Create data source using OData ODBC Driver
Watch this quick walkthrough to see how to configure your OData ODBC data source, or scroll down for the step-by-step written guide.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "OData" from the list of Popular Connectors. If "OData" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    OdataDSN
    OData
    • Configure the authentication in OData.
    No Authentication
    OData authentication
    No instructions available.
    1. Set Authentication Type to No Authentication [Http]
    OdataDSN
    OData
    https://services.odata.org/V3/Northwind/Northwind.svc
    IgnoreSSLCertificateErrors
    SslVersion
    Find full details in the OData Connector authentication reference.
    Windows Authentication
    1. Set Authentication Type to Windows Authentication [Http]
    OdataDSN
    OData
    There are no parameters to configure.
    Basic Authentication
    1. Set Authentication Type to Basic Authentication [Http]
    OdataDSN
    OData
    SslVersion
    NTLM Authentication
    1. Set Authentication Type to NTLM Authentication [Http]
    OdataDSN
    OData
    UserName (i.e. Domain\UserName) Fill-in the parameter...
    SslVersion
    Token Authentication
    1. Set Authentication Type to Token Authentication [Http]
    OdataDSN
    OData
    AuthScheme Bearer
    AuthHeader Authorization
    SslVersion
    OAuth Connection for OData API
    1. Set Authentication Type to OAuth Connection for OData API [OAuth]
    OdataDSN
    OData
    GrantType Default
    OAuthVersion Default
    ClientId
    ClientSecret
    UserName
    Password
    Scope
    AuthUrl https://some-domain.com/api/auth
    TokenUrl https://some-domain.com/api/token
    ReturnUrl https://zappysys.com/oauth
    ExtraAttributesForTokenRequest
    ExtraAttributesForAuthRequest
    DoNotIncludeCredentialsInHeader
    DoNotIncludeCredentialsInBody
    RenewBeforeSec
    ExtraHeaders (e.g. x-hdr1:AAA||x-hdr2:BBB)
    ContentType
    EnableCodeVerifier
    RemoveAuthHeader
    CustomAuthHeader
    CustomTokenPrefix
    SslVersion
    ZappySys API Driver - OData
    Read and write OData API data effortlessly. Query, integrate, and manage entities and feeds — almost no coding required.
    OdataDSN
    Url /something/123
    Filter
    Format json
    PageSize (Keep blank for default)
    Search Criteria
    Request Method POST
    IsMultiPart False
    Body {$rows$}
    JsonOutputFormat Multicontent
    DoNotOutputNullProperty False
    Batch Size (Default=1) 1
    Request Format Default
    Response Format Default
    Csv - Column Delimiter ,
    Csv - Row Delimiter {NEWLINE}
    Csv - Quote Around Value True
    Encoding
    CharacterSet
    Writer DateTime Format
    Csv - Has Header Row True
    Xml - ElementsToTreatAsArray
    DataFormat OData
        "Url" = '/something/123',
        "RequestMethod" = 'POST'
    OdataDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the OData API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in OData servers).
OData SQL query examples
Make generic rest api request
  6. Once the ODBC window opens, click Connect Asset and select your OdataDSN DSN from the list.
OData Connector actions
Need another use case? Pick the next OData action in Alteryx below.
You now know how to make generic REST API request (bulk write) in Alteryx without writing complex code. OData ODBC Driver handled pagination and authentication automatically.
