Create data source using OData ODBC Driver
Watch this quick walkthrough to see how to configure your OData ODBC data source, or scroll down for the step-by-step written guide.
When the Configuration window appears give your data source a name if you haven't done that already, then select "OData" from the list of Popular Connectors. If "OData" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
OdataDSNOData
- Configure the authentication in OData.
No Authentication
OData authentication
No instructions available.
No Authentication [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
OdataDSNODataNo Authentication [Http]https://services.odata.org/V3/Northwind/Northwind.svcOptional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True IgnoreSSLCertificateErrors SslVersion
Find full details in the OData Connector authentication reference.Windows Authentication
Windows Authentication [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
OdataDSNODataWindows Authentication [Http]https://services.odata.org/V3/Northwind/Northwind.svcThere are no parameters to configure.
Find full details in the OData Connector authentication reference.Basic Authentication
Basic Authentication [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
OdataDSNODataBasic Authentication [Http]https://services.odata.org/V3/Northwind/Northwind.svcRequired Parameters UserName Fill-in the parameter... Password Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True IgnoreSSLCertificateErrors SslVersion
Find full details in the OData Connector authentication reference.NTLM Authentication
NTLM Authentication [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
OdataDSNODataNTLM Authentication [Http]https://services.odata.org/V3/Northwind/Northwind.svcRequired Parameters UserName (i.e. Domain\UserName) Fill-in the parameter... Password Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True IgnoreSSLCertificateErrors SslVersion
Find full details in the OData Connector authentication reference.Token Authentication
Token Authentication [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
OdataDSNODataToken Authentication [Http]https://services.odata.org/V3/Northwind/Northwind.svcRequired Parameters Token Fill-in the parameter... Optional Parameters AuthScheme Bearer AuthHeader Authorization RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True IgnoreSSLCertificateErrors SslVersion
Find full details in the OData Connector authentication reference.OAuth Connection for OData API
OAuth Connection for OData API [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
OdataDSNODataOAuth Connection for OData API [OAuth]https://services.odata.org/V3/Northwind/Northwind.svcOptional Parameters GrantType Default OAuthVersion Default ClientId ClientSecret UserName Password Scope AuthUrl https://some-domain.com/api/auth TokenUrl https://some-domain.com/api/token ReturnUrl https://zappysys.com/oauth ExtraAttributesForTokenRequest ExtraAttributesForAuthRequest DoNotIncludeCredentialsInHeader DoNotIncludeCredentialsInBody RenewBeforeSec ExtraHeaders (e.g. x-hdr1:AAA||x-hdr2:BBB) ContentType EnableCodeVerifier RemoveAuthHeader CustomAuthHeader CustomTokenPrefix RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True IgnoreSSLCertificateErrors SslVersion
Find full details in the OData Connector authentication reference. -
ZappySys API Driver - ODataRead and write OData API data effortlessly. Query, integrate, and manage entities and feeds — almost no coding required.OdataDSN
Then simply select the Generic Read Data (XML API) endpoint (action).
ZappySys API Driver - ODataRead and write OData API data effortlessly. Query, integrate, and manage entities and feeds — almost no coding required.OdataDSNSELECT * FROM read_data_xml WITH(TableName='MyTable')
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the OData API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in OData servers).
OData SQL query examples
Read all records from an XML OData service table
Gets all rows from a table when the service uses XML. Supply TableName in WITH to identify the entity set (e.g. MyTable).
Generic read data in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your OdataDSN DSN from the list.
OData Connector actions
Need another use case? Pick the next OData action in Alteryx below.
- Generic Read Data (JSON API)
- List Columns
- List Tables
- List Tables (JSON API)
- List Tables (XML API)
- Read [Dynamic Endpoint]
You now know how to generic read data (XML API) in Alteryx without writing complex code. OData ODBC Driver handled pagination and authentication automatically.
