Create data source using Cosmos DB ODBC Driver
Watch this quick walkthrough to see how to configure your Cosmos DB ODBC data source, or scroll down for the step-by-step written guide.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Cosmos DB Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Cosmos DB" from the list of Popular Connectors. If "Cosmos DB" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    CosmosDbDSN
    Cosmos DB
    • Configure the authentication in Cosmos DB.
    API Key
    Cosmos DB authentication
    Connecting to your Azure Cosmos DB data requires you to authenticate your REST API access. Follow the instructions below:
    1. Go to your Azure portal homepage: https://portal.azure.com/.
    2. In the search bar at the top of the homepage, enter Azure Cosmos DB. In the dropdown that appears, select Azure Cosmos DB.
    3. Click on the name of the database account you want to connect to (also copy and paste the name of the database account for later use).
    4. On the next page where you can see all of the database account information, look along the left side and select Keys: Use API key to get Cosmos DB data via REST API in Azure
    5. On the Keys page, you will have two tabs: Read-write Keys and Read-only Keys. If you are going to write data to your database, you need to remain on the Read-write Keys tab. If you are only going to read data from your database, you should select the Read-only Keys tab.
    6. On the Keys page, copy the PRIMARY KEY value and paste it somewhere for later use (the SECONDARY KEY value may also be copied and used).
    7. Now go to SSIS package or ODBC data source and use this PRIMARY KEY in API Key authentication configuration.
    8. Enter the primary or secondary key you recorded in step 6 into the Primary or Secondary Key field.
    9. Then enter the database account you recorded in step 3 into the Database Account field.
    10. Next, enter or select the default database you want to connect to using the Default Database field.
    11. Continue by entering or selecting the default table (i.e. container/collection) you want to connect to using the Default Table (Container/Collection) field.
    12. Select the Test Connection button at the bottom of the window to verify proper connectivity with your Azure Cosmos DB account.
    13. If the connection test succeeds, select OK.
    14. Done! Now you are ready to use Cosmos DB Connector!
    1. Set Authentication Type to API Key [Http]
    CosmosDbDSN
    Cosmos DB
    API Key [Http]
    https://[$Account$].documents.azure.com
    Primary or Secondary Key Fill-in the parameter...
    Account Name (Case-Sensitive) Fill-in the parameter...
    Database Name (keep blank to use default) Case-Sensitive Fill-in the parameter...
    API Version Fill-in the parameter...
    Default Table (needed to invoke #DirectSQL)
    Find full details in the Cosmos DB Connector authentication reference.
    ZappySys API Driver - Cosmos DB
    Read and write Azure Cosmos DB data effortlessly. Query, integrate, and manage databases, containers, documents, and users — almost no coding required.
    CosmosDbDSN
  8. Then simply select the Create a document in the container endpoint (action).
    Table Name (Case-Sensitive) Select the value from the dropdown
    Document
    Partition Key Value (default is supplied Id)
    Enable Upsert Mode (update if document found)
    Read Document from File Path
    INSERT INTO TestContainer (PartitionKey, Document)
    VALUES(
    '["user2"]', --partition key value must match its attribute from document else it will throw error. In this example container PartitionKey is /id so we used its value. For multiple key use JSON array ["val1","val2"]
      "id": "user2",
      "name": "John Doe",
      "email": "jdoe@contoso.com",
      "phone": ["12345"],
      "level": "platinum"
    WITH(Upsert='true')
    CosmosDbDSN
    VALUES(
      "id": "user2",
      "name": "John Doe",
      "phone": ["12345"],
      "level": "platinum"
    WITH(Upsert='true')
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Cosmos DB API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Cosmos DB servers).
Cosmos DB SQL query examples
Create document with partition key
Inserts a new document into the container. If the container has a partition key, supply it in the PartitionKey column as a JSON array (e.g. ["user2"]). The value must match the document attribute used as the partition key. The Document column holds the full JSON body. Use the Upsert option in WITH to update if a document with the same id already exists.
VALUES(
  "id": "user2",
  "name": "John Doe",
  "phone": ["12345"],
  "level": "platinum"
WITH(Upsert='true')
Create document from file path
Inserts a document whose JSON body is read from a local file. The file path must start with the @ symbol (e.g. @c:\data\order.json). Set IsMultiPart=1 in WITH so the driver reads from disk. Partition key rules are the same as for inline document insert.
VALUES(
'@c:\data\order.json'   --path must start with @ symbol
WITH(Upsert='true', IsMultiPart=1)
Upsert document (insert or update if exists)
Inserts the document or updates it if a document with the same id already exists. Use the Upsert option in WITH on INSERT to enable upsert. Handy for sync or idempotent loads where you do not want to fail on duplicate id.
VALUES(
  "id": "user2",
  "name": "John Doe",
  "phone": ["12345"],
  "level": "platinum"
 WITH(Upsert='true')
create_document endpoint belongs to [Dynamic Table] table(s), and can therefore be used via those table(s).
Create a document in the container in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your CosmosDbDSN DSN from the list.
Cosmos DB Connector actions
Need another use case? Pick the next Cosmos DB action in Alteryx below.
You now know how to create a document in the container in Alteryx without writing complex code. Cosmos DB ODBC Driver handled pagination and authentication automatically.
