When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoho SalesIQ" from the list of Popular Connectors. If "Zoho SalesIQ" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
ZohoSalesiqDSNZoho SalesIQ
- Configure the authentication in Zoho SalesIQ.
Zoho SalesIQ authentication
- Click Add Client link
- Click CREATE.
ZohoSalesiqDSNZoho SalesIQOAuth [OAuth]https://salesiq.zoho.com/api/v2/[$Compnay$]Optional Parameters Company Screen Name for URL (e.g. mycompany) ClientId ClientSecret Permissions SalesIQ.operators.READ SalesIQ.conversations.READ SalesIQ.feedbacks.READ SalesIQ.departments.READ AccountUrl https://accounts.zoho.com RedirectUrl https://zappysys.com/oauth RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Zoho SalesIQ Connector authentication reference. -
ZappySys API Driver - Zoho SalesIQRead and write Zoho SalesIQ data effortlessly. Integrate, manage, and automate chats and visits — almost no coding required.ZohoSalesiqDSN
Then simply select the Get Conversations endpoint (action).
ZappySys API Driver - Zoho SalesIQRead and write Zoho SalesIQ data effortlessly. Integrate, manage, and automate chats and visits — almost no coding required.ZohoSalesiqDSNSELECT * FROM Conversations
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Zoho SalesIQ API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoho SalesIQ servers).
Zoho SalesIQ SQL query examples
Read conversations
Reads all chat conversations between visitors and operators. This includes message content, timestamps, and visitor details for auditing and analysis.
Use the Conversations table to retrieve full chat transcripts and session metadata.
Read feedback summary by operator
Reads a summary of feedback ratings grouped by operator for the previous year. This aggregation is useful for performance reviews and identifying top-performing agents.
This query aggregates data from the Conversations table, grouping by OwnerEmail and RatingString to provide a count of each rating type per operator.
OwnerEmail,
OwnerId,
RatingString,
COUNT(Id) Total
FROM Conversations
GROUP BY OwnerEmail, OwnerId, RatingString
ORDER BY OwnerEmail, RatingString
WITH(
--OperatorIds='81565000003048017,81565000002408043' --You can supply Operator Ids to filter result for those Operators only
StartTime='yearstart-1y'
, EndTime='yearstart-1d'
get_conversations endpoint belongs to
Conversations
Get conversations in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your ZohoSalesiqDSN DSN from the list.
Need another use case? Pick the next Zoho SalesIQ action in Alteryx below.
- Get Departments
- Get Feedbacks
- Get Operators
You now know how to get conversations in Alteryx without writing complex code. Zoho SalesIQ ODBC Driver handled pagination and authentication automatically.
