Create data source using Smartsheet ODBC Driver
Watch this quick walkthrough to see how to configure your Smartsheet ODBC data source, or scroll down for the step-by-step written guide.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Smartsheet Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Smartsheet" from the list of Popular Connectors. If "Smartsheet" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    SmartsheetDSN
    Smartsheet
    • Configure the authentication in Smartsheet.
    OAuth (Dynamic Token)
    Smartsheet authentication
    OAuth Walkthrough
    Apps connect to Smartsheet using OAuth 2.0 to authenticate and authorize users. If you are building an app, this documentation will walk you through the steps you need to authenticate your users. The Smartsheet SDKs contain APIs for OAuth 2.0.
    NOTE: For users of apps like AWS AppFabric, you will need a Tenant ID. You can find your Tenant ID in Admin Center under Security & Controls. There is a Smartsheet Tenant ID pane.
    First Steps
    Before you can start using OAuth 2.0 with your app, Smartsheet needs the following information:
    1. You must register with Smartsheet to get a developer account*. The developer account gives you access to "Developer Tools", which is where you manage your app.
    2. In "Developer Tools", complete any required fields in your developer profile.
    3. In "Developer Tools", register your app so Smartsheet can assign a client Id and a client secret to the app.
    4. Review the list of access scopes. You'll need to choose which ones your app needs to get to a user's Smartsheet data, and then ask the user to consent to that access.
    5. After you've worked through these steps, you'll be ready to implement the OAuth Flow.
    Open Developer Tools
    1. Log in to Smartsheet with your developer account.
    2. Click the "Account" button in the lower-left corner of your Smartsheet screen, and then click "Developer Tools".
    3. Do one of the following:
      • If you need to register an app, click "Create New App".
      • If you need to manage an app, click "view/edit" for the app.
    Register Your App Using Developer Tools
    2. Click the "Account" button in the upper-right corner of your Smartsheet screen, and then click "Developer Tools".
    3. In the "Create New App" form, provide the following information:
      • Name: the name the user sees to identify your app
      • Description: a brief description intended for the user
      • URL: the URL to launch your app, or the landing page if not a web app
      • Contact/support: support information for the user
      • Redirect URL: also known as a callback URL. The URL within your application that will receive the OAuth 2.0 credentials After you click "Save", Smartsheet assigns a client Id and secret to your app. Make a note of these Ids for the next steps; however, you can always look them up again in "Developer Tools".
    1. Set Authentication Type to OAuth (Dynamic Token) [OAuth]
    SmartsheetDSN
    Smartsheet
    https://api.smartsheet.com/2.0
    RetryStatusCodeList 429|503
    Find full details in the Smartsheet Connector authentication reference.
    Static Token
    Raw Token Requests
    If you want to get started quickly, or are developing a standalone application that can run with your credentials, follow these instructions:
    1. Click the "Account" button in the lower-left corner of the Smartsheet screen, and then click "Personal Settings".
    2. Click the "API Access" tab.
    3. Click the "Generate new access token" button to obtain an access token.
    The access token must be sent with every API call in an HTTP authorization header (except for therequests to Get Access Token or Refresh Access Token). Once you have an access token, include it in the Authorization header for every request you make:
    Authorization: Bearer JKlMNOpQ12RStUVwxYZAbcde3F5g6hijklM789
    The header name is Authorization and the value of the header is Bearer JKlMNOpQ12RStUVwxYZAbcde3F5g6hijklM789. Since the access token is being transmitted in clear text, all API calls are done over HTTPS.
    NOTE: A best practice is to use a shared account, such as ticket-processor@example.com, rather than your individual work account.
    1. Set Authentication Type to Static Token [Http]
    SmartsheetDSN
    Smartsheet
    Static Token [Http]
    Access Token Fill-in the parameter...
    ZappySys API Driver - Smartsheet
    Read and write Smartsheet data effortlessly. Integrate, manage, and automate sheets, rows, and reports — almost no coding required.
    SmartsheetDSN
    Url /something/123
    Filter
    Request Method POST
    IsMultiPart False
    Body {$rows$}
    JsonOutputFormat Multicontent
    DoNotOutputNullProperty False
    Batch Size (Default=1) 1
    Request Format Default
    Response Format Default
    Csv - Column Delimiter ,
    Csv - Row Delimiter {NEWLINE}
    Csv - Quote Around Value True
    Encoding
    CharacterSet
    Writer DateTime Format
    Csv - Has Header Row True
    Xml - ElementsToTreatAsArray
        "Url" = '/something/123',
        "RequestMethod" = 'POST'
    SmartsheetDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Smartsheet API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Smartsheet servers).
Smartsheet SQL query examples
Make generic rest api request
  6. Once the ODBC window opens, click Connect Asset and select your SmartsheetDSN DSN from the list.
Smartsheet Connector actions
Need another use case? Pick the next Smartsheet action in Alteryx below.
You now know how to make generic REST API request (bulk write) in Alteryx without writing complex code. Smartsheet ODBC Driver handled pagination and authentication automatically.
