Create data source using ServiceNow ODBC Driver
Watch this quick walkthrough to see how to configure your ServiceNow ODBC data source, or scroll down for the step-by-step written guide.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the ServiceNow Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "ServiceNow" from the list of Popular Connectors. If "ServiceNow" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ServicenowDSN
    ServiceNow
    • Configure the authentication in ServiceNow.
    Basic Auth (UserName and Password)
    ServiceNow authentication
    Authenticate using ServiceNow instance username and password.
    Locate your ServiceNow instance credentials and use them for HTTP authentication:
    1. Go to https://developer.servicenow.com/dev.do and log in.
    2. Click on your profile picture.
    3. When a menu appears, click on Manage instance password or a similar option:
      Manage instance password in ServiceNow
    4. In a new window you will see your HTTP Basic Authentication credentials:
      Use instance credentials to authenticate to ServiceNow
    5. Done! Use this username and password when configuring HTTP Authentication parameters.
    1. Set Authentication Type to Basic Auth (UserName and Password) [Http]
    ServicenowDSN
    ServiceNow
    https://[$InstanceName$].service-now.com/api/now
    InstanceName (e.g. mycompany) Fill-in the parameter...
    User name Fill-in the parameter...
    ApiVersion v2
    Date Time Value Handling
    Find full details in the ServiceNow Connector authentication reference.
    OAuth Authorization Code Grant (User Creds)
    Authenticate using OAuth 2.0 Authorization Code Flow (3-legged)
    Create OAuth application and use it for authentication:
    1. Login to your instance at https://your-instance-id.service-now.com.
    2. Start by clicking on menu item All, then search for oauth, and click Application Registry option:
      Locate OAuth configuration in ServiceNow
    3. Then click button New:
      Create new OAuth application in ServiceNow
    4. Continue by clicking Create an OAuth API endpoint for external clients option:
      Use ServiceNow OAuth application for external clients
    5. Move on by naming your OAuth application and entering a Client Secret (or let it be generated automatically).
    6. Click on the lock icon next to the Redirect URL. Enter https://zappysys.com/oauth. This is not needed if you use Client Credentials Grant or Password Grant
    7. Finally give it a final touch by increasing the Refresh Token Lifespan value to 315,360,000 (it should last for 10 years):
      Configure OAuth application in ServiceNow
    8. Change Default Grant Type as per your need.
      NOTE: If you prefer to use Client Credentials grant (Service account style access without using real userid-password) then your admin must enable it. Client Credentials is only supported on instances where it is explicitly enabled by the ServiceNow administrator. Its not supported in Dev / Free instance.
    9. Done! Now you can use Client ID and Client Secret when configuring OAuth Authentication parameters.
    Enable Client Credentials Grant Type
    • Enable the Client Credentials Grant Type: Go to System Properties > All Properties, create a new property named glide.oauth.inbound.client.credential.grant_type.enabled, and set it to true.
    • Configure the OAuth Application: Navigate to System OAuth > Application Registry, click New, and select Create an OAuth API endpoint for external clients. Set the name and save the record. In the Default Grant Type field, select Client Credentials and associate it with the integration user.
    1. Set Authentication Type to OAuth Authorization Code Grant (User Creds) [OAuth]
    ServicenowDSN
    ServiceNow
    Redirect URI (***Must match as App Registry Page***) Fill-in the parameter...
    OAuth Client Credentials Grant (Must be enabled by Admin)
    Authenticate using OAuth Client Credentials Grant (Client ID and Client Secret). [API reference]
    1. Set Authentication Type to OAuth Client Credentials Grant (Must be enabled by Admin) [OAuth]
    ServicenowDSN
    ServiceNow
    There are no parameters to configure.
    OAuth Password Grant
    Authenticate using OAuth Password Grant (ServiceNow instance username, password, OAuth Client ID, and Client Secret). [API reference]
    1. Set Authentication Type to OAuth Password Grant [OAuth]
    ServicenowDSN
    ServiceNow
    ZappySys API Driver - ServiceNow
    Read and write ServiceNow data effortlessly. Integrate, manage, and automate incidents, tasks, attachments, and records — almost no coding required.
    ServicenowDSN
  8. Then simply select the Test Connection endpoint (action).
    Test Connection
    This Endpoint has no parameters.
    SELECT * FROM test_connection
    ServicenowDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the ServiceNow API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in ServiceNow servers).
ServiceNow SQL query examples
Test connection in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your ServicenowDSN DSN from the list.
ServiceNow Connector actions
Need another use case? Pick the next ServiceNow action in Alteryx below.
You now know how to test connection in Alteryx without writing complex code. ServiceNow ODBC Driver handled pagination and authentication automatically.
