Create data source using SharePoint Online ODBC Driver
Watch this quick walkthrough to see how to configure your SharePoint Online ODBC data source, or scroll down for the step-by-step written guide.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the SharePoint Online Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "SharePoint Online" from the list of Popular Connectors. If "SharePoint Online" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    SharepointOnlineDSN
    SharePoint Online
    • Configure the authentication in SharePoint Online.
    User Credentials
    SharePoint Online authentication
    WARNING: If you are planning to automate processes, we recommend that you use a Application Credentials authentication method. In case, you still need to use User Credentials, then make sure you use a system/generic account (e.g. automation@my-company.com). When you use a personal account which is tied to a specific employee profile and that employee leaves the company, the token may become invalid and any automated processes using that token will start to fail.
    1. Navigate to the Azure Portal and log in using your credentials.
    2. Access Microsoft Entra ID.
    3. Register a new application by going to App registrations and clicking on New registration button:
      Start new app registration in Microsoft Entra ID
      INFO: Find more information on how to register an application in Graph API reference.
    4. When configuration window opens, configure these fields:
      • Supported account type
        • Use Accounts in this organizational directory only, if you need access to data in your organization only.
      • Redirect URI:
        • Set the type to Public client/native (mobile & desktop).
        • Use https://zappysys.com/oauth as the URL.
      Register app in Microsoft Entra ID
    5. After registering the app, copy the Application (client) ID for later:
      Copy client ID of Microsoft Entra ID app
    6. Copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs to use later in the configuration:
      Copy Auth and Token URLs in Microsoft Entra ID app
    7. Now go to SSIS package or ODBC data source and use the copied values in User Credentials authentication configuration:
      • In the Authorization URL field paste the OAuth authorization endpoint (v2) URL value you copied in the previous step.
      • In the Token URL field paste the OAuth token endpoint (v2) URL value you copied in the previous step.
      • In the Client ID field paste the Application (client) ID value you copied in the previous step.
      • In the Scope field use the default or pick labeled permissions. Prefer User.Read, Files.Read, or Files.ReadWrite when you want lower-impact, user-consent-friendly access; add Sites.*.All / Files.*.All only when you need full site or file coverage (those often need an admin to approve the app for the organization).
        • offline_access
        • openid
        • profile
        • User.Read
        • Sites.ReadWrite.All
        • Files.ReadWrite.All
        Admin consent note:
        • Token generation can still ask for admin approval, even when delegated scopes are listed in API permissions.
        • A Global Administrator can allow user consent for selected low-impact delegated permissions.
        • Broad scopes such as Sites.Read.All, Sites.ReadWrite.All, Files.Read.All, and Files.ReadWrite.All may still require admin consent.
        Settings: User consent settings (Entra ID > Enterprise apps > Consent and permissions > User consent settings). Docs: configure user consent, recommended settings.
    8. Press Generate Token button to generate Access and Refresh Tokens.
    9. Optional step. Choose Default Site Id from the drop down menu.
    10. Click Test Connection to confirm the connection is working.
    11. Done! Now you are ready to use the API Connector!
    1. Set Authentication Type to User Credentials [OAuth]
    SharepointOnlineDSN
    SharePoint Online
    https://graph.microsoft.com/v1.0
    Authorization URL Fill-in the parameter...
    Token URL Fill-in the parameter...
    Application (client) ID Fill-in the parameter...
    Permissions (Scope) Fill-in the parameter...
    Return URL Fill-in the parameter...
    Default Site Id (select after pressing 'Generate Token') Fill-in the parameter...
    Client Secret
    Default Drive Id (select after pressing 'Generate Token')
    Login Prompt Option
    RetryStatusCodeList 429|503|423
    Search Option For Non-Indexed Fields (Default=Blank - Search Only Indexed)
    Extra Headers (e.g. Header1:AAA||Header2:BBB)
    IsAppCred 0
    Find full details in the SharePoint Online Connector authentication reference.
    Follow these simple steps to create Microsoft Entra ID application with application access permissions:
    • Create an OAuth app
    • Configure App Permissions
    • Grant granular permissions to the OAuth application (optional)
      This step allows to grant OAuth application granular permissions, i.e. access configured specific Sites, Lists, and List Items.
    Step-1: Create OAuth app
    3. Register a new application by going to App registrations and clicking on New registration button: Start new app registration in Microsoft Entra ID
        • e.g. select Accounts in this organizational directory only if you need access to data in your organization only.
      • Redirect URI:
        • Leave the URL field empty.
    6. Then copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs:
    7. Continue and create Client secret:
      Add Client secret for Microsoft Entra ID app
    8. Then copy the Client secret for later steps:
      Copy Client secret
    Step-2: Configure App Permissions
    1. Continue by adding permissions for the app by going to the API permissions section, and clicking on Add a permission:
      Start adding permissions to Microsoft Entra ID app
    2. Select Microsoft Graph:
      Select Graph API permissions for Microsoft Entra ID app
    3. Then choose Application permissions option:
      Select app permissions for Microsoft Entra ID app
    4. Continue by adding these Sites permissions (search for site):
      Enable only one of the site-wide Microsoft Graph application permissions that fits your scenario: Sites.Read.All (read all sites), Sites.ReadWrite.All (read/write all sites), or Sites.Selected (least privilege: only sites you explicitly grant). These levels overlap in purpose; do not select all of them because an illustrative screenshot may show several checkboxes. If you choose Sites.Selected, there is no Entra ID or SharePoint UI to pick individual sites—you must grant access per site (or list/item) using the PowerShell / Graph steps in Grant SharePoint permissions to the OAuth app (optional) below.
      Select SharePoint Online application scopes
      INFO: If you want to access specific lists or list items (table-level vs row-level security) rather than the full site, then add Lists.SelectedOperations.Selected or ListItems.SelectedOperations.Selected permissions , just like in the previous step (search for list).
      WARNING: If you add any of these permissions - Sites.Selected, Lists.SelectedOperations.Selected, or ListItems.SelectedOperations.Selected - you must grant the app the SharePoint permissions for the specific resource (e.g. a Site, a List, or a ListItem). Follow instructions in Grant SharePoint permissions to the OAuth app (optional) section on how to accomplish that.
    5. Finish by clicking Add permissions button:
      Add permissions to Microsoft Entra ID app
    6. Now it's time to Grant admin consent for your application:
      Grant admin consent for Microsoft Entra ID app
    7. Confirm all the permissions are granted:
      Admin consent granted successfully in Entra ID
    8. Now go to SSIS package or ODBC data source and use the copied values in Application Credentials authentication configuration:
      • In the Client Secret field paste the Client secret value you copied in the previous step.
      • Optional step. Choose Default Site Id from the drop down menu.
    9. Click Test Connection to confirm the connection is working.
    10. Done!
    Step-3 (optional): Grant SharePoint permissions to the OAuth app
    If you used Sites.Selected, Lists.SelectedOperations.Selected or ListItems.SelectedOperations.Selected permission in the previous section, you must grant the app the SharePoint permissions for the specific resource (e.g. a Site, a List, or a ListItem). You can do it using PowerShell or SharePoint admin center (obsolete method).
    Granting SharePoint permissions using PowerShell
    Unfortunately, there is no user interface available to control these permissions yet. For now, granting permissions has to be accomplished via Microsoft Graph API [Microsoft reference]:
    You must be the owner of the resource to grant permissions (i.e. belong to SharePoint owners group or be the owner of the Site or List).
    1. Open PowerShell (run as admin).
    2. Call the following PowerShell code to grant read and write permission for the app we created earlier (assuming Application (client) ID is 89ea5c94-aaaa-bbbb-cccc-3fa95f62b66e):
      ##### CONFIGURATION ############################################################################################
      # More info at:
      # - https://learn.microsoft.com/en-us/graph/permissions-selected-overview?tabs=powershell
      # - https://learn.microsoft.com/en-us/powershell/module/microsoft.graph.sites/?view=graph-powershell-1.0
      # Find SharePoint Site Id by following these steps:
      # - Login into SharePoint Online
      # - Open this URL https://{your-company}.sharepoint.com/_api/site in the browser
      #   NOTE: For a subsite use https://{your-company}.sharepoint.com/sites/{your-subsite}/_api/site
      # - Find 'Id' element in the response (e.g. <d:Id m:type="Edm.Guid">efcdd21a-aaaa-bbbb-cccc-5d8104d8b5e3</d:Id>)
      # - Copy the Site Id, i.e.: efcdd21a-aaaa-bbbb-cccc-5d8104d8b5e3
      # Set $siteId variable to the retrieved Site Id:
      $siteId="efcdd21a-aaaa-bbbb-cccc-5d8104d8b5e3"
      # Find your Application Id (i.e. Client Id) in the Azure Portal, in App Registrations page:
      # https://portal.azure.com/#view/Microsoft_AAD_RegisteredApps/ApplicationsListBlade
      $applicationId="89ea5c94-aaaa-bbbb-cccc-3fa95f62b66e"
      # Set one of app permissions: read, write, fullcontrol, owner ('write' includes 'read' permission)
      $appPermission="write"
      ##### SCRIPT ###################################################################################################
      # Step-1: Install 'Microsoft.Graph.Sites' module if it's not installed
      if (-not (Get-Module Microsoft.Graph.Sites -ListAvailable))
          Install-Module Microsoft.Graph.Sites
      # Step-2: Load module
      Import-Module Microsoft.Graph.Sites
      # Step-3: Login (use Azure admin or SharePoint owner account)
      DisConnect-MgGraph
      Connect-MgGraph
      # Step-4: Set parameters for API call (set permissions, Site ID and Application ID)
      $params = @{
      	roles = @($appPermission)
      	grantedTo = @{
      		application = @{id = $applicationId}
      # Step-5: Grant permissions
      New-MgSitePermission -SiteId $siteId -BodyParameter $params
      # Done!
      Write-Host "Granted SharePoint permissions to application '$applicationId' for site '$siteId'."
    3. That's it! Now you can use the connector.
    Granting SharePoint permissions using SharePoint admin center (obsolete method)
    If you used Site.Selected permission you can link it SharePoint site in SharePoint admin center [SharePoint reference]. Follow these simple steps to accomplish that:
    1. Log in to SharePoint admin center using this URL: (replace YOURCOMPANY with your company name):
      https://YOURCOMPANY-admin.sharepoint.com/_layouts/15/appinv.aspx
      INFO: To view all the registered apps in SharePoint, visit this page: https://YOURCOMPANY-admin.sharepoint.com/_layouts/15/appprincipals.aspx?Scope=Web.
    2. In the App Id field enter Application (client) ID you copied in the previous step.
    3. In the Permission Request XML field enter XML snippet which describes which SharePoint permissions you want to grant to the OAuth app, e.g.:
      <AppPermissionRequests AllowAppOnlyPolicy="true">
        <AppPermissionRequest Scope="http://sharepoint/content/tenant" Right="FullControl" />
      </AppPermissionRequests>
      INFO: This example gives app FullControl, but you can also grant it Read or Write permissions.
    4. Click Create to grant the permission to your OAuth app.
    5. That's it! Now you can use the connector.
    1. Set Authentication Type to Application Credentials [OAuth]
    SharepointOnlineDSN
    SharePoint Online
    Default Site Id Fill-in the parameter...
    Scope https://graph.microsoft.com/.default
    Default Drive Id
    IsAppCred 1
    Application Credentials with Certificate (Sign JWT with Private Key)
    • Create Public/Private Key Pair
    • Upload Public Key
    • Configure ZappySys Connection for Private Key use
    • Grant granular permissions (optional)
    5. After registering the app, copy the Application (client) ID for later: Copy client ID of Microsoft Entra ID app
    6. Then copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs: Copy Auth and Token URLs in Microsoft Entra ID app
    1. Continue by adding permissions for the app by going to the API permissions section, and clicking on Add a permission: Start adding permissions to Microsoft Entra ID app
    2. Select Microsoft Graph: Select Graph API permissions for Microsoft Entra ID app
    3. Then choose Application permissions option: Select app permissions for Microsoft Entra ID app
      Enable only one of the site-wide Microsoft Graph application permissions that fits your scenario: Sites.Read.All (read all sites), Sites.ReadWrite.All (read/write all sites), or Sites.Selected (least privilege: only sites you explicitly grant). These levels overlap in purpose; do not select all of them because an illustrative screenshot may show several checkboxes. If you choose Sites.Selected, there is no Entra ID or SharePoint UI to pick individual sites—you must grant access per site (or list/item) using the PowerShell / Graph steps in Step-6 (optional): Grant granular permissions to the OAuth app below.
      WARNING: If you add any of these permissions - Sites.Selected, Lists.SelectedOperations.Selected, or ListItems.SelectedOperations.Selected - you must grant the app the SharePoint permissions for the specific resource (e.g. a Site, a List, or a ListItem). Follow instructions in Step-6 (optional): Grant granular permissions to the OAuth app on how to accomplish that.
    5. Finish by clicking Add permissions button: Add permissions to Microsoft Entra ID app
    6. Now it's time to Grant admin consent for your application: Grant admin consent for Microsoft Entra ID app
    7. Confirm all the permissions are granted: Admin consent granted successfully in Entra ID
    Step-3: Generate a Self-Signed Certificate
    # Run this in PowerShell
    #Change .AddYears(1) to desired number. By default it expires certificate in one year as per below code.
    $cert = New-SelfSignedCertificate `
      -Subject "CN=MyClientAppCert" `
      -KeySpec Signature `
      -KeyExportPolicy Exportable `
      -KeyLength 2048 `
      -CertStoreLocation "Cert:\CurrentUser\My" `
      -KeyAlgorithm RSA `
      -HashAlgorithm SHA256 `
      -NotAfter (Get-Date).AddYears(1) `
      -Provider "Microsoft Enhanced RSA and AES Cryptographic Provider"
    # Export private key (.pfx)  - Keep this with you to make API calls (SECRET KEY - DONOT SHARE)
    $pfxPath = "$env:USERPROFILE\Desktop\private_key.pfx"
    $pwd = ConvertTo-SecureString -String "yourStrongPassword123" -Force -AsPlainText
    Export-PfxCertificate -Cert $cert -FilePath $pfxPath -Password $pwd
    # Export public certificate (.cer) - UPLOAD this to Azure Portal
    $cerPath = "$env:USERPROFILE\Desktop\public_key.cer"
    Export-Certificate -Cert $cert -FilePath $cerPath
    Step-4: Upload the Certificate (i.e. Public Key *.cer)
    Once we have certificate file generated.
    1. In your App Registration, go to Certificates & secrets
    2. Under Certificates, click Upload certificate
    3. Select the .cer file (public certificate) Upload public key (certificate file) for App-Credentials (JWT Auth)
    4. Click Select a file (Browse button)
    5. Select public key file (*.cer) from local machine and click OK to upload
    Step-5: Configure ZappySys Connection - Use private key (i.e. *.pfx or *.pem)
    Now its time to use certificate pfx file (private key) generated in the previous step (NOTE: PFX file contains both private key and public key).
    1. Go to SSIS package or ODBC data source and use the copied values in Application Credentials authentication configuration:
    2. Configure private key
      • go to Certificate Tab
      • Change Storage Mode to Disk File: *.pfx format (PKCS#12).
        NOTE: You can also use Stored In LocalMachine mode if PFX file already imported in the Local Certificate Storage Area - User Store OR Machine Store.
        If you used OpenSSL to generate key pair then use Disk File: *.pem format (PKCS#8 or PKCS#1) Mode for Cert Store Location.
      • Supply the key file path
      • Supply the certificate password (same password used in earlier PowerShell script)
    3. Now go back to General Tab, choose Default Site Id and Default Drive Id from the drop down menu.
    4. Click Test connection see everything is good
      # More info at:
      DisConnect-MgGraph
      Connect-MgGraph
      $params = @{
      	grantedTo = @{
      # Done!
    1. Set Authentication Type to Application Credentials with Certificate (Sign JWT with Private Key) [OAuth]
    SharepointOnlineDSN
    SharePoint Online
    Certificate: *** Configure [Client Certificate] Tab *** Fill-in the parameter...
    Default Drive Id
    IsAppCred 1
    ZappySys API Driver - SharePoint Online
    Read and write SharePoint Online data effortlessly. Integrate, manage, and automate sites, lists, document libraries, and files — almost no coding required.
    SharepointOnlineDSN
  8. Then simply select the List SharePoint System Lists endpoint (action).
    Site Id (Re-Select Drive Id after you change this)
    DataFormat OData
    Continue On 404 Error (When item not found)
    SELECT * FROM SystemLists
    SharepointOnlineDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the SharePoint Online API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in SharePoint Online servers).
SharePoint Online SQL query examples
Get SystemLists
list_system_lists endpoint belongs to SystemLists table(s), and can therefore be used via those table(s).
List SharePoint system lists in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your SharepointOnlineDSN DSN from the list.
SharePoint Online Connector actions
Need another use case? Pick the next SharePoint Online action in Alteryx below.
You now know how to list SharePoint system lists in Alteryx without writing complex code. SharePoint Online ODBC Driver handled pagination and authentication automatically.
