Create data source using Hubspot ODBC Driver
Watch this quick walkthrough to see how to configure your Hubspot ODBC data source, or scroll down for the step-by-step written guide.
When the Configuration window appears give your data source a name if you haven't done that already, then select "Hubspot" from the list of Popular Connectors. If "Hubspot" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
HubspotDSNHubspot
- Configure the authentication in Hubspot.
Private app (Static Access Token)
Hubspot authentication
Private apps allow you to use HubSpot's APIs to access specific data from your HubSpot account. You can authorize what each private app can request or change in your account, which will generate an access token that's unique to your app. [API reference]
Follow these instructions to create a Private app in HubSpot and configure HubSpot authentication in SSIS package or ODBC data source:
- First of all, go to HubSpot portal.
Then click Data Management option on the left
and then hit Integrations menu item:
Move on by clicking Private Apps menu item
and then click Create a private app button to create one:
- Then continue by following the instructions on HubSpot Docs.
Once you create an app, go to SSIS package or ODBC data source and in Private App authentication set these parameters:
- For AccessToken field use Access token value from the Private app configuration in HubSpot.
- Done! Now you are ready to use HubSpot Connector!
Private app (Static Access Token) [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
HubspotDSNHubspotPrivate app (Static Access Token) [Http]https://api.hubapi.comRequired Parameters AccessToken Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Hubspot Connector authentication reference.Public app
In HubSpot, a public app is a type of integration that can be installed on customer accounts or listed on the App Marketplace. It requires authentication via OAuth. Once a user installs your app on their HubSpot account, you’ll be able to make API calls to that account using an OAuth access token. [API reference]
Follow these instructions to create a Public app in HubSpot and configure HubSpot authentication in SSIS package or ODBC data source:
- First of all, if you don't have HubSpot Developer's account, register one.
- Go to HubSpot and select your Developer account.
Click Apps on the left hand side and then click Create app button to create a Public app:
Then continue by following the instructions in HubSpot Docs.
NOTE: If you don't have a working Redirect URL, you can use
https://zappysys.com/oauth(it's safe).- Once you create an app, go to SSIS package or ODBC data source and in Public app authentication set these parameters (use values from your Public app configuration in HubSpot):
- For ClientId field use Client ID value.
- For ClientSecret field use Client secret value.
For Scope field use Scopes values, e.g.:
accounting tickets files crm.lists.read crm.lists.write crm.objects.contacts.read crm.objects.contacts.write crm.schemas.contacts.read crm.objects.custom.read crm.objects.custom.write crm.schemas.custom.read crm.objects.companies.read crm.objects.companies.write crm.schemas.companies.read crm.objects.deals.read crm.objects.deals.write crm.schemas.deals.read crm.objects.quotes.read crm.objects.quotes.write crm.schemas.quotes.read crm.objects.line_items.read crm.objects.line_items.write crm.schemas.line_items.read
NOTE: You can use other scopes too, but they must match the scopes defined in your Public app.- For ReturnUrl field use one of Redirect URLs.
Public app [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
HubspotDSNHubspotPublic app [OAuth]https://api.hubapi.comRequired Parameters UseCustomApp Fill-in the parameter... Scope (Must Match with App Scopes) Fill-in the parameter... Optional Parameters Client ID Client Secret ReturnUrl Authorization URL (leave blank for default) Token URL (leave blank for default) RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Developer API key (Deprecated)
Deprecated authentication method. Use [Private app] instead. [API reference]
Using HubSpot API key is deprecated method for authentication. Use Private app authentication instead. If you still need one, then follow these instructions to get HubSpot API key:
Click Apps on the left hand side and then click Get HubSpot API key button to get one:
When a popup appears, click Show Key button and then hit Copy button to copy API key:
Once copy the API key, go to SSIS package or ODBC data source and use it in API Key authentication configuration:
- Paste it in ApiKey parameter field.
Developer API key (Deprecated) [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
HubspotDSNHubspotDeveloper API key (Deprecated) [Http]https://api.hubapi.comRequired Parameters ApiKey Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Hubspot Connector authentication reference. - Once you create an app, go to SSIS package or ODBC data source and in Public app authentication set these parameters (use values from your Public app configuration in HubSpot):
ZappySys API Driver - HubspotRead and write HubSpot data effortlessly. Integrate, manage, and automate contacts, companies, deals, and tickets — almost no coding required.HubspotDSN
Then simply select the Contacts table and Insert operation.
ZappySys API Driver - HubspotRead and write HubSpot data effortlessly. Integrate, manage, and automate contacts, companies, deals, and tickets — almost no coding required.HubspotDSNINSERT INTO Contacts(email, firstname, lastname, custom_checkbox, custom_date, custom_number) VALUES ('john.doe@abc.com', 'John', 'Doe', 'true', '2023-01-01', 100.55)
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Hubspot API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Hubspot servers).Let's not stop here and explore SQL query examples, including how to use them in Stored Procedures and Views (virtual tables) in the next steps.
Hubspot SQL query examples
Insert a contact
Creates a single contact with the given email, first name, last name, and optional custom properties. Column names must match the contact property internal names.
INSERT INTO Contacts(email, firstname, lastname, custom_checkbox, custom_date, custom_number) VALUES ('john.doe@abc.com', 'John', 'Doe', 'true', '2023-01-01', 100.55)Bulk create contacts using SQL Server data
Inserts multiple contacts by reading rows from a SQL Server database. Data is read from a SELECT statement (or stored procedure); column names or aliases must match the target contact properties (e.g.
firstname,lastname,email). The driver uses the HubSpot bulk API to send the data.INSERT INTO Contacts SOURCE ( 'MSSQL', 'Data Source=localhost;Initial Catalog=Test;Integrated Security=true', 'SELECT firstname, lastname, email FROM StagingContacts' )create_contactsendpoint belongs toContactstable(s), and can therefore be used via those table(s).Create SQL view in ODBC data source
Create contacts in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your HubspotDSN DSN from the list.
Hubspot Connector actions
Need another use case? Pick the next Hubspot action in Alteryx below.
- Archive Companies
- Archive Contacts
- Archive Deals
- Archive Line Items
- Archive Products
- Archive Quotes
- Archive Tickets
- Create Companies
- Create Deals
- Create Line Items
- Create Products
- Create Quotes
- Create Tickets
- Get Companies
- Get Company By ID
- Get Company Properties
- Get Contact By ID
- Get Contact Properties
- Get Contacts
- Get Deal By ID
- Get Deal Properties
- Get Deals
- Get Line Item By ID
- Get Line Item Properties
- Get Line Items
- Get Owners
- Get Product By ID
- Get Product Properties
- Get Products
- Get Quote By ID
- Get Quotes
- Get Quotes Properties
- Get Ticket By ID
- Get Tickets
- Get Tickets Properties
- Search Companies
- Search Contacts
- Search Deals
- Search LineItems
- Search Products
- Search Quotes
- Search Tickets
- Update Companies
- Update Contacts
- Update Deals
- Update Line items
- Update Products
- Update Quotes
- Update Tickets
- Upload File from Local Disk
You now know how to create contacts in Alteryx without writing complex code. Hubspot ODBC Driver handled pagination and authentication automatically.
Want more?Don't stop here. Discover more integrations.
Explore all Alteryx connectors
Explore all Hubspot integration scenarios
