Create data source using Amazon Ads ODBC Driver
Watch this quick walkthrough to see how to configure your Amazon Ads ODBC data source, or scroll down for the step-by-step written guide.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Amazon Ads Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Amazon Ads" from the list of Popular Connectors. If "Amazon Ads" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    AmazonAdsDSN
    Amazon Ads
    • Configure the authentication in Amazon Ads.
    OAuth Authentication
    Amazon Ads authentication
    Amazon OAuth Security Profile has be created in Amazon Developer portal. [API reference]
    1. Firstly, login into Amazon Developer portal in https://developer.amazon.com.
    2. Then click Sign in.
    3. If you don't have an account, press Create your Amazon Developer account button to create one.
    4. Once logged in, click on your profile icon on the right-top of the window and hit Settings:
      Amazon developer profile settings
    5. Then click Security Profiles and proceed with creating a new Security Profile:
      Create Amazon developer security profile
    6. After that, click Web Settings subtab, then hit Show Secret button to reveal the Client Secret (you will need it later), and click Edit to add a Redirect URL:
      Reveal client secret in Amazon developer security profile
    7. Continue by setting Allowed Return URLs (you can have your own or use https://zappysys.com/oauth):
      Set return URLs in Amazon developer security profile
    8. Done! Now you can use Client ID, Client Secret, and Redirect URL when configuring OAuth Authentication parameters:
      Use client ID and client secret to connect to REST API Amazon services
    1. Set Authentication Type to OAuth Authentication [OAuth]
    AmazonAdsDSN
    Amazon Ads
    https://advertising-api.amazon.com/v2
    AuthorizationUrl Fill-in the parameter...
    Profile (click 'Generate Token' before this) Fill-in the parameter...
    Find full details in the Amazon Ads Connector authentication reference.
    ZappySys API Driver - Amazon Ads
    Read and write Amazon Ads data effortlessly. Integrate, manage, and automate campaigns, ad groups, and performance metrics — almost no coding required.
    AmazonAdsDSN
  8. Then simply select the Test Connection endpoint (action).
    Test Connection
    This Endpoint has no parameters.
    SELECT * FROM test_connection
    AmazonAdsDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Amazon Ads API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Amazon Ads servers).
Amazon Ads SQL query examples
Test connection in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your AmazonAdsDSN DSN from the list.
Amazon Ads Connector actions
Need another use case? Pick the next Amazon Ads action in Alteryx below.
You now know how to test connection in Alteryx without writing complex code. Amazon Ads ODBC Driver handled pagination and authentication automatically.
