Create data source using Power BI Service ODBC Driver
Watch this quick walkthrough to see how to configure your Power BI Service ODBC data source, or scroll down for the step-by-step written guide.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Power BI Service Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Power BI Service" from the list of Popular Connectors. If "Power BI Service" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    PowerBiServiceDSN
    Power BI Service
    • Configure the authentication in Power BI Service.
    User Credentials
    Power BI Service authentication
    WARNING: If you are planning to automate processes, we recommend that you use a Application Credentials authentication method. In case, you still need to use User Credentials, then make sure you use a system/generic account (e.g. automation@my-company.com). When you use a personal account which is tied to a specific employee profile and that employee leaves the company, the token may become invalid and any automated processes using that token will start to fail.
    1. Navigate to the Azure Portal and log in using your credentials.
    2. Access Microsoft Entra ID.
    3. Register a new application by going to App registrations and clicking on New registration button:
      Start new app registration in Microsoft Entra ID
      INFO: Find more information on how to register an application in Graph API reference.
    4. When configuration window opens, configure these fields:
      • Supported account type
        • Use Accounts in this organizational directory only, if you need access to data in your organization only.
      • Redirect URI:
        • Set the type to Public client/native (mobile & desktop).
        • Use https://zappysys.com/oauth as the URL.
      Register app in Microsoft Entra ID
    5. After registering the app, copy the Application (client) ID for later:
      Copy client ID of Microsoft Entra ID app
    6. Copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs to use later in the configuration:
      Copy Auth and Token URLs in Microsoft Entra ID app
    7. Now go to SSIS package or ODBC data source and use the copied values in User Credentials authentication configuration:
      • In the Authorization URL field paste the OAuth authorization endpoint (v2) URL value you copied in the previous step.
      • In the Token URL field paste the OAuth token endpoint (v2) URL value you copied in the previous step.
      • In the Client ID field paste the Application (client) ID value you copied in the previous step.
      • In the Scope field use the default value or select individual scopes, e.g.:
        • offline_access
        • https://analysis.windows.net/powerbi/api/Workspace.Read.All
        • https://analysis.windows.net/powerbi/api/Dataset.Read.All
        • https://analysis.windows.net/powerbi/api/Dataset.ReadWrite.All
        Admin consent note:
        • Token generation can still ask for admin approval, even when delegated scopes are listed in API permissions.
        • A Global Administrator can allow user consent for selected low-impact delegated permissions.
        • If tenant policy blocks user consent, an administrator must approve the requested delegated permissions.
        Settings: User consent settings (Entra ID > Enterprise apps > Consent and permissions > User consent settings). Docs: configure user consent, recommended settings.
    8. Press Generate Token button to generate Access and Refresh Tokens.
    9. Click Test Connection to confirm the connection is working.
    10. Optional step. Choose Default Workspace from the drop down menu.
    11. Choose Default Dataset from the drop down menu.
    12. Done! Now you are ready to use the API Connector!
    1. Set Authentication Type to User Credentials [OAuth]
    PowerBiServiceDSN
    Power BI Service
    https://api.powerbi.com/v1.0/myorg
    Authorization URL Fill-in the parameter...
    Token URL Fill-in the parameter...
    Application (client) ID Fill-in the parameter...
    Default Dataset (select after generating tokens) Fill-in the parameter...
    Client Secret
    Redirect URI (must match App Redirect URI)
    Default Workspace (Keep Empty for My Workspace - select after generating tokens)
    RetryStatusCodeList 429|503
    RetryCountMax 20
    RetryWaitTimeMs 1000
    Login options
    Find full details in the Power BI Service Connector authentication reference.
    ZappySys API Driver - Power BI Service
    Read and write Microsoft Power BI data effortlessly. Access, refresh, and manage datasets, reports, and dashboards — almost no coding required.
    PowerBiServiceDSN
    Url /something/123
    Filter
    Request Method POST
    IsMultiPart False
    Body {$rows$}
    JsonOutputFormat Multicontent
    DoNotOutputNullProperty False
    Batch Size (Default=1) 1
    Request Format Default
    Response Format Default
    Csv - Column Delimiter ,
    Csv - Row Delimiter {NEWLINE}
    Csv - Quote Around Value True
    Encoding
    CharacterSet
    Writer DateTime Format
    Csv - Has Header Row True
    Xml - ElementsToTreatAsArray
        "Url" = '/something/123',
        "RequestMethod" = 'POST'
    PowerBiServiceDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Power BI Service API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Power BI Service servers).
Power BI Service SQL query examples
Make generic rest api request
  6. Once the ODBC window opens, click Connect Asset and select your PowerBiServiceDSN DSN from the list.
Power BI Service Connector actions
Need another use case? Pick the next Power BI Service action in Alteryx below.
You now know how to make generic REST API request (bulk write) in Alteryx without writing complex code. Power BI Service ODBC Driver handled pagination and authentication automatically.
