Create data source using OneDrive ODBC Driver
Watch this quick walkthrough to see how to configure your OneDrive ODBC data source, or scroll down for the step-by-step written guide.
When the Configuration window appears give your data source a name if you haven't done that already, then select "OneDrive" from the list of Popular Connectors. If "OneDrive" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
OnedriveDSNOneDrive
- Configure the authentication in OneDrive.
User Credentials
OneDrive authentication
WARNING: To automate your company's processes, make sure you use a system/generic account (e.g.automation@my-company.com). When you use a personal account which is tied to a specific employee profile and that employee leaves the company, the token may become invalid and any automated processes using that token will start to fail.- Navigate to the Azure Portal and log in using your credentials.
- Access Microsoft Entra ID.
Register a new application by going to
App registrations
and clicking on New registration button:
Supported account type
- Use
- Use
Redirect URI:
- Set the type to
- Set the type to
Then copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs to use later in the configuration:
In the Permissions (Scope) field use the default or pick labeled permissions. [User] scopes are enough for your own OneDrive (read-only:
Files.Read). [Tenant] entries are broader and often need an admin to approve the app—use them when resolving other users’ or groups’ drives (User.Read.All,Group.Read.All) or all reachable files (Files.Read.All/Files.ReadWrite.All).-
offline_access,openid,profile -
User.Read,Files.Read,Files.ReadWrite -
Files.Read.All,Files.ReadWrite.All,User.Read.All,Group.Read.All(often admin consent)
- Broad scopes such as
Files.Read.All,Files.ReadWrite.All,User.Read.All, andGroup.Read.Allmay still require admin consent.
- Optional step. Choose Default Drive Id from the drop down menu.
OnedriveDSNOneDriveUser Credentials [OAuth]https://graph.microsoft.com/v1.0Required Parameters Authorization URL Fill-in the parameter... Token URL Fill-in the parameter... Application (client) ID Fill-in the parameter... Permissions (Scope) Fill-in the parameter... Optional Parameters Client Secret Refresh Token File Path Return URL https://zappysys.com/oauth Default Group or User Id (additional Scopes needed to list - If fails enter manually) Default Drive Id (Select after clicking **Generate Token**) me RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429|503|423 RetryCountMax 5 RetryMultiplyWaitTime True Login Prompt Option Search Option For Non-Indexed Fields (Default=Blank - Search Only Indexed) Extra Headers (e.g. Header1:AAA||Header2:BBB) IsAppCred 0
Find full details in the OneDrive Connector authentication reference.Application Credentials
Follow these simple steps below to create Microsoft Entra ID application with application access permissions. Using following steps, you can grant very granular app permissions to access File(s). Choose permission based on your need.
Create OAuth app
App registrations
- e.g. select
Accounts in this organizational directory onlyif you need access to data in your organization only.
- e.g. select
Redirect URI:
- Set the type to
Public client/native (mobile & desktop). - Leave the URL field empty.
- Set the type to
Then copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs:
Continue and create Client secret:
Then copy the Client secret for later steps:
Continue by adding permissions for the app by going to the API permissions section, and clicking on Add a permission:
Select Microsoft Graph:
Then choose Application permissions option:
Continue by adding these Files (OneDrive) permissions (Just search for "Files" and then select desired permissions):
Finish by clicking Add permissions button:
Now it's time to Grant admin consent for your application:
Confirm all the permissions are granted:
Now go to SSIS package or ODBC data source and use the copied values in Application Credentials authentication configuration:
- In the Client Secret field paste the Client secret value you copied in the previous step.
Application Credentials [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
OnedriveDSNOneDriveApplication Credentials [OAuth]https://graph.microsoft.com/v1.0Required Parameters Token URL Fill-in the parameter... Application (client) ID Fill-in the parameter... Client Secret Fill-in the parameter... Default Group or User Id (additional Scopes needed to list - If fails enter manually) Fill-in the parameter... Default Drive Id Fill-in the parameter... Optional Parameters Scope https://graph.microsoft.com/.default RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429|503|423 RetryCountMax 5 RetryMultiplyWaitTime True Search Option For Non-Indexed Fields (Default=Blank - Search Only Indexed) Extra Headers (e.g. Header1:AAA||Header2:BBB) IsAppCred 1
Find full details in the OneDrive Connector authentication reference.Application Credentials with Certificate (Sign JWT with Private Key)
Similar to Assplication-only access but with JWT sign with Private Key [API reference]
Create OAuth app
App registrations
- e.g. select
- e.g. select
Configure App Permissions
Generate a Self-Signed Certificate
# Run this in PowerShell #Change .AddYears(1) to desired number. By default it expires certificate in one year as per below code. $cert = New-SelfSignedCertificate ` -Subject "CN=MyClientAppCert" ` -KeySpec Signature ` -KeyExportPolicy Exportable ` -KeyLength 2048 ` -CertStoreLocation "Cert:\CurrentUser\My" ` -KeyAlgorithm RSA ` -HashAlgorithm SHA256 ` -NotAfter (Get-Date).AddYears(1) ` -Provider "Microsoft Enhanced RSA and AES Cryptographic Provider" # Export private key (.pfx) - Keep this with you to make API calls (SECRET KEY - DONOT SHARE) $pfxPath = "$env:USERPROFILE\Desktop\private_key.pfx" $pwd = ConvertTo-SecureString -String "yourStrongPassword123" -Force -AsPlainText Export-PfxCertificate -Cert $cert -FilePath $pfxPath -Password $pwd # Export public certificate (.cer) - UPLOAD this to Azure Portal $cerPath = "$env:USERPROFILE\Desktop\public_key.cer" Export-Certificate -Cert $cert -FilePath $cerPathUpload the Certificate (i.e. Public Key *.cer)
Once we have certificate file generated.- In your App Registration, go to Certificates & secrets
- Under Certificates, click Upload certificate
- Select the
.cerfile (public certificate)
- Click Select a file (Browse button)
- Select public key file (*.cer) from local machine and click OK to upload
Configure ZappySys Connection - Use private key (i.e. *.pfx or *.pem)
Now its time to use certificate pfx file (private key) generated in the previous step (NOTE: PFX file contains both private key and public key).-
Go to SSIS package or ODBC data source and use the copied values in Application Credentials authentication configuration:
- Configure private key
- go to Certificate Tab
- Change Storage Mode to
Disk File: *.pfx format (PKCS#12).NOTE: You can also useStored In LocalMachinemode if PFX file already imported in the Local Certificate Storage Area - User Store OR Machine Store. If you used OpenSSL to generate key pair then useDisk File: *.pem format (PKCS#8 or PKCS#1)Mode for Cert Store Location. - Supply the key file path
- Supply the certificate password (same password used in earlier PowerShell script)
- Now go back to General Tab, choose Default Group / User Id and Default Drive Id from the drop down menu.
- Click Test connection see everything is good
Application Credentials with Certificate (Sign JWT with Private Key) [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
OnedriveDSNOneDriveApplication Credentials with Certificate (Sign JWT with Private Key) [OAuth]https://graph.microsoft.com/v1.0Required Parameters Token URL Fill-in the parameter... Application (client) ID Fill-in the parameter... Certificate: *** Configure [Client Certificate] Tab *** Fill-in the parameter... Default Group or User Id (additional Scopes needed to list - If fails enter manually) Fill-in the parameter... Default Drive Id Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429|503|423 RetryCountMax 5 RetryMultiplyWaitTime True Search Option For Non-Indexed Fields (Default=Blank - Search Only Indexed) Extra Headers (e.g. Header1:AAA||Header2:BBB) IsAppCred 1
Find full details in the OneDrive Connector authentication reference. -
ZappySys API Driver - OneDriveRead and write Microsoft OneDrive data effortlessly. Integrate, manage, and automate files and folders — almost no coding required.OnedriveDSN
Then simply select the Make Generic REST API Request (Bulk Write) endpoint (action).
ZappySys API Driver - OneDriveRead and write Microsoft OneDrive data effortlessly. Integrate, manage, and automate files and folders — almost no coding required.OnedriveDSNSELECT * FROM __DynamicRequest__ WITH ( "Url" = '/something/123', "RequestMethod" = 'POST' )
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the OneDrive API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in OneDrive servers).
OneDrive SQL query examples
Make generic rest api request
generic_request_bulk_write endpoint belongs to
__DynamicRequest__
Once the ODBC window opens, click Connect Asset and select your OnedriveDSN DSN from the list.
OneDrive Connector actions
Need another use case? Pick the next OneDrive action in Alteryx below.
- Copy item (File or Folder)
- Create / Update CSV File (Generic)
- Create / Update JSON File (Generic)
- Delete Item (File or Folder)
- Download File
- Get Groups
- Get Item (File or Folder)
- Get User Drives
- Get Users
- List Drives
- List Excel Files
- List Excel Worksheets of a File (i.e. List Tabs)
- List Files
- List Root (Non Recursive)
- Lists Folder Items (Non-Recursive Children)
- Move or rename item (File or Folder)
- Read CSV File (Generic)
- Read Drive
- Read Excel Worksheet (Auto Detect Range)
- Read Excel Worksheet (From Exact Range)
- Read JSON File (Generic)
- Upload File
You now know how to make generic REST API request (bulk write) in Alteryx without writing complex code. OneDrive ODBC Driver handled pagination and authentication automatically.
