Create data source using Shopify ODBC Driver
Watch this quick walkthrough to see how to configure your Shopify ODBC data source, or scroll down for the step-by-step written guide.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Shopify Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Shopify" from the list of Popular Connectors. If "Shopify" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ShopifyDSN
    Shopify
    • Configure the authentication in Shopify.
    Shopify authentication
    Quick Setup Summary:
    • Log in to your Shopify Admin and click Settings (the gear icon in the bottom left).
    • Select Apps from the left-side settings menu.
    • Click the Develop apps button at the top right of the page.
    • Open your app (or create a new one) and configure the necessary Admin API access scopes.
    • Click Install app. Once installed, navigate to the API credentials tab.
    1. Visit https://accounts.shopify.com and log into your Shopify store account.
    2. After logging in, select the store you wish to connect to.
    3. Select Settings (gear icon in the lower-left corner) to launch the Settings screen.
    4. On the left menu panel, select Apps. (Note: Sales channels are now managed in a separate menu item).
    5. On the Apps page, select Develop apps (near the top right of the screen).
      Note: If this is your first time accessing this section, you may need to click "Allow custom app development" to proceed.
    6. On the App development screen, select Create an app.
    7. Give the app a name (e.g., "ZappySys Connector"), select the appropriate developer from the drop-down, and select Create app.
    8. Click Configure Admin API scopes.
    9. In the Admin API access scopes screen, select the checkboxes based on which features you plan to use:
      • For Customers: read_customers, write_customers
      • For Orders: read_orders, write_orders
      • For Products: read_products, write_products
      • For Inventory: read_inventory, write_inventory
      • For Locations: read_locations
      • For Payouts/Analytics: read_all_orders or read_analytics
    10. After selecting your scopes, click Save at the top or bottom of the page.
    11. Install the app by clicking the Install app button (upper-right corner). If prompted, confirm by selecting Install.
    1. Once the app is installed, you will be taken to the API credentials tab.
    2. Look for the Admin API access token section. Select Reveal token once to show the token (it starts with shpat_).
    3. IMPORTANT: Copy and save this token immediately in a secure location. You cannot view it again after leaving this page.
      Reveal Token Screenshot
    1. Open the ZappySys connector configuration screen.
    2. Enter Subdomain: Enter the unique subdomain of your Shopify store into the Subdomain parameter textbox.
      How to find your Subdomain:
      If you use a custom domain (e.g., www.my-store.com), you must still use your internal Shopify subdomain:
      • Method 1 (Admin URL): While logged into Shopify, check your browser address bar.
        • If the URL is admin.shopify.com/store/my-unique-slug, your subdomain is my-unique-slug.
        • If the URL is my-unique-slug.myshopify.com/admin, your subdomain is my-unique-slug.
      • Method 2 (Domains Setting): Go to Settings > Domains. Look for the "Primary domain for the online store" or the fallback domain ending in .myshopify.com. The part before the dots is your subdomain.
    3. Enter Access Token: Paste the shpat_xxx token you saved in Step 14 into the Admin API Access Token textbox.
      Tip: Click the ellipses (...) button inside the textbox to open a larger dialog for easier pasting.
    4. Click Test Connection to verify the settings.
    5. If the test is successful, click OK to save the configuration.
    1. Set Authentication Type to Admin Access Token (Custom App) [Http]
    ShopifyDSN
    Shopify
    https://[$Subdomain$].myshopify.com/admin/api/2026-10
    Sub-domain Fill-in the parameter...
    Admin API Access Token Fill-in the parameter...
    Find full details in the Shopify Connector authentication reference.
    OAuth Authorization Code Grant (3-legged) - RECOMMENDED
    1. Log in to the Shopify Dev Dashboard using your Partner account.
    2. Click Apps in the left menu, then click Create app.
    3. Select Start from Dev Dashboard (manual setup) and give your app a name.
    4. Step 1: Configure Scopes and URLs via "Versions"
      • Click the Versions tab at the top of the app screen.
      • Click Create version (or edit the Draft).
      • In the URLs section, enter https://zappysys.com/oauth into Allowed redirection URL(s).
      • Select your Admin API scopes based on which features you plan to use:
      • Click Release (top right). Note: Settings only become active once a version is Released.
    5. Step 2: Set Distribution Method
      • Click Distribution in the left-side menu.
      • Select Custom Distribution.
      • Enter your Shopify store URL (e.g., your-store.myshopify.com) and click Generate link.
      • Action Required: Copy the generated install link, open it in your browser, and follow the prompts to install/unlock the app for your store. You must complete this step before testing the connection in ZappySys.
    1. Click on Settings in the left-side navigation of your app.
    2. In the Client credentials section, copy the Client ID and Client Secret (click the eye icon to reveal).
    1. Open the ZappySys connector and select OAuth Authorization Code Grant (3-legged).
    2. Subdomain: Enter your store handle (the part before .myshopify.com).
    3. Client ID / Secret: Paste the credentials from Steps 6 and 7.
    4. Redirect URI: Enter https://zappysys.com/oauth.
    5. Click Test Connection. You will be prompted to authorize the app in your browser.
    Note on Tokens: Successful authorization generates an "Offline" Access Token (starting with shpca_). This token does not expire and does not require a refresh token.
    Troubleshooting: If you see "App no longer available," ensure you have completed the Distribution step and followed the Install Link in Step 5 to unlock the app for your store.
    1. Set Authentication Type to OAuth Authorization Code Grant (3-legged) - RECOMMENDED [OAuth]
    ShopifyDSN
    Shopify
    Redirect URI (***Must match App Settings***) Fill-in the parameter...
    ZappySys API Driver - Shopify
    Read and write Shopify data effortlessly. Integrate, manage, and automate customers, orders, products, and inventory — almost no coding required.
    ShopifyDSN
  8. Then simply select the Products table and Insert operation.
    Products
    Insert
    DoNotOutputEmptyNestedProperty True
    DoNotOutputEmptyArrayProperty True
    INSERT INTO Products
    	 Title
    	,Status
    	,BodyHtml
    	,UrlHandle
    	,Vendor
    	,ProductType
    	,Variants
    	,Options
    	,Tags
    	,Metafields
    	,Images
    VALUES
    ('Ice Cream'
    ,'draft'
    ,'<strong>Very yummy ice cream!</strong>'
    ,'ice-cream'
    ,'Burton'
    ,'Snowboard'
    	{"price":10.5, "option1":"Chocolate","option2":"Small","sku":"ICE-CHO-SML","inventory_quantity":100},
    	{"price":10.5, "option1":"Chocolate","option2":"Medium","sku":"ICE-CHO-MED","inventory_quantity":100},
    	{"price":11.5, "option1":"Vanilla","option2":"Small","sku":"ICE-VNL-MED","inventory_quantity":210}
    --you must set variants and use atlease one value from the below list in option1, option2 or option3 in any variant entry else it will fail.
    	{"name":"Color","values":["Chocolate","Vanilla"]},
    	{"name":"Size","values":["Small","Medium"]}
    ,'["Frozen","Seasonal","Dad''s Fav"]'
    --adding metadata (custom fields) - metadata fields must be created before setting it
    --below are 2 system fields for SEO Title / SEO Description (you dont need to create them unlike custom metadata). These values appears on SEO section
    	{"key":"title_tag","value":"Yum Ice Cream SEO Title", "namespace":"global","type":"single_line_text_field"},
    	{"key":"description_tag","value":"Yum Ice Cream SEO description", "namespace":"global","type":"single_line_text_field"}
    --first image becomes main image if you supply multiple images
    --upload multiple images from URL (set "src")
    	{"src":"https://zappysys.com/images/tech/google-analytics-logo.png"},
    	{"src":"https://zappysys.com/images/tech/web-api-logo.png"}
    --OR upload multiple local image files (set "attachment")
    --	 {"attachment":"<<c:\temp\icecream_1.png,FUN_FILE_BASE64ENC>>"},
    --	 {"attachment":"<<c:\temp\icecream_2.png,FUN_FILE_BASE64ENC>>"}
    ShopifyDSN
    	 Title
    	,Status
    	,BodyHtml
    	,UrlHandle
    	,Vendor
    	,ProductType
    	,Variants
    	,Options
    	,Tags
    	,Metafields
    	,Images
    VALUES
    ('Ice Cream'
    ,'draft'
    ,'ice-cream'
    ,'Burton'
    ,'Snowboard'
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Shopify API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Shopify servers).
Shopify SQL query examples
Create a product
Creates a new product in Shopify. You can specify various attributes such as Title, BodyHtml, Vendor, ProductType, Tags, and Images.
This example also demonstrates how to create variants and options simultaneously by supplying JSON arrays for the Variants and Options columns.
	 Title
	,Status
	,BodyHtml
	,UrlHandle
	,Vendor
	,ProductType
	,Variants
	,Options
	,Tags
	,Metafields
	,Images
VALUES
('Ice Cream'
,'draft'
,'ice-cream'
,'Burton'
,'Snowboard'
post_product endpoint belongs to Products table(s), and can therefore be used via those table(s).
Create a product in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your ShopifyDSN DSN from the list.
Shopify Connector actions
Need another use case? Pick the next Shopify action in Alteryx below.
You now know how to create a product in Alteryx without writing complex code. Shopify ODBC Driver handled pagination and authentication automatically.
