Create data source using Shopify ODBC Driver
Watch this quick walkthrough to see how to configure your Shopify ODBC data source, or scroll down for the step-by-step written guide.
When the Configuration window appears give your data source a name if you haven't done that already, then select "Shopify" from the list of Popular Connectors. If "Shopify" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
ShopifyDSNShopify
- Configure the authentication in Shopify.
Shopify authentication
Quick Setup Summary:
- Log in to your Shopify Admin and click Settings (the gear icon in the bottom left).
- Select Apps from the left-side settings menu.
- Click the Develop apps button at the top right of the page.
- Open your app (or create a new one) and configure the necessary Admin API access scopes.
- Click Install app. Once installed, navigate to the API credentials tab.
- Visit https://accounts.shopify.com and log into your Shopify store account.
- After logging in, select the store you wish to connect to.
- Select Settings (gear icon in the lower-left corner) to launch the Settings screen.
- On the left menu panel, select Apps. (Note: Sales channels are now managed in a separate menu item).
- On the Apps page, select Develop apps (near the top right of the screen).
Note: If this is your first time accessing this section, you may need to click "Allow custom app development" to proceed. - On the App development screen, select Create an app.
- Give the app a name (e.g., "ZappySys Connector"), select the appropriate developer from the drop-down, and select Create app.
- Click Configure Admin API scopes.
- In the Admin API access scopes screen, select the checkboxes based on which features you plan to use:
- For Customers:
read_customers,write_customers - For Orders:
read_orders,write_orders - For Products:
read_products,write_products - For Inventory:
read_inventory,write_inventory - For Locations:
read_locations - For Payouts/Analytics:
read_all_ordersorread_analytics
- For Customers:
- After selecting your scopes, click Save at the top or bottom of the page.
- Install the app by clicking the Install app button (upper-right corner). If prompted, confirm by selecting Install.
- Once the app is installed, you will be taken to the API credentials tab.
- Look for the Admin API access token section. Select Reveal token once to show the token (it starts with
shpat_). IMPORTANT: Copy and save this token immediately in a secure location. You cannot view it again after leaving this page.
- Open the ZappySys connector configuration screen.
- Enter Subdomain: Enter the unique subdomain of your Shopify store into the Subdomain parameter textbox.
How to find your Subdomain:
If you use a custom domain (e.g.,
www.my-store.com), you must still use your internal Shopify subdomain:- Method 1 (Admin URL): While logged into Shopify, check your browser address bar.
- If the URL is
admin.shopify.com/store/my-unique-slug, your subdomain is my-unique-slug. - If the URL is
my-unique-slug.myshopify.com/admin, your subdomain is my-unique-slug.
- If the URL is
- Method 2 (Domains Setting): Go to Settings > Domains. Look for the "Primary domain for the online store" or the fallback domain ending in
.myshopify.com. The part before the dots is your subdomain.
- Enter Access Token: Paste the
shpat_xxxtoken you saved in Step 14 into the Admin API Access Token textbox.
Tip: Click the ellipses (...) button inside the textbox to open a larger dialog for easier pasting. - Click Test Connection to verify the settings.
- If the test is successful, click OK to save the configuration.
Admin Access Token (Custom App) [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
ShopifyDSNShopifyAdmin Access Token (Custom App) [Http]https://[$Subdomain$].myshopify.com/admin/api/2026-10Required Parameters Sub-domain Fill-in the parameter... Admin API Access Token Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Shopify Connector authentication reference.OAuth Authorization Code Grant (3-legged) - RECOMMENDED
- Log in to the Shopify Dev Dashboard using your Partner account.
- Click Apps in the left menu, then click Create app.
- Select Start from Dev Dashboard (manual setup) and give your app a name.
- Step 1: Configure Scopes and URLs via "Versions"
- Click the Versions tab at the top of the app screen.
- Click Create version (or edit the Draft).
- In the URLs section, enter
https://zappysys.com/oauthinto Allowed redirection URL(s). - Select your Admin API scopes based on which features you plan to use:
- For Customers:
- For Customers:
- Click Release (top right). Note: Settings only become active once a version is Released.
- Step 2: Set Distribution Method
- Click Distribution in the left-side menu.
- Select Custom Distribution.
- Enter your Shopify store URL (e.g.,
your-store.myshopify.com) and click Generate link. - Action Required: Copy the generated install link, open it in your browser, and follow the prompts to install/unlock the app for your store. You must complete this step before testing the connection in ZappySys.
- Click on Settings in the left-side navigation of your app.
- In the Client credentials section, copy the Client ID and Client Secret (click the eye icon to reveal).
- Open the ZappySys connector and select OAuth Authorization Code Grant (3-legged).
- Subdomain: Enter your store handle (the part before
.myshopify.com). - Client ID / Secret: Paste the credentials from Steps 6 and 7.
- Redirect URI: Enter
https://zappysys.com/oauth. - Click Test Connection. You will be prompted to authorize the app in your browser.
Note on Tokens: Successful authorization generates an "Offline" Access Token (starting with
shpca_). This token does not expire and does not require a refresh token.Troubleshooting: If you see "App no longer available," ensure you have completed the Distribution step and followed the Install Link in Step 5 to unlock the app for your store.
OAuth Authorization Code Grant (3-legged) - RECOMMENDED [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
ShopifyDSNShopifyOAuth Authorization Code Grant (3-legged) - RECOMMENDED [OAuth]https://[$Subdomain$].myshopify.com/admin/api/2026-10Required Parameters Redirect URI (***Must match App Settings***) Fill-in the parameter...
Find full details in the Shopify Connector authentication reference. -
ZappySys API Driver - ShopifyRead and write Shopify data effortlessly. Integrate, manage, and automate customers, orders, products, and inventory — almost no coding required.ShopifyDSN
Then simply select the Customers table and Insert operation.
ZappySys API Driver - ShopifyRead and write Shopify data effortlessly. Integrate, manage, and automate customers, orders, products, and inventory — almost no coding required.ShopifyDSNINSERT INTO Customers (FirstName, LastName, Email, Phone, Password, PasswordConfirmation, SendWelcomeEmail, MultipassIdentifier, Note, Tags, TaxExempt, TaxExemptions, DefaultAddressFirstName, DefaultAddressLastName, DefaultAddressCompany, DefaultAddressLine1, DefaultAddressLine2, DefaultAddressCity, DefaultAddressProvince, DefaultAddressCountry, DefaultAddressZip, DefaultAddressPhone, DefaultAddressName, DefaultAddressProvinceCode, DefaultAddressCountryCode, DefaultAddressCountryName) VALUES ('John', 'Doe', 'john.doe@gmail.com', '7705553543', 'myNewP@ssword123', 'myNewP@ssword123', 1, null, 'This is a note on the customer account.', null, 0, null, 'John', 'Doe', 'John Doe Corp.', '123 Main Street', null, 'Atlanta', 'Georgia', 'United States', '30135', '7705553543', 'John Doe', 'GA', 'US', 'United States')
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Shopify API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Shopify servers).
Shopify SQL query examples
Create a customer
Creates a new customer record. You can specify details such as FirstName, LastName, Email, Phone, and address fields like DefaultAddressCity and DefaultAddressCountry.
VALUES
Create a customer using raw JSON body
Creates a customer by supplying the entire JSON body in the special _rawdoc_ column. This is useful for setting attributes or nested structures that are not mapped to specific input columns.
INSERT INTO Customers(_rawdoc_)
VALUES('{"customer":{"first_name":"John","last_name":"Doe","email":"a.doe@gmail.com","phone":"7705553111"}}')
Bulk create customers using SQL Server data
Bulk creates customers by reading data from an external SQL Server database using the SOURCE clause. The column names in the source query must match the input columns of the Customers table (e.g. FirstName, LastName, Email).
INSERT INTO Customers(FirstName, LastName, Email, Phone)
SOURCE('MSSQL'
,'Data Source=localhost;Initial Catalog=tempdb;Integrated Security=true'
,'select ''John'' as FirstName, ''Doe'' as LastName, ''a.doe@gmail.com'' as Email, ''7705553111'' as Phone'
Bulk create customers using raw JSON body from SQL Server
Bulk creates customers by reading raw JSON bodies from an external SQL Server database. The source query should return a column named _rawdoc_ containing the JSON for each customer.
SOURCE('MSSQL'
,'select ''{"customer":{"first_name":"Cust1","last_name":"Doe1","email":"a.doe@gmail.com","phone":"7705553111"}}'' as _rawdoc_
UNION
select ''{"customer":{"first_name":"Cust2","last_name":"Doe2","email":"b.doe@gmail.com","phone":"7705553222"}}'' as _rawdoc_
post_customer endpoint belongs to
Customers
Create a customer in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your ShopifyDSN DSN from the list.
Shopify Connector actions
Need another use case? Pick the next Shopify action in Alteryx below.
- Create a Location
- Create a Product
- Create a Product Variant
- Create an Order
- Delete a Customer
- Delete a Location
- Delete a product
- Delete a product variant
- Delete an Order
- Get Customer
- Get Customers
- Get Inventory Item
- Get Inventory Items
- Get Inventory Levels
- Get Location
- Get Locations
- Get Order
- Get Order Items
- Get Orders
- Get Orders Count
- Get Payouts
- Get Product
- Get Product Variants
- Get Products
- Get Products Count
- Insert Inventory Levels
- Update a Customer
- Update a Location
- Update a Product
- Update a Product Variant
- Update an Order
- Update Inventory Item
- Update Inventory Levels
You now know how to create a customer in Alteryx without writing complex code. Shopify ODBC Driver handled pagination and authentication automatically.
