Create data source using Hubspot ODBC Driver
Watch this quick walkthrough to see how to configure your Hubspot ODBC data source, or scroll down for the step-by-step written guide.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Hubspot Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Hubspot" from the list of Popular Connectors. If "Hubspot" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    HubspotDSN
    Hubspot
    • Configure the authentication in Hubspot.
    Private app (Static Access Token)
    Hubspot authentication
    Private apps allow you to use HubSpot's APIs to access specific data from your HubSpot account. You can authorize what each private app can request or change in your account, which will generate an access token that's unique to your app. [API reference]
    Follow these instructions to create a Private app in HubSpot and configure HubSpot authentication in SSIS package or ODBC data source:
    1. First of all, go to HubSpot portal.
    2. Then click Data Management option on the left and then hit Integrations menu item: Go to integrations in HubSpot
    3. Move on by clicking Private Apps menu item and then click Create a private app button to create one: Create private app to get HubSpot data via REST API
    4. Then continue by following the instructions on HubSpot Docs.
    5. Once you create an app, go to SSIS package or ODBC data source and in Private App authentication set these parameters:
      • For AccessToken field use Access token value from the Private app configuration in HubSpot.
    6. Done! Now you are ready to use HubSpot Connector!
    1. Set Authentication Type to Private app (Static Access Token) [Http]
    HubspotDSN
    Hubspot
    https://api.hubapi.com
    AccessToken Fill-in the parameter...
    Find full details in the Hubspot Connector authentication reference.
    Public app
    In HubSpot, a public app is a type of integration that can be installed on customer accounts or listed on the App Marketplace. It requires authentication via OAuth. Once a user installs your app on their HubSpot account, you’ll be able to make API calls to that account using an OAuth access token. [API reference]
    Follow these instructions to create a Public app in HubSpot and configure HubSpot authentication in SSIS package or ODBC data source:
    1. First of all, if you don't have HubSpot Developer's account, register one.
    2. Go to HubSpot and select your Developer account.
    3. Click Apps on the left hand side and then click Create app button to create a Public app: Create public app to get HubSpot data via REST API
    4. Then continue by following the instructions in HubSpot Docs.
      NOTE: If you don't have a working Redirect URL, you can use https://zappysys.com/oauth (it's safe).
    5. Once you create an app, go to SSIS package or ODBC data source and in Public app authentication set these parameters (use values from your Public app configuration in HubSpot):
      • For ClientId field use Client ID value.
      • For ClientSecret field use Client secret value.
      • For Scope field use Scopes values, e.g.:
        accounting
        tickets
        files
        crm.lists.read
        crm.lists.write
        crm.objects.contacts.read
        crm.objects.contacts.write
        crm.schemas.contacts.read
        crm.objects.custom.read
        crm.objects.custom.write
        crm.schemas.custom.read
        crm.objects.companies.read
        crm.objects.companies.write
        crm.schemas.companies.read
        crm.objects.deals.read
        crm.objects.deals.write
        crm.schemas.deals.read
        crm.objects.quotes.read
        crm.objects.quotes.write
        crm.schemas.quotes.read
        crm.objects.line_items.read
        crm.objects.line_items.write
        crm.schemas.line_items.read
        NOTE: You can use other scopes too, but they must match the scopes defined in your Public app.
      • For ReturnUrl field use one of Redirect URLs.
    6. When you are done with that, click Generate Token button to generate Access and Refresh Tokens.
    7. Done! Now you are ready to use HubSpot Connector!
    1. Set Authentication Type to Public app [OAuth]
    HubspotDSN
    Hubspot
    Public app [OAuth]
    UseCustomApp Fill-in the parameter...
    Scope (Must Match with App Scopes) Fill-in the parameter...
    Client ID
    Client Secret
    ReturnUrl
    Authorization URL (leave blank for default)
    Token URL (leave blank for default)
    Developer API key (Deprecated)
    Deprecated authentication method. Use [Private app] instead. [API reference]
    Using HubSpot API key is deprecated method for authentication. Use Private app authentication instead. If you still need one, then follow these instructions to get HubSpot API key:
    • First of all, if you don't have HubSpot Developer's account, register one.
    • Go to HubSpot and select your Developer account.
    • Click Apps on the left hand side and then click Get HubSpot API key button to get one: Get HubSpot API key
    • When a popup appears, click Show Key button and then hit Copy button to copy API key: Use API key to read HubSpot data via REST API
    • Once copy the API key, go to SSIS package or ODBC data source and use it in API Key authentication configuration:
      • Paste it in ApiKey parameter field.
    • Done! Now you are ready to use HubSpot Connector!
    1. Set Authentication Type to Developer API key (Deprecated) [Http]
    HubspotDSN
    Hubspot
    ApiKey Fill-in the parameter...
    ZappySys API Driver - Hubspot
    Read and write HubSpot data effortlessly. Integrate, manage, and automate contacts, companies, deals, and tickets — almost no coding required.
    HubspotDSN
    Url /something/123
    Filter
    Request Method POST
    IsMultiPart False
    Body {$rows$}
    JsonOutputFormat Multicontent
    DoNotOutputNullProperty False
    Batch Size (Default=1) 1
    Request Format Default
    Response Format Default
    Csv - Column Delimiter ,
    Csv - Row Delimiter {NEWLINE}
    Csv - Quote Around Value True
    Encoding
    CharacterSet
    Writer DateTime Format
    Csv - Has Header Row True
    Xml - ElementsToTreatAsArray
        "Url" = '/something/123',
        "RequestMethod" = 'POST'
    HubspotDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Hubspot API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Hubspot servers).
Hubspot SQL query examples
Make generic rest api request
  6. Once the ODBC window opens, click Connect Asset and select your HubspotDSN DSN from the list.
Hubspot Connector actions
Need another use case? Pick the next Hubspot action in Alteryx below.
You now know how to make generic REST API request (bulk write) in Alteryx without writing complex code. Hubspot ODBC Driver handled pagination and authentication automatically.
