While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Stripe Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Stripe" from the list of Popular Connectors. If "Stripe" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    StripeDSN
    Stripe
    Stripe
    Stripe authentication
    3. Then create a Secret key.
    StripeDSN
    Stripe
    Stripe [Http]
    https://api.stripe.com/v1
    ZappySys API Driver - Stripe
    StripeDSN
  8. Then simply select the Create a Product endpoint (action).
    Create a Product
    Name Select the value from the dropdown
    Type (Good or Service) Select the value from the dropdown
    Active
    Description
    Caption (Can be set if Type = good)
    Package Dimensions - Height (inch) (Can be set if Type = good)
    Package Dimensions - Length (inch) (Can be set if Type = good)
    Package Dimensions - Weight (inch) (Can be set if Type = good)
    Package Dimensions - Width (inch) (Can be set if Type = good)
    Shippable (Can be set if Type = good)
    Statement Description (Can be set if Type = service)
    Unit Label (Can be set if Type = service)
    Product URL (Can be set if Type = good)
    Next Link/Cursor Expression $.data[-1:].id
    Stop Indicator Value false
    Stop Indicator Attribute $.has_more
    Suffix for Next URL starting_after=<%nextlink%>
    INSERT INTO Products
    (     [Name]
    	, [Caption]
    	, [Description]
    	, [Type]
    	--, [UnitLabel] --only when product type=service
    	, [Active]
    	, [PackageDimensionsHeight]
    	, [PackageDimensionsWidth]
    	, [PackageDimensionsLength]
    	, [PackageDimensionsWeight]
    	, [URL]
    	, [Image1]
    	, [Image2]
    	, [Image3]
    VALUES('SSIS PowerPack 3'
    	, 'SSIS Caption 3'
    	, 'SSIS PowerPack description long ....'
    	, 'good' --or service
    	--, 'Unit label' --only when product type=service
    	, 'True' --active ?
    	, '12'
    	, '13'
    	, '14'
    	, '1000'
    	, 'https://zappysys.com/products/ssis-powerpack/'
    	, 'https://zappysys.com/images/tech/web-api-logo.png'
    	, 'https://zappysys.com/images/tech/xml-logo.png'
    	, 'https://zappysys.com/images/tech/salesforce-logo.png'
    StripeDSN
    (     [Name]
    	, [Caption]
    	, [Description]
    	, [Type]
    	, [Active]
    	, [URL]
    	, [Image1]
    	, [Image2]
    	, [Image3]
    	, 'SSIS Caption 3'
    	, 'True' --active ?
    	, '12'
    	, '13'
    	, '14'
    	, '1000'
Stripe SQL query examples
Create a product
Creates a new product record in the Products table. This example demonstrates how to use the INSERT INTO statement to specify product details such as name, description, dimensions, and images.
(     [Name]
	, [Caption]
	, [Description]
	, [Type]
	, [Active]
	, [URL]
	, [Image1]
	, [Image2]
	, [Image3]
	, 'SSIS Caption 3'
	, 'True' --active ?
	, '12'
	, '13'
	, '14'
	, '1000'
create_product endpoint belongs to Products table(s), and can therefore be used via those table(s).
Create a product in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your StripeDSN DSN from the list.
Stripe Connector actions
You now know how to create a product in Alteryx without writing complex code. Stripe ODBC Driver handled pagination and authentication automatically.
