While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Zoho CRM Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoho CRM" from the list of Popular Connectors. If "Zoho CRM" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ZohoCrmDSN
    Zoho CRM
    • Configure the authentication in Zoho CRM.
    Zoho CRM authentication
    1. Go to Zoho API Console
    2. Click Add Client link
    7. Click CREATE.
    ZohoCrmDSN
    Zoho CRM
    OAuth [OAuth]
    https://www.zohoapis.com/crm/[$Version$]
    ClientId
    ClientSecret
    Permissions ZohoCRM.settings.all ZohoCRM.modules.all ZohoCRM.coql.READ
    API Version v2
    Find full details in the Zoho CRM Connector authentication reference.
    ZappySys API Driver - Zoho CRM
    Read and write Zoho CRM data effortlessly. Integrate, manage, and automate accounts, leads, contacts, and deals — almost no coding required.
    ZohoCrmDSN
  8. Then simply select the Read Data (COQL Query Builder) endpoint (action).
    Module Select the value from the dropdown
    Select Fields Select the value from the dropdown
    Where Condition
    Group By Fields
    Order By
    API Version
    PageSize 200
    NextUrlEndIndicator false
    StopIndicatorAttributeOrExpr $.info.more_records
    NextUrlWaitInMs 0
    PagingMode ByPostData
    PagingByUrlAttributeName {%offset%}
    PagingByUrlCurrentPage 0
    PagingIncrementBy
    SELECT *
    	FROM get_module_data_coql_builder
    	WITH(
    		  Module = 'Leads'
    		, Version = 'v8'
    		, PageSize = '2000'
    		-- Select regular fields and aggregate functions.
    		-- Aggregate function names must be uppercase: COUNT, SUM, MIN, MAX, AVG.
    		, Select = 'Country,Lead_Status,COUNT(id)'
    		-- Enter condition only. Do not include the WHERE keyword.
    		, Where = 'Lead_Status=''Junk Lead'' and Created_Time>''2015-07-08T03:07:16-04:00'''
    		-- Required because Select mixes regular fields with COUNT(id).
    		, GroupBy = 'Country,Lead_Status'
    		-- Enter sort expression only. Do not include the ORDER BY keyword.
    		, OrderBy = 'Country desc'
    ZohoCrmDSN
    SELECT *
    	WITH(
    		  Module = 'Leads'
    		, Version = 'v8'
    		, PageSize = '2000'
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Zoho CRM API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoho CRM servers).
Zoho CRM SQL query examples
Read data using COQL Query Builder
Builds and runs a Zoho CRM COQL query using the get_module_data_coql_builder endpoint. Instead of typing the full COQL statement, provide the module, selected fields, filter condition, and optional grouping or sorting. The connector generates the final COQL query and sends it to Zoho's /coql API.
This example queries the Leads module, groups records by Country and Lead_Status, and returns a COUNT(id) value for each group.
Use API v7 or v8 for standard modules when you want larger pages, up to 2000 rows per API call. API v2 is limited to 200 rows per COQL call. Zoho COQL offset pagination has a documented window limit: v7/v8 allow up to 100,000 rows for the same query criteria, while v6 documents a 10,000-row offset window. For larger pulls, split the query using a stable condition such as id > last_record_id and repeat the request.
Aggregate functions such as COUNT, SUM, MIN, MAX, and AVG must be uppercase. When mixing aggregate functions with regular fields, every regular field in Select must also be listed in GroupBy.
SELECT *
	WITH(
		  Module = 'Leads'
		, Version = 'v8'
		, PageSize = '2000'
Read email status metrics using COQL Query Builder (Emails module, v2)
Queries the Emails module via COQL for metrics such as status (bounced, opened, clicked), open/click times, bounce reason, and related fields. Zoho exposes Emails in COQL only through API v2; from v3 onward this approach does not apply. With v2, PageSize must be 200 or less. For other modules, use v7/v8 (or v3+) if you need page sizes larger than 200.
SELECT *
WITH(
	  Module='Emails'
	, Version='v2' --must be v2 for Emails module , newer versions dont support Emails module in COQL
	, Select='Owner,Subject,Entity_Id,Modified_By,Created_Time,Modified_Time,Sent_To,Module,Last_Opened,Last_Clicked,Bounced_Time,First_Opened,First_Clicked,No_of_Opens,No_of_Clicks,Template_Name,Sent_On,Status,Source,Cc,Sender,Bounce_Reason,Bcc'
	--, Where='Status = ''Bounced'' and Created_Time>''2015-07-08T03:07:16-04:00''  '
  --, OrderBy='Created_Time desc'
Read data in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your ZohoCrmDSN DSN from the list.
Zoho CRM Connector actions
You now know how to read data (COQL query builder) in Alteryx without writing complex code. Zoho CRM ODBC Driver handled pagination and authentication automatically.
