Create data source using Cosmos DB ODBC Driver
Watch this quick walkthrough to see how to configure your Cosmos DB ODBC data source, or scroll down for the step-by-step written guide.
When the Configuration window appears give your data source a name if you haven't done that already, then select "Cosmos DB" from the list of Popular Connectors. If "Cosmos DB" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
CosmosDbDSNCosmos DB
- Configure the authentication in Cosmos DB.
API Key
Cosmos DB authentication
Connecting to your Azure Cosmos DB data requires you to authenticate your REST API access. Follow the instructions below:- Go to your Azure portal homepage: https://portal.azure.com/.
- In the search bar at the top of the homepage, enter Azure Cosmos DB. In the dropdown that appears, select Azure Cosmos DB.
- Click on the name of the database account you want to connect to (also copy and paste the name of the database account for later use).
On the next page where you can see all of the database account information, look along the left side and select Keys:
- On the Keys page, you will have two tabs: Read-write Keys and Read-only Keys. If you are going to write data to your database, you need to remain on the Read-write Keys tab. If you are only going to read data from your database, you should select the Read-only Keys tab.
- On the Keys page, copy the PRIMARY KEY value and paste it somewhere for later use (the SECONDARY KEY value may also be copied and used).
- Now go to SSIS package or ODBC data source and use this PRIMARY KEY in API Key authentication configuration.
- Enter the primary or secondary key you recorded in step 6 into the Primary or Secondary Key field.
- Then enter the database account you recorded in step 3 into the Database Account field.
- Next, enter or select the default database you want to connect to using the Default Database field.
- Continue by entering or selecting the default table (i.e. container/collection) you want to connect to using the Default Table (Container/Collection) field.
- Select the Test Connection button at the bottom of the window to verify proper connectivity with your Azure Cosmos DB account.
- If the connection test succeeds, select OK.
- Done! Now you are ready to use Cosmos DB Connector!
API Key [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
CosmosDbDSNCosmos DBAPI Key [Http]https://[$Account$].documents.azure.comRequired Parameters Primary or Secondary Key Fill-in the parameter... Account Name (Case-Sensitive) Fill-in the parameter... Database Name (keep blank to use default) Case-Sensitive Fill-in the parameter... API Version Fill-in the parameter... Optional Parameters Default Table (needed to invoke #DirectSQL)
Find full details in the Cosmos DB Connector authentication reference. -
ZappySys API Driver - Cosmos DBRead and write Azure Cosmos DB data effortlessly. Query, integrate, and manage databases, containers, documents, and users — almost no coding required.CosmosDbDSN
Then simply select the Create Permission Token for a User (One Table) endpoint (action).
ZappySys API Driver - Cosmos DBRead and write Azure Cosmos DB data effortlessly. Query, integrate, and manage databases, containers, documents, and users — almost no coding required.CosmosDbDSNSELECT * FROM create_token WITH ( "PermissionName" = 'abcd-1234-permissionname', "User" = 'abcd-1234-user', "PermissionMode" = 'all', "Table" = 'abcd-1234-table' )
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Cosmos DB API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Cosmos DB servers).
Cosmos DB SQL query examples
Create permission token for a user
Create permission token for a user in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your CosmosDbDSN DSN from the list.
Cosmos DB Connector actions
Need another use case? Pick the next Cosmos DB action in Alteryx below.
- Create a document in the container
- Create User for Database
- Delete a Document by Id
- Get All Documents for a Table
- Get All Users for a Database
- Get Database Information by Id or Name
- Get Document by Id
- Get List of Databases
- Get List of Tables
- Get table information by Id or Name
- Get table partition key ranges
- Get User by Id or Name
- Query documents using Cosmos DB SQL query language
- Update Document in the Container
- Upsert a document in the container
You now know how to create permission token for a user (one table) in Alteryx without writing complex code. Cosmos DB ODBC Driver handled pagination and authentication automatically.
