Create data source using ElasticSearch ODBC Driver
Watch this quick walkthrough to see how to configure your ElasticSearch ODBC data source, or scroll down for the step-by-step written guide.
When the Configuration window appears give your data source a name if you haven't done that already, then select "ElasticSearch" from the list of Popular Connectors. If "ElasticSearch" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
ElasticsearchDSNElasticSearch
- Configure the authentication in ElasticSearch.
Basic Authentication (UserId/Password)
ElasticSearch authentication
Use HTTP Basic Authentication with any Elasticsearch-compatible cluster (self-hosted, Elastic Cloud, OpenSearch, or other managed hosts).
- Set Service URL to your cluster base URL (for example
https://your-host:9200or the HTTPS URL from your provider). - Enter User Name and Password for a user that can call the Elasticsearch REST API. Some managed hosts label these as Access Key / Access Secret — use those values in the same fields.
- If you use a self-signed certificate and see a trust error, set Ignore certificate related errors to True (only if you trust the server).
- Click Test connection.
Optional — Bonsai example: On Bonsai, open
https://app.bonsai.io/clusters/{your-instance-id}/tokens, copy Access Key and Access Secret into User Name and Password, then test. Sample data (if needed):https://{your-cluster-id}.apps.bonsaisearch.net/app/home#/tutorial_directory.API Connection Manager configuration
Basic Authentication (UserId/Password) [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
ElasticsearchDSNElasticSearchBasic Authentication (UserId/Password) [Http]http://localhost:9200Optional Parameters User Name (or Access Key) Password (or Access Secret) Ignore certificate related errors
Find full details in the ElasticSearch Connector authentication reference.Windows Authentication (No Password)
No instructions available.
Windows Authentication (No Password) [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
ElasticsearchDSNElasticSearchWindows Authentication (No Password) [Http]http://localhost:9200Optional Parameters Ignore certificate related errors
Find full details in the ElasticSearch Connector authentication reference. -
ZappySys API Driver - ElasticSearchRead and write Elasticsearch data effortlessly. Integrate, manage, and automate indexes and documents — almost no coding required.ElasticsearchDSN
Then simply select the Create Index endpoint (action).
ZappySys API Driver - ElasticSearchRead and write Elasticsearch data effortlessly. Integrate, manage, and automate indexes and documents — almost no coding required.ElasticsearchDSNSELECT * FROM create_index WITH(Name='my_new_index_name', ContineOnErrorForStatusCode=1)
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the ElasticSearch API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in ElasticSearch servers).
ElasticSearch SQL query examples
Create a new index
Creates a new index (similar to creating a table). Supply the index name in the WITH clause. To have the call fail if the index already exists, set ContineOnErrorForStatusCode=0.
Create index in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your ElasticsearchDSN DSN from the list.
ElasticSearch Connector actions
Need another use case? Pick the next ElasticSearch action in Alteryx below.
- Count documents
- Delete documents
- Delete Index
- Get document by ID from Index or Alias
- Get documents from Index or Alias
- Get Index or Alias metadata
- Insert documents
- List aliases
- List indexes
- Search / Query documents
- Update documents
- Upsert documents
You now know how to create index in Alteryx without writing complex code. ElasticSearch ODBC Driver handled pagination and authentication automatically.
