Create data source using ElasticSearch ODBC Driver
Watch this quick walkthrough to see how to configure your ElasticSearch ODBC data source, or scroll down for the step-by-step written guide.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the ElasticSearch Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "ElasticSearch" from the list of Popular Connectors. If "ElasticSearch" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ElasticsearchDSN
    ElasticSearch
    • Configure the authentication in ElasticSearch.
    Basic Authentication (UserId/Password)
    ElasticSearch authentication
    Use HTTP Basic Authentication with any Elasticsearch-compatible cluster (self-hosted, Elastic Cloud, OpenSearch, or other managed hosts).
    1. Set Service URL to your cluster base URL (for example https://your-host:9200 or the HTTPS URL from your provider).
    2. Enter User Name and Password for a user that can call the Elasticsearch REST API. Some managed hosts label these as Access Key / Access Secret — use those values in the same fields.
    3. If you use a self-signed certificate and see a trust error, set Ignore certificate related errors to True (only if you trust the server).
    4. Click Test connection.
    Optional — Bonsai example: On Bonsai, open https://app.bonsai.io/clusters/{your-instance-id}/tokens, copy Access Key and Access Secret into User Name and Password, then test. Sample data (if needed): https://{your-cluster-id}.apps.bonsaisearch.net/app/home#/tutorial_directory.
    1. Set Authentication Type to Basic Authentication (UserId/Password) [Http]
    ElasticsearchDSN
    ElasticSearch
    http://localhost:9200
    User Name (or Access Key)
    Password (or Access Secret)
    Find full details in the ElasticSearch Connector authentication reference.
    Windows Authentication (No Password)
    No instructions available.
    1. Set Authentication Type to Windows Authentication (No Password) [Http]
    ElasticsearchDSN
    ElasticSearch
    ZappySys API Driver - ElasticSearch
    Read and write Elasticsearch data effortlessly. Integrate, manage, and automate indexes and documents — almost no coding required.
    ElasticsearchDSN
  8. Then simply select the [Dynamic Table] table and Insert operation.
    [Dynamic Table]
    Insert
    Index Select the value from the dropdown
    Alias (Deprecated - Use Index instead)
    DoNotAddMultiContentSeparator True
    RowHeaderFooterContinueOnError True
    RowHeader
    DoNotIndentArray True
    INSERT INTO MyIndex([MyCol1], [MyCol2] ) VALUES (100, 'A1')
    ElasticsearchDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the ElasticSearch API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in ElasticSearch servers).
ElasticSearch SQL query examples
Insert documents into index with _id autogenerated
When you dont supply _id column value, ElasticSearch will generate it automatically for you.
Insert documents into index with your own _id
Inserts documents into index with _id column. _id is string datatype so can be
INSERT INTO MyIndex(_id, [MyCol1], [MyCol2] ) VALUES ('A1234', 100, 'A1')
Insert documents using nested attribute and raw fragments (JSON sub-documents, arrays)
This example produces JSON document like this {"_id": "some_auto_generated_id" , "Location": { "City" : "Atlanta" , "ZipCode" : "30060" },"ColorsArray ": ["Red", "Blue", "Green"],"SomeNestedDoc": { "Col1" : "aaa" , "Col2" : "bbb" , "Col2" : "ccc" }} . Notice that how Column name with Dot translated into nested Columns (i.e. City, ZipCode) and Prefix raw:: allowed to treat value as array or sub document.
INSERT INTO MyIndexName ([Location.City], [Location.ZipCode], [raw::ColorsArray], [raw::SomeNestedDoc] )
--raw JSON must be in one line
VALUES ('Atlanta', '30060', '["red","green","blue"]', '{"Col1":"aaa","Col2":"bbb","Col3":"ccc"}' )
Insert documents using various data types
This example shows how to insert values for different datatype fields. Some fields can accept value as Raw JSON (e.g. nested, object, geo_point, geo_shape). Object field type can also accept value by nested field (e.g. [object_field.field1] )
INSERT INTO my_index (
	binary_field,
	boolean_field,
	byte_field,
	date_field,
	double_field,
	float_field,
	geo_point_field,  --raw
	--OR--
	--"geo_point_field.lat",
	--"geo_point_field.lon",
	geo_shape_field,  --raw
	--OR--
	--"geo_shape_field.type",
	--"geo_shape_field.coordinates",
	integer_field,
	ip_field,
	keyword_field,
	long_field,
	nested_field, --raw
	object_field, --raw
	--OR--
	--"object_field.field1",
	--"object_field.field2",
	short_field,
	text_field
VALUES(
	'SGVsbG8gd29ybGQ=', --binary_field  --base64 value of "Hello world"
	false, --bool
	117, --byte_field
	'2012-12-31T23:59:59.123', --date_field
	1.123456789, --double_field
	1.123456789, --float_field
	'{ "lat": 40.7128, "lon": -74.0060 }', --geo_point_field
	--OR--
	-- 40.7128, -74.0060,
	'{ "type": "polygon", "coordinates": [[[-74.0060, 40.7128], [-73.9960, 40.7128], [-73.9960, 40.7028], [-74.0060, 40.7028], [-74.0060, 40.7128]]] }', --geo_shape_field
	--OR--
	--'polygon',
	--'[[[-74.0060, 40.7128], [-73.9960, 40.7128], [-73.9960, 40.7028], [-74.0060, 40.7028], [-74.0060, 40.7128]]]',
	123, --integer_field
	'127.0.0.1', --ip_field
	'thhi is text', --keyword_field
	1234567890, --long_field
	'[{"nested_property_1":"nested text 1", "nested_property_2":100}, {"nested_property_1":"nested text 2", "nested_property_2":101}]', --nested_field
	'{"field1":"A","field2":"B"}', --object_field (Raw Value)
	--OR--
	--'object field keyword 1', --object_field.field1
	--123,                       --object_field.field2
	1, --short_field
	'text field ' --text_field
Insert raw document (_rawdoc_ usage)
This example shows how to insert document(s) in a raw format. When you use column name _rawdoc_ then its treated as RAW body. Notice that we use @ before string literal in value. This allow to use escape sequence (in this case \n for new line).
INSERT INTO shop(_RAWDOC_)
VALUES(@'{"create":{"_index":"shop","_id":"1"}}\n{"name":"record-1","colors":["yellow","orange"]}\n{"create":{"_index":"shop","_id":"2"}}\n{"name":"record-2","colors":["red","blue"]}\n')
	binary_field,
	boolean_field,
	byte_field,
	date_field,
	double_field,
	float_field,
	--OR--
	--OR--
	integer_field,
	ip_field,
	keyword_field,
	long_field,
	nested_field, --raw
	object_field, --raw
	--OR--
	short_field,
	text_field
VALUES(
	false, --bool
	117, --byte_field
	--OR--
	--OR--
	--'polygon',
	--OR--
	1, --short_field
insert_documents endpoint belongs to [Dynamic Table] , [Dynamic Table] table(s), and can therefore be used via those table(s).
Insert documents in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your ElasticsearchDSN DSN from the list.
ElasticSearch Connector actions
Need another use case? Pick the next ElasticSearch action in Alteryx below.
You now know how to insert documents in Alteryx without writing complex code. ElasticSearch ODBC Driver handled pagination and authentication automatically.
