When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoho CRM" from the list of Popular Connectors. If "Zoho CRM" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
ZohoCrmDSNZoho CRM
- Configure the authentication in Zoho CRM.
Zoho CRM authentication
- Click Add Client link
- Click CREATE.
ZohoCrmDSNZoho CRMOAuth [OAuth]https://www.zohoapis.com/crm/[$Version$]Optional Parameters ClientId ClientSecret Permissions ZohoCRM.settings.all ZohoCRM.modules.all ZohoCRM.coql.READ AccountUrl https://accounts.zoho.com RedirectUrl https://zappysys.com/oauth API Version v2 RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Zoho CRM Connector authentication reference. -
ZappySys API Driver - Zoho CRMRead and write Zoho CRM data effortlessly. Integrate, manage, and automate accounts, leads, contacts, and deals — almost no coding required.ZohoCrmDSN
Then simply select the Read Data (Direct COQL Query - Auto Paging) endpoint (action).
ZappySys API Driver - Zoho CRMRead and write Zoho CRM data effortlessly. Integrate, manage, and automate accounts, leads, contacts, and deals — almost no coding required.ZohoCrmDSNSELECT * FROM get_module_data_coql WITH( sql_query = 'select Last_Name, First_Name, Company from Leads where Company like ''Test'' order by id desc' , Version = 'v8' , PageSize = '2000' )
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Zoho CRM API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoho CRM servers).
Zoho CRM SQL query examples
Read data using Direct COQL Endpoint
Runs a direct Zoho CRM COQL query using the get_module_data_coql endpoint. Enter the full COQL statement in the sql_query parameter. The connector sends the query to Zoho's /coql API and automatically pages results when your query does not include a LIMIT clause.
Use this endpoint when you want full control over the COQL query, including selected fields, filters, joins, sorting, and aggregate expressions. For a guided parameter-based experience, use the get_module_data_coql_builder endpoint instead.
Tip: If you want to run native COQL directly without calling an endpoint with WITH(...), use the #DirectSql prefix. See the native COQL pass-through example below.
API v2 supports up to 200 rows per page. Newer API versions such as v7 or v8 support larger page sizes, up to 2000 rows per page. For the Emails module, use API v2 and keep PageSize at 200 or less.
SELECT *
WITH(
, Version = 'v8'
, PageSize = '2000'
Read data in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your ZohoCrmDSN DSN from the list.
Zoho CRM Connector actions
- Add / Update Tags for records
- Delete [Dynamic Endpoint]
- Gets record count for specific tag for module
- Insert [Dynamic Endpoint]
- List Module Fields
- List Module Settings
- List Modules
- List Tags
- List Territories
- List Views
- Read [Dynamic Endpoint]
- Read [Dynamic Endpoint] (Use this for fewer than 50 Fields in v3+)
- Read Data (COQL Query Builder)
- Search [Dynamic Endpoint]
- Update [Dynamic Endpoint]
- Upsert [Dynamic Endpoint] (Update or Insert)
You now know how to read data (direct COQL query - auto paging) in Alteryx without writing complex code. Zoho CRM ODBC Driver handled pagination and authentication automatically.
