When the Configuration window appears give your data source a name if you haven't done that already, then select "Asana" from the list of Popular Connectors. If "Asana" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
AsanaDSNAsana
- Configure the authentication in Asana.
Personal Access Token
Asana authentication
Here is how to obtain a Personal Access Token (PAT) in Asana:-
Open My apps in Asana portal
and click Create new token button:
Once a popup opens, name your new token:
Then click Copy button to copy the token:
- Now go to SSIS package or ODBC data source and use this token in Personal Access Token authentication configuration.
- Choose Default Workspace and Default Project to work with.
- Done! Now you are ready to use Asana Connector!
Personal Access Token [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
AsanaDSNAsanaPersonal Access Token [Http]https://app.asana.com/api/1.0Required Parameters Enter Token (Personal Access Token - PAT) Fill-in the parameter... Default Workspace Fill-in the parameter... Default Project Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Asana Connector authentication reference.OAuth app
Here is how to register an OAuth app in Asana:-
and click Create new app button:
Once a popup opens, name your app and check two options, and click Create app button:
Then copy Client ID and Client secret and save them in a file (we will need them for authentication):
Continue by selecting OAuth menu item on your left and click Add redirect URL button (you can have your own or use
https://zappysys.com/oauth):
- Proceed by clicking on the Manage distribution section on your left.
Then specify workspaces your app needs to access (use Any workspace to access them all):
- Once you do that, click Save changes button.
- Now go to SSIS package or ODBC data source and use Client ID, Client Secret, and Redirect URL in OAuth app authentication configuration.
OAuth app [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
AsanaDSNAsanaOAuth app [OAuth]https://app.asana.com/api/1.0Required Parameters ClientId Fill-in the parameter... Client Secret Fill-in the parameter... Default Workspace (** Select after Token is generated **) Fill-in the parameter... Default Project (** Select after Token is generated **) Fill-in the parameter... Optional Parameters Permissions default Redirect URL https://zappysys.com/oauth RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Asana Connector authentication reference. -
ZappySys API Driver - AsanaRead and write Asana data effortlessly. Integrate, manage, and automate tasks, projects, workspaces, and time entries — almost no coding required.AsanaDSN
Then simply select the Get Workspace Custom Fields endpoint (action).
ZappySys API Driver - AsanaRead and write Asana data effortlessly. Integrate, manage, and automate tasks, projects, workspaces, and time entries — almost no coding required.AsanaDSNSELECT * FROM WorkspaceCustomFields
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Asana API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Asana servers).
Asana SQL query examples
Get WorkspaceCustomFields
get_workspace_custom_fields endpoint belongs to
Get workspace custom fields in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your AsanaDSN DSN from the list.
Asana Connector actions
- Download Attachment
- Download Multiple Attachments
- Get Allocations
- Get Attachments (For Project refer to Key-Resources Upload only)
- Get Goals
- Get Memberships
- Get Portfolio Custom Fields
- Get Portfolios
- Get Project (Single)
- Get Project Custom Fields
- Get Project Section
- Get Project Sections
- Get Projects
- Get Sub Tasks
- Get Tags
- Get Task (Single)
- Get Tasks
- Get Time Tracking Entries
- Get User (Single)
- Get User Task Lists
- Get Users
- Get Workspace (Single)
- Get Workspace Tasks
- Get Workspace Teams
- Get Workspaces
- Search Tasks (Advanced Filter)
You now know how to get workspace custom fields in Alteryx without writing complex code. Asana ODBC Driver handled pagination and authentication automatically.
