While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Asana Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Asana" from the list of Popular Connectors. If "Asana" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    AsanaDSN
    Asana
    • Configure the authentication in Asana.
    Personal Access Token
    Asana authentication
    Here is how to obtain a Personal Access Token (PAT) in Asana:
    1. Open My apps in Asana portal and click Create new token button: Create Personal Access Token in Asana
    2. Once a popup opens, name your new token: Name Personal Access Token in Asana
    3. Then click Copy button to copy the token: Use Personal Access Token to get Asana data via REST API
    4. Now go to SSIS package or ODBC data source and use this token in Personal Access Token authentication configuration.
    5. Choose Default Workspace and Default Project to work with.
    6. Click Test Connection to confirm the connection is working.
    7. Done! Now you are ready to use Asana Connector!
    1. Set Authentication Type to Personal Access Token [Http]
    AsanaDSN
    Asana
    https://app.asana.com/api/1.0
    Enter Token (Personal Access Token - PAT) Fill-in the parameter...
    Default Workspace Fill-in the parameter...
    Default Project Fill-in the parameter...
    Find full details in the Asana Connector authentication reference.
    OAuth app
    Here is how to register an OAuth app in Asana:
    1. Open My apps in Asana portal and click Create new app button: Create new OAuth app in Asana
    2. Once a popup opens, name your app and check two options, and click Create app button: Name OAuth app in Asana
    3. Then copy Client ID and Client secret and save them in a file (we will need them for authentication): Use OAuth app to get Asana data via REST API
    4. Continue by selecting OAuth menu item on your left and click Add redirect URL button (you can have your own or use https://zappysys.com/oauth): Add redirect URL to Asana OAuth app
    5. Proceed by clicking on the Manage distribution section on your left.
    6. Then specify workspaces your app needs to access (use Any workspace to access them all): Choose distribution method in Asana OAuth app
    7. Once you do that, click Save changes button.
    8. Now go to SSIS package or ODBC data source and use Client ID, Client Secret, and Redirect URL in OAuth app authentication configuration.
    9. When you are done with that, click Generate Token button to generate Access and Refresh Tokens.
    10. Choose Default Workspace and Default Project to work with.
    11. Click Test Connection to confirm the connection is working.
    12. Done! Now you are ready to use Asana Connector!
    1. Set Authentication Type to OAuth app [OAuth]
    AsanaDSN
    Asana
    OAuth app [OAuth]
    Default Workspace (** Select after Token is generated **) Fill-in the parameter...
    Default Project (** Select after Token is generated **) Fill-in the parameter...
    Permissions default
    Redirect URL https://zappysys.com/oauth
    ZappySys API Driver - Asana
    Read and write Asana data effortlessly. Integrate, manage, and automate tasks, projects, workspaces, and time entries — almost no coding required.
    AsanaDSN
    Url /something/123
    Filter
    Limit 100
    Request Method POST
    IsMultiPart False
    Body {$rows$}
    JsonOutputFormat Multicontent
    DoNotOutputNullProperty False
    Batch Size (Default=1) 1
    Request Format Default
    Response Format Default
    Csv - Column Delimiter ,
    Csv - Row Delimiter {NEWLINE}
    Csv - Quote Around Value True
    Encoding
    CharacterSet
    Writer DateTime Format
    Csv - Has Header Row True
    Xml - ElementsToTreatAsArray
    NextUrlAttributeOrExpr $.next_page.uri
        "Url" = '/something/123',
        "RequestMethod" = 'POST'
    AsanaDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Asana API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Asana servers).
Asana SQL query examples
Make generic rest api request
  6. Once the ODBC window opens, click Connect Asset and select your AsanaDSN DSN from the list.
Asana Connector actions
You now know how to make generic REST API request (bulk write) in Alteryx without writing complex code. Asana ODBC Driver handled pagination and authentication automatically.
