While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Stripe Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Stripe" from the list of Popular Connectors. If "Stripe" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    StripeDSN
    Stripe
    Stripe
    Stripe authentication
    3. Then create a Secret key.
    StripeDSN
    Stripe
    Stripe [Http]
    https://api.stripe.com/v1
    ZappySys API Driver - Stripe
    StripeDSN
  8. Then simply select the Delete a Product endpoint (action).
    Delete a Product
    Product Id Select the value from the dropdown
    ContineOn404Error True
    Next Link/Cursor Expression $.data[-1:].id
    Stop Indicator Value false
    Stop Indicator Attribute $.has_more
    Suffix for Next URL starting_after=<%nextlink%>
    DELETE FROM Products
    WHERE Id = 'abc'
    StripeDSN
    WHERE Id = 'abc'
Stripe SQL query examples
Delete a product
Deletes a product record from the Products table. This example demonstrates how to remove a product using the DELETE FROM statement with a specific Id in the WHERE clause.
WHERE Id = 'abc'
delete_product endpoint belongs to Products table(s), and can therefore be used via those table(s).
Delete a product in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your StripeDSN DSN from the list.
Stripe Connector actions
You now know how to delete a product in Alteryx without writing complex code. Stripe ODBC Driver handled pagination and authentication automatically.
