- Click Add Client link
- Click CREATE.
Then simply select the Get Problem Tasks endpoint (action).
ZappySys API Driver - ManageEngine ServiceDesk Plus (Zoho)Read and write ServiceDesk Plus (Zoho) data effortlessly. Integrate, manage, and automate requests, tasks, comments, and worklogs — almost no coding required.ManageengineServicedeskPlusZohoDSNSELECT * FROM get_problem_tasks WITH ( "ProblemId" = 'abcd-1234-problemid' )
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the ManageEngine ServiceDesk Plus (Zoho) API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in ManageEngine ServiceDesk Plus (Zoho) servers).
Get problem tasks
Get problem tasks in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your ManageengineServicedeskPlusZohoDSN DSN from the list.
- Delete Request
- Get Asset Details
- Get Assets
- Get Change Details
- Get Change Note Details
- Get Change Notes
- Get Change Task Comments
- Get Change Task Details
- Get Change Task Worklogs
- Get Change Tasks
- Get Change Worklog Details
- Get Change Worklogs
- Get Changes
- Get Contract Details
- Get Contracts
- Get Problem Details
- Get Problem Note Details
- Get Problem Notes
- Get Problem Task Comment Details
- Get Problem Task Comments
- Get Problem Task Details
- Get Problem Task Worklogs
- Get Problem Worklog Details
- Get Problem Worklogs
- Get Problems
- Get Project Details
- Get Project Members
- Get Project Milestone Tasks
- Get Project Milestones
- Get Project Note Details
- Get Project Notes
- Get Project Task Comments
- Get Project Task Details
- Get Project Task Worklogs
- Get Project Tasks
- Get Project Worklog Details
- Get Project Worklogs
- Get Projects
- Get Purchase Order Details
- Get Purchase Orders
- Get Release Details
- Get Release Note Details
- Get Release Notes
- Get Release Task Comments
- Get Release Task Details
- Get Release Task Worklogs
- Get Release Tasks
- Get Release Worklog Details
- Get Release Worklogs
- Get Releases
- Get Request Details
- Get Request Note Details
- Get Request Notes
- Get Request Task Comments
- Get Request Task Details
- Get Request Task Worklogs
- Get Request Tasks
- Get Request Worklog Details
- Get Request Worklogs
- Get Requests
- Get Task Details
- Get Tasks
- Test Connection
You now know how to get problem tasks in Alteryx without writing complex code. ManageEngine ServiceDesk Plus (Zoho) ODBC Driver handled pagination and authentication automatically.
