Create data source using ServiceNow ODBC Driver
Watch this quick walkthrough to see how to configure your ServiceNow ODBC data source, or scroll down for the step-by-step written guide.
When the Configuration window appears give your data source a name if you haven't done that already, then select "ServiceNow" from the list of Popular Connectors. If "ServiceNow" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
ServicenowDSNServiceNow
- Configure the authentication in ServiceNow.
Basic Auth (UserName and Password)
ServiceNow authentication
Authenticate using ServiceNow instance username and password.
Locate your ServiceNow instance credentials and use them for HTTP authentication:
- Go to https://developer.servicenow.com/dev.do and log in.
- Click on your profile picture.
When a menu appears, click on Manage instance password or a similar option:
In a new window you will see your HTTP Basic Authentication credentials:
Done! Use this username and password when configuring HTTP Authentication parameters.
Basic Auth (UserName and Password) [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
ServicenowDSNServiceNowBasic Auth (UserName and Password) [Http]https://[$InstanceName$].service-now.com/api/nowRequired Parameters InstanceName (e.g. mycompany) Fill-in the parameter... User name Fill-in the parameter... Password Fill-in the parameter... Optional Parameters ApiVersion v2 RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True Date Time Value Handling
Find full details in the ServiceNow Connector authentication reference.OAuth Authorization Code Grant (User Creds)
Authenticate using OAuth 2.0 Authorization Code Flow (3-legged)
Create OAuth application and use it for authentication:
- Login to your instance at https://your-instance-id.service-now.com.
Start by clicking on menu item All, then search for oauth, and click Application Registry option:
Then click button New:
Continue by clicking Create an OAuth API endpoint for external clients option:
Move on by naming your OAuth application and entering a Client Secret (or let it be generated automatically).
- Click on the lock icon next to the Redirect URL. Enter
https://zappysys.com/oauth. This is not needed if you use Client Credentials Grant or Password Grant -
Finally give it a final touch by increasing the Refresh Token Lifespan value to
315,360,000(it should last for 10 years):
- Change Default Grant Type as per your need. NOTE: If you prefer to use Client Credentials grant (Service account style access without using real userid-password) then your admin must enable it. Client Credentials is only supported on instances where it is explicitly enabled by the ServiceNow administrator. Its not supported in Dev / Free instance.
Done! Now you can use Client ID and Client Secret when configuring OAuth Authentication parameters.
Enable Client Credentials Grant Type
Enable the Client Credentials Grant Type:
Go to System Properties > All Properties, create a new property named
glide.oauth.inbound.client.credential.grant_type.enabled, and set it to true. - Configure the OAuth Application: Navigate to System OAuth > Application Registry, click New, and select Create an OAuth API endpoint for external clients. Set the name and save the record. In the Default Grant Type field, select Client Credentials and associate it with the integration user.
OAuth Authorization Code Grant (User Creds) [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
ServicenowDSNServiceNowOAuth Authorization Code Grant (User Creds) [OAuth]https://[$InstanceName$].service-now.com/api/nowRequired Parameters Redirect URI (***Must match as App Registry Page***) Fill-in the parameter...
Find full details in the ServiceNow Connector authentication reference.OAuth Client Credentials Grant (Must be enabled by Admin)
Authenticate using OAuth Client Credentials Grant (Client ID and Client Secret). [API reference]
OAuth Client Credentials Grant (Must be enabled by Admin) [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
ServicenowDSNServiceNowOAuth Client Credentials Grant (Must be enabled by Admin) [OAuth]https://[$InstanceName$].service-now.com/api/nowThere are no parameters to configure.
Find full details in the ServiceNow Connector authentication reference.OAuth Password Grant
Authenticate using OAuth Password Grant (ServiceNow instance username, password, OAuth Client ID, and Client Secret). [API reference]
OAuth Password Grant [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
ServicenowDSNServiceNowOAuth Password Grant [OAuth]https://[$InstanceName$].service-now.com/api/nowRequired Parameters User name Fill-in the parameter... Password Fill-in the parameter...
Find full details in the ServiceNow Connector authentication reference. -
ZappySys API Driver - ServiceNowRead and write ServiceNow data effortlessly. Integrate, manage, and automate incidents, tasks, attachments, and records — almost no coding required.ServicenowDSN
Then simply select the Get List Of System Tables Admin Use Sys Db Object endpoint (action).
ZappySys API Driver - ServiceNowRead and write ServiceNow data effortlessly. Integrate, manage, and automate incidents, tasks, attachments, and records — almost no coding required.ServicenowDSNSELECT * FROM get_system_tables_admin
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the ServiceNow API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in ServiceNow servers).
ServiceNow SQL query examples
Get list of system tables admin use sys db object
Get list of system tables admin use sys db object in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your ServicenowDSN DSN from the list.
ServiceNow Connector actions
Need another use case? Pick the next ServiceNow action in Alteryx below.
- Delete a Table Row
- Delete Attachment
- Delete table row
- Download Table Attachment (Single - Using Id)
- Download Table Attachments (Multiple - Using Query)
- Download Table Attachments By Parent Row Search
- Get Attachments
- Get Attachments By Parent Row Search
- Get List of Tables
- Get List Of Tables Admin Use Sys Db Object
- Get List Of User Tables Admin Use Sys Db Object
- Get Record Labels (Tags)
- Get Table Columns
- Get Table Columns Admin Use Sys Dictionary
- Get Table Row Count
- Get Table Rows
- Test Connection
- Update a Table Row
- Upload Attachment
You now know how to get list of system tables admin use sys db object in Alteryx without writing complex code. ServiceNow ODBC Driver handled pagination and authentication automatically.
