When the Configuration window appears give your data source a name if you haven't done that already, then select "Stripe" from the list of Popular Connectors. If "Stripe" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
StripeDSNStripe
- Configure the authentication in Stripe.
Stripe
Stripe authentication
- Login into your Stripe account
- Go to https://dashboard.stripe.com/apikeys.
- Then create a Secret key.
- In the parameter 'Token' fill in newly created key.
Stripe [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
StripeDSNStripeStripe [Http]https://api.stripe.com/v1Required Parameters Token Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Stripe Connector authentication reference. -
ZappySys API Driver - StripeRead and write Stripe data effortlessly. Manage customers, products, subscriptions, and invoices — almost no coding required.StripeDSN
Then simply select the Create an Invoice endpoint (action).
ZappySys API Driver - StripeRead and write Stripe data effortlessly. Manage customers, products, subscriptions, and invoices — almost no coding required.StripeDSNSELECT * FROM create_invoice WITH ( "customer" = 'abcd-1234-customer' )
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Stripe API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Stripe servers).
Stripe SQL query examples
Create an invoice
Create an invoice in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your StripeDSN DSN from the list.
Stripe Connector actions
- Create a Customer
- Create a Product
- Create an Invoice Item
- Delete a Customer
- Delete a Draft Invoice
- Delete a Product
- Delete an Invoice Item
- Finalize an Invoice
- List All Customers
- List All Invoice Items
- List All Invoices
- List All Products
- List All Quotes
- List All Subscriptions
- List All Subscriptions Items
- Mark an Invoice As Uncollectible
- Pay an Invoice
- Retrieve a Customer
- Retrieve a single Product
- Retrieve a single Subscription
- Retrieve an Invoice
- Retrieve an Invoice Item
- Retrieve an Invoice Line Items
- Retrieve an Upcoming Invoice
- Retrieve an Upcoming Invoice Line Items
- Send an Invoice For Manual Payment
- Test Connection
- Update a Customer
- Update a Product
- Update an Invoice
- Update an Invoice Item
- Void an Invoice
You now know how to create an invoice in Alteryx without writing complex code. Stripe ODBC Driver handled pagination and authentication automatically.
