While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Stripe Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Stripe" from the list of Popular Connectors. If "Stripe" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    StripeDSN
    Stripe
    Stripe
    Stripe authentication
    3. Then create a Secret key.
    StripeDSN
    Stripe
    Stripe [Http]
    https://api.stripe.com/v1
    ZappySys API Driver - Stripe
    StripeDSN
  8. Then simply select the List All Products endpoint (action).
    List All Products
    Active
    Created later than (yyyy-MM-dd)
    Created on or later than (yyyy-MM-dd)
    Created earlier than (yyyy-MM-dd)
    Created on or earlier than (yyyy-MM-dd)
    Next Link/Cursor Expression $.data[-1:].id
    Stop Indicator Value false
    Stop Indicator Attribute $.has_more
    Suffix for Next URL starting_after=<%nextlink%>
    SELECT * FROM Products
    StripeDSN
Stripe SQL query examples
Read products
Reads all records from the Products table. This example demonstrates a basic SELECT query to retrieve a complete list of products from the Stripe account.
get_products endpoint belongs to Products table(s), and can therefore be used via those table(s).
List all products in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your StripeDSN DSN from the list.
Stripe Connector actions
You now know how to list all products in Alteryx without writing complex code. Stripe ODBC Driver handled pagination and authentication automatically.
