentication Type to User Credentials [OAuth]
    OnedriveDSN
    OneDrive
    https://graph.microsoft.com/v1.0
    Authorization URL Fill-in the parameter...
    Token URL Fill-in the parameter...
    Application (client) ID Fill-in the parameter...
    Permissions (Scope) Fill-in the parameter...
    Client Secret
    Refresh Token File Path
    Return URL https://zappysys.com/oauth
    Default Group or User Id (additional Scopes needed to list - If fails enter manually)
    Default Drive Id (Select after clicking **Generate Token**) me
    RetryStatusCodeList 429|503|423
    Login Prompt Option
    Search Option For Non-Indexed Fields (Default=Blank - Search Only Indexed)
    Extra Headers (e.g. Header1:AAA||Header2:BBB)
    IsAppCred 0
    Find full details in the OneDrive Connector authentication reference.
    Application Credentials
    Follow these simple steps below to create Microsoft Entra ID application with application access permissions. Using following steps, you can grant very granular app permissions to access File(s). Choose permission based on your need.
    Create OAuth app
        • e.g. select Accounts in this organizational directory only if you need access to data in your organization only.
      • Redirect URI:
        • Leave the URL field empty.
    6. Then copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs: Copy Auth and Token URLs in Microsoft Entra ID app
    7. Continue and create Client secret: Add Client secret for Microsoft Entra ID app
    8. Then copy the Client secret for later steps: Copy Client secret
    9. Continue by adding permissions for the app by going to the API permissions section, and clicking on Add a permission: Start adding permissions to Microsoft Entra ID app
    10. Select Microsoft Graph: Select Graph API permissions for Microsoft Entra ID app
    11. Then choose Application permissions option: Select app permissions for Microsoft Entra ID app
    12. Continue by adding these Files (OneDrive) permissions (Just search for "Files" and then select desired permissions): Select OneDrive scopes
    13. Finish by clicking Add permissions button: Add permissions to Microsoft Entra ID app
    14. Now it's time to Grant admin consent for your application: Grant admin consent for Microsoft Entra ID app
    15. Confirm all the permissions are granted: Admin consent granted successfully in Entra ID
    16. Now go to SSIS package or ODBC data source and use the copied values in Application Credentials authentication configuration:
      • In the Client Secret field paste the Client secret value you copied in the previous step.
      • Optional step. Choose Default Drive Id from the drop down menu.
    17. Click Test Connection to confirm the connection is working.
    1. Set Authentication Type to Application Credentials [OAuth]
    OnedriveDSN
    OneDrive
    Default Group or User Id (additional Scopes needed to list - If fails enter manually) Fill-in the parameter...
    Default Drive Id Fill-in the parameter...
    Scope https://graph.microsoft.com/.default
    IsAppCred 1
    Application Credentials with Certificate (Sign JWT with Private Key)
    Similar to Assplication-only access but with JWT sign with Private Key [API reference]
    Create OAuth app
    Configure App Permissions
    1. Continue by adding permissions for the app by going to the API permissions section, and clicking on Add a permission: Start adding permissions to Microsoft Entra ID app
    2. Select Microsoft Graph: Select Graph API permissions for Microsoft Entra ID app
    3. Then choose Application permissions option: Select app permissions for Microsoft Entra ID app
    4. Continue by adding these Files (OneDrive) permissions (Just search for "Files" and then select desired permissions): Select OneDrive scopes
    5. Finish by clicking Add permissions button: Add permissions to Microsoft Entra ID app
    6. Now it's time to Grant admin consent for your application: Grant admin consent for Microsoft Entra ID app
    7. Confirm all the permissions are granted: Admin consent granted successfully in Entra ID
    Generate a Self-Signed Certificate
    # Run this in PowerShell
    #Change .AddYears(1) to desired number. By default it expires certificate in one year as per below code.
    $cert = New-SelfSignedCertificate `
      -Subject "CN=MyClientAppCert" `
      -KeySpec Signature `
      -KeyExportPolicy Exportable `
      -KeyLength 2048 `
      -CertStoreLocation "Cert:\CurrentUser\My" `
      -KeyAlgorithm RSA `
      -HashAlgorithm SHA256 `
      -NotAfter (Get-Date).AddYears(1) `
      -Provider "Microsoft Enhanced RSA and AES Cryptographic Provider"
    # Export private key (.pfx)  - Keep this with you to make API calls (SECRET KEY - DONOT SHARE)
    $pfxPath = "$env:USERPROFILE\Desktop\private_key.pfx"
    $pwd = ConvertTo-SecureString -String "yourStrongPassword123" -Force -AsPlainText
    Export-PfxCertificate -Cert $cert -FilePath $pfxPath -Password $pwd
    # Export public certificate (.cer) - UPLOAD this to Azure Portal
    $cerPath = "$env:USERPROFILE\Desktop\public_key.cer"
    Export-Certificate -Cert $cert -FilePath $cerPath
    Upload the Certificate (i.e. Public Key *.cer)
    Once we have certificate file generated.
    1. In your App Registration, go to Certificates & secrets
    2. Under Certificates, click Upload certificate
    3. Select the .cer file (public certificate) Upload public key (certificate file) for App-Credentials (JWT Auth)
    4. Click Select a file (Browse button)
    5. Select public key file (*.cer) from local machine and click OK to upload
    Configure ZappySys Connection - Use private key (i.e. *.pfx or *.pem)
    Now its time to use certificate pfx file (private key) generated in the previous step (NOTE: PFX file contains both private key and public key).
    1. Go to SSIS package or ODBC data source and use the copied values in Application Credentials authentication configuration:
    2. Configure private key
      • go to Certificate Tab
      • Change Storage Mode to Disk File: *.pfx format (PKCS#12).
        NOTE: You can also use Stored In LocalMachine mode if PFX file already imported in the Local Certificate Storage Area - User Store OR Machine Store.
        If you used OpenSSL to generate key pair then use Disk File: *.pem format (PKCS#8 or PKCS#1) Mode for Cert Store Location.
      • Supply the key file path
      • Supply the certificate password (same password used in earlier PowerShell script)
    3. Now go back to General Tab, choose Default Group / User Id and Default Drive Id from the drop down menu.
    4. Click Test connection see everything is good
    1. Set Authentication Type to Application Credentials with Certificate (Sign JWT with Private Key) [OAuth]
    OnedriveDSN
    OneDrive
    Certificate: *** Configure [Client Certificate] Tab *** Fill-in the parameter...
    IsAppCred 1
    ZappySys API Driver - OneDrive
    Read and write Microsoft OneDrive data effortlessly. Integrate, manage, and automate files and folders — almost no coding required.
    OnedriveDSN
  8. Then simply select the Read Drive endpoint (action).
    Read Drive
    Drive Id / Shared Folder Select the value from the dropdown
    DataFormat OData
    Continue On 404 Error (When item not found)
    SELECT * FROM get_drive
    WITH (DriveId='b!GtLQTMU726XXXXY5F2BBNi14')
    --You can get DriveId by selecting from 'Drives' table.
    OnedriveDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the OneDrive API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in OneDrive servers).
OneDrive SQL query examples
Read a drive
Gets a single drive by ID. Supply DriveId in the WITH clause to inspect drive metadata or quota before querying root or folder contents.
Read drive in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your OnedriveDSN DSN from the list.
OneDrive Connector actions
Need another use case? Pick the next OneDrive action in Alteryx below.
You now know how to read drive in Alteryx without writing complex code. OneDrive ODBC Driver handled pagination and authentication automatically.
