While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Zoho CRM Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoho CRM" from the list of Popular Connectors. If "Zoho CRM" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ZohoCrmDSN
    Zoho CRM
    • Configure the authentication in Zoho CRM.
    Zoho CRM authentication
    1. Go to Zoho API Console
    2. Click Add Client link
    7. Click CREATE.
    ZohoCrmDSN
    Zoho CRM
    OAuth [OAuth]
    https://www.zohoapis.com/crm/[$Version$]
    ClientId
    ClientSecret
    Permissions ZohoCRM.settings.all ZohoCRM.modules.all ZohoCRM.coql.READ
    API Version v2
    Find full details in the Zoho CRM Connector authentication reference.
    ZappySys API Driver - Zoho CRM
    Read and write Zoho CRM data effortlessly. Integrate, manage, and automate accounts, leads, contacts, and deals — almost no coding required.
    ZohoCrmDSN
  8. Then simply select the Add / Update Tags for records endpoint (action).
    module Select the value from the dropdown
    Record Id(s) (comma seperated list) Select the value from the dropdown
    Tag Id Select the value from the dropdown
    Overwrite
    SELECT * FROM post_tags
    WITH(
    	  module='Accounts'
    	, ids='1558554000105151002'
    	, tag_names='mytag1,mytag2'
      , over_write='true'
    ZohoCrmDSN
    WITH(
    	  module='Accounts'
      , over_write='true'
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Zoho CRM API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoho CRM servers).
Zoho CRM SQL query examples
Update tags
Adds or overwrites tags for existing records. This example demonstrates using the post_tags endpoint to update tags for a specific record ID in the Accounts module.
WITH(
	  module='Accounts'
  , over_write='true'
Add / update tags for records in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your ZohoCrmDSN DSN from the list.
Zoho CRM Connector actions
You now know how to add / update tags for records in Alteryx without writing complex code. Zoho CRM ODBC Driver handled pagination and authentication automatically.
