Create data source using Zendesk ODBC Driver
Watch this quick walkthrough to see how to configure your Zendesk ODBC data source, or scroll down for the step-by-step written guide.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Zendesk Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Zendesk" from the list of Popular Connectors. If "Zendesk" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ZendeskDSN
    Zendesk
    • Configure the authentication in Zendesk.
    Zendesk authentication
    Recommended for unattended automation: This authentication method does not require an interactive user login and does not use a refresh token. When the access token expires, ZappySys automatically requests a new access token using the same Client ID and Client Secret.
    1. Sign in to Zendesk as an administrator.
    2. Go to Admin Center > Apps and integrations > APIs > Zendesk API.
    3. Open the OAuth Clients section and create an OAuth client.
    4. Configure the OAuth client as a Confidential client.
    5. Enter a unique Client ID.
    6. Copy the generated Client Secret and store it securely.
    7. Configure the permissions/scopes required by your integration.
    8. In the ZappySys connection, enter your Zendesk Sub Domain, Client ID, Client Secret, and desired Permissions.
    9. Click Test Connection.
    Security: Client Credentials should only be used in trusted server-side environments where the Client Secret can be stored securely. Do not expose the Client Secret in browser-side or client-side applications.
    The access token is associated with the Zendesk user linked to the OAuth client and inherits that user's permissions. For automated integrations, consider using a dedicated Zendesk service account with only the permissions required by the integration.
    No Redirect URL, browser login, authorization code, or refresh token is required for this authentication method.
    1. Set Authentication Type to OAuth - Client Credentials (Server-to-Server) [OAuth]
    ZendeskDSN
    Zendesk
    https://[$Domain$].zendesk.com/api/v2
    Sub Domain (e.g. mycompany) Fill-in the parameter...
    OAuth Client ID Fill-in the parameter...
    OAuth Client Secret Fill-in the parameter...
    Permissions Fill-in the parameter...
    Find full details in the Zendesk Connector authentication reference.
    OAuth - User Login (Interactive)
    4. Enter a unique Client ID.
    5. Copy the generated Client Secret and store it securely.
    6. Configure the following Redirect URL for the OAuth client:
      https://zappysys.com/oauth
    7. In the ZappySys connection, enter your Zendesk Sub Domain, Client ID, Client Secret, and desired Permissions.
    8. Start the authorization process and sign in to Zendesk when the browser opens.
    9. Approve access when prompted.
    10. Click Test Connection.
    Token renewal: Zendesk access tokens expire. ZappySys uses the OAuth refresh token to obtain new access tokens without requiring the user to sign in again. The latest refresh token must be stored securely because Zendesk rotates refresh tokens during renewal.
    If the refresh token expires, is revoked, or cannot be restored from the saved connection, the interactive Zendesk login process must be performed again.
    For unattended server-side integrations where you do not want to maintain a refresh token, consider OAuth - Client Credentials (Server-to-Server).
    1. Set Authentication Type to OAuth - User Login (Interactive) [OAuth]
    ZendeskDSN
    Zendesk
    RedirectUrl Fill-in the parameter...
    Token Authentication (Legacy)
    Deprecated by Zendesk: Zendesk is removing API token authentication. Existing API tokens are scheduled to stop working on April 30, 2027. For new integrations, use OAuth instead.
    3. Make sure Token access is enabled.
    4. Create or select an existing API token.
    5. Copy the generated token and store it securely.
    6. Enter your Zendesk Sub Domain.
    7. Enter your Zendesk User ID / Email.
    8. Paste the API token into the Token field.
    Migration: For unattended ETL, scheduled jobs, and server-side integrations, use OAuth - Client Credentials (Server-to-Server).
    1. Set Authentication Type to Token Authentication (Legacy) [Http]
    ZendeskDSN
    Zendesk
    UserId Fill-in the parameter...
    Basic Authentication (User ID + Password)
    Important: This method cannot be used when two-factor authentication (2FA) is enabled for the Zendesk user. Password access to the API must also be enabled in Zendesk.
    3. Make sure Password access is enabled.
    4. Enter your Zendesk Sub Domain. For example, if your Zendesk URL is: https://mycompany.zendesk.com, enter mycompany.
    5. Enter your Zendesk User ID / Email and Password.
    6. Click Test Connection.
    Recommendation: For new integrations, OAuth is preferred over storing a user's password. For unattended server-side integrations, consider OAuth - Client Credentials (Server-to-Server).
    1. Set Authentication Type to Basic Authentication (User ID + Password) [Http]
    ZendeskDSN
    Zendesk
    UserName (2FA Must be OFF) Fill-in the parameter...
    ZappySys API Driver - Zendesk
    Read and write Zendesk data effortlessly. Manage tickets, users, and organizations — almost no coding required.
    ZendeskDSN
  8. Then simply select the Delete Organization endpoint (action).
    Delete Organization
    Organization ID for Delete Select the value from the dropdown
    EnableArrayFlattening True
    ContineOn404Error True
    NextUrlAttributeOrExpr $.next_page
    MaxArrayItemsToFlatten 5
    Wait time after each request (in milliseconds) 0
    DELETE FROM Organizations Where id=21855694556443
    ZendeskDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Zendesk API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zendesk servers).
Zendesk SQL query examples
Delete an organization
Deletes an organization by its ID. This example demonstrates using the DELETE FROM statement with a WHERE clause specifying the organization ID.
delete_organization endpoint belongs to Organizations table(s), and can therefore be used via those table(s).
Delete organization in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your ZendeskDSN DSN from the list.
Zendesk Connector actions
Need another use case? Pick the next Zendesk action in Alteryx below.
You now know how to delete organization in Alteryx without writing complex code. Zendesk ODBC Driver handled pagination and authentication automatically.
