While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Zoho SalesIQ Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoho SalesIQ" from the list of Popular Connectors. If "Zoho SalesIQ" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ZohoSalesiqDSN
    Zoho SalesIQ
    • Configure the authentication in Zoho SalesIQ.
    Zoho SalesIQ authentication
    1. Go to Zoho API Console
    2. Click Add Client link
    7. Click CREATE.
    ZohoSalesiqDSN
    Zoho SalesIQ
    OAuth [OAuth]
    https://salesiq.zoho.com/api/v2/[$Compnay$]
    Company Screen Name for URL (e.g. mycompany)
    ClientId
    ClientSecret
    Permissions SalesIQ.operators.READ SalesIQ.conversations.READ SalesIQ.feedbacks.READ SalesIQ.departments.READ
    Find full details in the Zoho SalesIQ Connector authentication reference.
    ZappySys API Driver - Zoho SalesIQ
    Read and write Zoho SalesIQ data effortlessly. Integrate, manage, and automate chats and visits — almost no coding required.
    ZohoSalesiqDSN
  8. Then simply select the Get Feedbacks endpoint (action).
    Get Feedbacks
    Ratings
    OperatorIds
    DepartmentIds
    AppIds
    StartTime
    EndTime
    TimezoneOffset
    VisitorEmail
    PageSize 99
    PagingIncrementBy
    NextUrlEndIndicator regex=(^$)|false
    StopIndicatorAttributeOrExpr $.more_data_available
    PagingMode ByUrlParameter
    PagingByUrlAttributeName index
    PagingByUrlEndStrategy DetectBasedOnMultipleRules
    PagingEndRules <ArrayOfPagingEndRule><PagingEndRule><Mode>DetectBasedOnResponseStatusCode</Mode><StatusCode>204</StatusCode></PagingEndRule><PagingEndRule><Mode>DetectBasedOnResponseStatusCode</Mode><StatusCode>304</StatusCode></PagingEndRule><PagingEndRule><Mode>DetectBasedOnResponseStatusCode</Mode><Mode>DetectBasedOnRecordCount</Mode></PagingEndRule></ArrayOfPagingEndRule>
    SELECT * FROM Feedbacks
    ZohoSalesiqDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Zoho SalesIQ API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoho SalesIQ servers).
Zoho SalesIQ SQL query examples
Read feedbacks
Reads visitor feedback and ratings submitted after chat sessions. This data helps in evaluating operator performance and customer satisfaction.
The Feedbacks table contains ratings and comments provided by visitors.
Read feedbacks with manual pagination
Reads feedback records in batches to overcome API pagination limits. This example demonstrates how to retrieve data month-by-month and combine the results using UNION to get a complete dataset for a longer period.
This approach is necessary when the total number of records exceeds the API's single-request limit, ensuring all data is captured by iterating through date ranges.
SELECT * INTO #t1 FROM Feedbacks WITH(OperatorIds='81565000003048017', StartTime='2023-01-01', EndTime='2023-02-01');
SELECT * INTO #t2 FROM Feedbacks WITH(OperatorIds='81565000003048017', StartTime='2023-02-01', EndTime='2023-03-01');
SELECT * INTO #t3 FROM Feedbacks WITH(OperatorIds='81565000003048017', StartTime='2023-03-01', EndTime='2023-04-01');
SELECT * INTO #t4 FROM Feedbacks WITH(OperatorIds='81565000003048017', StartTime='2023-04-01', EndTime='2023-05-01');
SELECT * INTO #t5 FROM Feedbacks WITH(OperatorIds='81565000003048017', StartTime='2023-05-01', EndTime='2023-06-01');
SELECT * INTO #t6 FROM Feedbacks WITH(OperatorIds='81565000003048017', StartTime='2023-06-01', EndTime='2023-07-01');
SELECT * INTO #t7 FROM Feedbacks WITH(OperatorIds='81565000003048017', StartTime='2023-07-01', EndTime='2023-08-01');
SELECT * INTO #t8 FROM Feedbacks WITH(OperatorIds='81565000003048017', StartTime='2023-08-01', EndTime='2023-09-01');
SELECT * INTO #t9 FROM Feedbacks WITH(OperatorIds='81565000003048017', StartTime='2023-09-01', EndTime='2023-10-01');
SELECT * INTO #t10 FROM Feedbacks WITH(OperatorIds='81565000003048017', StartTime='2023-10-01', EndTime='2023-11-01');
SELECT * INTO #t11 FROM Feedbacks WITH(OperatorIds='81565000003048017', StartTime='2023-11-01', EndTime='2023-12-01');
SELECT * INTO #t12 FROM Feedbacks WITH(OperatorIds='81565000003048017', StartTime='2023-12-01', EndTime='2024-01-01');
SELECT * FROM #t1 UNION
SELECT * FROM #t2 UNION
SELECT * FROM #t3 UNION
SELECT * FROM #t4 UNION
SELECT * FROM #t5 UNION
SELECT * FROM #t6 UNION
SELECT * FROM #t7 UNION
SELECT * FROM #t8 UNION
SELECT * FROM #t9 UNION
SELECT * FROM #t10 UNION
SELECT * FROM #t11 UNION
SELECT * FROM #t12;
get_feedbacks endpoint belongs to Feedbacks table(s), and can therefore be used via those table(s).
Get feedbacks in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your ZohoSalesiqDSN DSN from the list.
Need another use case? Pick the next Zoho SalesIQ action in Alteryx below.
You now know how to get feedbacks in Alteryx without writing complex code. Zoho SalesIQ ODBC Driver handled pagination and authentication automatically.
