Create data source using Zoom ODBC Driver
Watch this quick walkthrough to see how to configure your Zoom ODBC data source, or scroll down for the step-by-step written guide.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Zoom Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoom" from the list of Popular Connectors. If "Zoom" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ZoomDSN
    Zoom
    • Configure the authentication in Zoom.
    User Credentials (Access Your Data)
    Zoom authentication
    OAuth App must be created under Admin Console > Channel > API > Settings. [API reference]
    Follow the steps below to create a Zoom OAuth app and obtain the required credentials (Client ID and Client Secret):
    1. Go to the Zoom App Marketplace and sign in with your Zoom account.
    2. From the top navigation bar, open the Develop dropdown and select Build App.
    3. In the What kind of app are you creating window, select General App, click the Create button.
    4. Enter a name for your app and select the app type.
      (E.g. Zoom-General App)
    5. Click Create to continue.
    6. In the Redirect URL for OAuth field, enter the following URI and add it to the allow list:
      https://zappysys.com/oauth/
    7. Copy your Client ID and Client Secret, then paste them into the ZappySys API Component/Driver UI under the required parameters.
    8. From the Scopes window, please add the appropriate Granular scopes. You can search for the scopes listed below and enable them as needed.
      Scope Levels:
      • User-Level: Grants access only to the authenticated user’s data. Suitable for apps where users connect with their own Zoom account.
      • Admin-Level: Grants access to data across all users in the account, provided the user has admin permissions. Best for organization-wide apps.
      • Master-Level: Grants access at the highest level, typically for apps that need full account control (including sub-accounts). Requires Master Account credentials.
      Recommended Scopes:
      User-Level
      • user:read:settings
      • meeting:read:list_meetings
      • meeting:read:meeting
      • meeting:read:list_registrants
      • meeting:read:past_meeting
      • meeting:read:list_registration_questions
      • webinar:read:list_webinars
      • webinar:read:webinar
      • webinar:read:list_registrants
      • report:read:user
      Admin-Level
      • user:read:settings:admin
      • user:write:user:admin
      • meeting:read:list_meetings:admin
      • meeting:read:meeting:admin
      • meeting:read:list_registrants:admin
      • meeting:read:past_meeting:admin
      • meeting:read:list_registration_questions:admin
      • user:read:list_users:admin
      • webinar:read:list_webinars:admin
      • webinar:read:webinar:admin
      • webinar:read:list_registrants:admin
      • report:read:user:admin
      Master-Level
      • user:read:settings:master
      • meeting:read:list_meetings:master
      • meeting:read:meeting:master
      • meeting:read:list_registrants:master
      • user:read:list_users:master
      • webinar:read:list_webinars:master
      • webinar:read:webinar:master
      • webinar:read:list_registrants:master
      • report:read:user:master
    9. That’s it! After adding the scopes, click Continue to complete the process.
    10. In the ZappySys API Component/Driver UI, enter your Zoom app Client ID and Client Secret, then click Generate Token to obtain the access tokens.
    11. You’re done!
    1. Set Authentication Type to User Credentials (Access Your Data) [OAuth]
    ZoomDSN
    Zoom
    https://api.zoom.us/v2
    Client Id Fill-in the parameter...
    Redirect Url Fill-in the parameter...
    Token Url Fill-in the parameter...
    Authorization Url Fill-in the parameter...
    Retry Mode RetryWhenStatusCodeMatch
    Retry Status Code 429
    Retry Count Max 5
    Retry Multiply Wait Time True
    Find full details in the Zoom Connector authentication reference.
    App Credentials (Access Account Level Data)
    Zoom authentication
    Server-to-Server OAuth authentication method that lets applications access the Zoom API directly without user login or consent, using a Client ID and Secret to generate short-lived tokens. [API reference]
    3. In the What kind of app are you creating window, select Server to Server OAuth App, click the Create button.
      (E.g. Basic OAuth App)
    6. Copy your Account ID, Client ID, and Client Secret, then paste them into the ZappySys API Component/Driver UI under the required parameters.
    7. In the Information window, enter the company name, developer name, and email address, then click Continue.
      Scope Levels:
      Recommended Scopes:
      Admin-Level
      Master-Level
    10. In the ZappySys API Component/Driver UI, enter your Zoom app Account ID, Client ID, and Client Secret, then click Test Connection.
    11. You’re done!
    1. Set Authentication Type to App Credentials (Access Account Level Data) [OAuth]
    ZoomDSN
    Zoom
    Account Id Fill-in the parameter...
    Retry Count Max 5
    User Credentials (Access Your Data) - With Legacy Scopes
    Zoom authentication
    Perform the following steps to get the Zoom OAuth credentials (i.e. Client ID and Client Secret)
    1. Go to Zoom Marketplace Portal and sign in there.
    2. Once you successfully login then select "Build App" option from Develop dropdown from top left on the page.
    3. Click on Create button of OAuth panel section of page.
    4. Enter the name for your application and choose app type (Recommneded "Account-Level App") option for your API
    5. Then proceed with clicking Create button.
    6. In Redirect URL for OAuth enter this https://zappysys.com/oauth/ as Redirect URI and add it to allow lists.
    7. Copy Client ID and Client Secret here and paste it into Connection Manager Required Paramters section in respective place holders
    8. Add appropiate scopes from the Scopes menu option to the right side of page for your API as below :
      NOTE: If you need to read/write data for all users (not just 'me') then add :admin suffix in the scope (e.g. meeting:read:admin)
      • meeting:read
      • meeting:write
      • user:read
      • user:write
      • user_info:read
      • meeting:read
      • chat_channel:read
      • chat_channel:write
      • chat_contact:read
      • chat_message:read
      • chat_message:write
      • contact:read
      • pac:read
      • pac:write
      • phone:read
      • phone:write
      • phone_call_control:read
      • phone_call_control:write
      • phone_call_log:read
      • phone_call_log:write
      • phone_e911:read
      • phone_recording:read
      • phone_recording:write
      • phone_sms:read
      • phone_sms:write
      • phone_voicemail:read
      • phone_voicemail:write
      • recording:read
      • recording:write
      • tsp:read
      • tsp:write
      • user:read
      • user:write
      • user_info:read
      • user_zak:read
      • webinar:read
      • webinar:write
      • report:read:user
    9. Click Generate Token button on Connection Manager UI to generate tokens.
    10. That's it!
    1. Set Authentication Type to User Credentials (Access Your Data) - With Legacy Scopes [OAuth]
    ZoomDSN
    Zoom
    RedirectUrl Fill-in the parameter...
    TokenUrl Fill-in the parameter...
    AuthorizationUrl Fill-in the parameter...
    Scope
    ZappySys API Driver - Zoom
    Read and write Zoom data effortlessly. Integrate, manage, and automate meetings, users, accounts, and invitations — almost no coding required.
    ZoomDSN
    Url /something/123
    Filter
    Request Method POST
    IsMultiPart False
    Body {$rows$}
    JsonOutputFormat Multicontent
    DoNotOutputNullProperty False
    Batch Size (Default=1) 1
    Request Format Default
    Response Format Default
    Csv - Column Delimiter ,
    Csv - Row Delimiter {NEWLINE}
    Csv - Quote Around Value True
    Encoding
    CharacterSet
    Writer DateTime Format
    Csv - Has Header Row True
    Xml - ElementsToTreatAsArray
        "Url" = '/something/123',
        "RequestMethod" = 'POST'
    ZoomDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Zoom API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoom servers).
Zoom SQL query examples
Make generic rest api request
  6. Once the ODBC window opens, click Connect Asset and select your ZoomDSN DSN from the list.
Zoom Connector actions
Need another use case? Pick the next Zoom action in Alteryx below.
You now know how to make generic REST API request (bulk write) in Alteryx without writing complex code. Zoom ODBC Driver handled pagination and authentication automatically.
