While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Zoho SalesIQ Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoho SalesIQ" from the list of Popular Connectors. If "Zoho SalesIQ" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ZohoSalesiqDSN
    Zoho SalesIQ
    • Configure the authentication in Zoho SalesIQ.
    Zoho SalesIQ authentication
    1. Go to Zoho API Console
    2. Click Add Client link
    7. Click CREATE.
    ZohoSalesiqDSN
    Zoho SalesIQ
    OAuth [OAuth]
    https://salesiq.zoho.com/api/v2/[$Compnay$]
    Company Screen Name for URL (e.g. mycompany)
    ClientId
    ClientSecret
    Permissions SalesIQ.operators.READ SalesIQ.conversations.READ SalesIQ.feedbacks.READ SalesIQ.departments.READ
    Find full details in the Zoho SalesIQ Connector authentication reference.
    ZappySys API Driver - Zoho SalesIQ
    Read and write Zoho SalesIQ data effortlessly. Integrate, manage, and automate chats and visits — almost no coding required.
    ZohoSalesiqDSN
    Url /something/123
    Filter
    Request Method POST
    IsMultiPart False
    Body {$rows$}
    JsonOutputFormat Multicontent
    DoNotOutputNullProperty False
    Batch Size (Default=1) 1
    Request Format Default
    Response Format Default
    Csv - Column Delimiter ,
    Csv - Row Delimiter {NEWLINE}
    Csv - Quote Around Value True
    Encoding
    CharacterSet
    Writer DateTime Format
    Csv - Has Header Row True
    Xml - ElementsToTreatAsArray
        "Url" = '/something/123',
        "RequestMethod" = 'POST'
    ZohoSalesiqDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Zoho SalesIQ API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoho SalesIQ servers).
Zoho SalesIQ SQL query examples
Make generic rest api request
  6. Once the ODBC window opens, click Connect Asset and select your ZohoSalesiqDSN DSN from the list.
Need another use case? Pick the next Zoho SalesIQ action in Alteryx below.
You now know how to make generic REST API request (bulk write) in Alteryx without writing complex code. Zoho SalesIQ ODBC Driver handled pagination and authentication automatically.
