When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoho SalesIQ" from the list of Popular Connectors. If "Zoho SalesIQ" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
ZohoSalesiqDSNZoho SalesIQ
- Configure the authentication in Zoho SalesIQ.
Zoho SalesIQ authentication
- Click Add Client link
- Click CREATE.
ZohoSalesiqDSNZoho SalesIQOAuth [OAuth]https://salesiq.zoho.com/api/v2/[$Compnay$]Optional Parameters Company Screen Name for URL (e.g. mycompany) ClientId ClientSecret Permissions SalesIQ.operators.READ SalesIQ.conversations.READ SalesIQ.feedbacks.READ SalesIQ.departments.READ AccountUrl https://accounts.zoho.com RedirectUrl https://zappysys.com/oauth RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Zoho SalesIQ Connector authentication reference. -
ZappySys API Driver - Zoho SalesIQRead and write Zoho SalesIQ data effortlessly. Integrate, manage, and automate chats and visits — almost no coding required.ZohoSalesiqDSN
Then simply select the Get Departments endpoint (action).
ZappySys API Driver - Zoho SalesIQRead and write Zoho SalesIQ data effortlessly. Integrate, manage, and automate chats and visits — almost no coding required.ZohoSalesiqDSNSELECT * FROM Departments
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Zoho SalesIQ API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoho SalesIQ servers).
Zoho SalesIQ SQL query examples
Read departments
Reads all departments configured in the Zoho SalesIQ account. This list includes department names, IDs, and status, which are essential for routing chats and organizing operators.
The Departments table allows you to view the organizational structure used for chat distribution.
get_departments endpoint belongs to
Departments
Get departments in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your ZohoSalesiqDSN DSN from the list.
Need another use case? Pick the next Zoho SalesIQ action in Alteryx below.
- Get Conversations
- Get Feedbacks
- Get Operators
You now know how to get departments in Alteryx without writing complex code. Zoho SalesIQ ODBC Driver handled pagination and authentication automatically.
