While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the ManageEngine ServiceDesk Plus (Zoho) Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "ManageEngine ServiceDesk Plus (Zoho)" from the list of Popular Connectors. If "ManageEngine ServiceDesk Plus (Zoho)" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ManageengineServicedeskPlusZohoDSN
    • Configure the authentication in ManageEngine ServiceDesk Plus (Zoho).
    1. Go to Zoho API Console
    2. Click Add Client link
    7. Click CREATE.
    OAuth [OAuth]
    https://sdpondemand.manageengine.com/api/v3
    ClientId
    ClientSecret
    Permissions SDPOnDemand.requests.ALL
    Find full details in the ManageEngine ServiceDesk Plus (Zoho) Connector authentication reference.
    ZappySys API Driver - ManageEngine ServiceDesk Plus (Zoho)
    Read and write ServiceDesk Plus (Zoho) data effortlessly. Integrate, manage, and automate requests, tasks, comments, and worklogs — almost no coding required.
  8. Then simply select the Get Problem Task Comments endpoint (action).
    ProblemId Select the value from the dropdown
    TaskId Select the value from the dropdown
    ContineOn404Error True
    PagingMode ByUrlPath
    PagingByUrlAttributeName [$page$]
    RowsPerPage 100
    PagingIncrementBy
    NextUrlEndIndicator false
    StopIndicatorAttributeOrExpr $.list_info.has_more_rows
    SELECT * FROM get_problem_task_comments
    WHERE problem_id = 'abcd-1234-problemid'
    AND task_id = 'abcd-1234-taskid'
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the ManageEngine ServiceDesk Plus (Zoho) API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in ManageEngine ServiceDesk Plus (Zoho) servers).
Get problem task comments
Get problem task comments in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your ManageengineServicedeskPlusZohoDSN DSN from the list.
You now know how to get problem task comments in Alteryx without writing complex code. ManageEngine ServiceDesk Plus (Zoho) ODBC Driver handled pagination and authentication automatically.
