When the Configuration window appears give your data source a name if you haven't done that already, then select "FastSpring" from the list of Popular Connectors. If "FastSpring" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
FastspringDSNFastSpring
- Configure the authentication in FastSpring.
API Credentials
FastSpring authentication
- In the FastSpring portal, navigate to Developer Tools > APIs > API Credentials.
Click Create, FastSpring will automatically generate your Username and Password.
Copy them, we will need them in the next step:
WARNING: Securely store the credentials for future reference. -
Now go to SSIS package or ODBC data source and use this token in API Credentials authentication configuration:
- In the UserName field paste the Username value you copied in the previous step.
- In the Password field paste the Password value you copied in the previous step.
- Done! Now you are ready to use FastSpring Connector!
API Credentials [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
FastspringDSNFastSpringAPI Credentials [Http]https://api.fastspring.comRequired Parameters UserName Fill-in the parameter... Password Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True Your Webstore URL (Only used by get_products_visibility endpoint) https://YOUR-STORE.onfastspring.com
Find full details in the FastSpring Connector authentication reference. -
ZappySys API Driver - FastSpringRead and write FastSpring data effortlessly. Integrate, manage, and automate orders, subscriptions, quotes, products, and accounts — almost no coding required.FastspringDSN
Then simply select the Products table and Insert, Upsert operation.
ZappySys API Driver - FastSpringRead and write FastSpring data effortlessly. Integrate, manage, and automate orders, subscriptions, quotes, products, and accounts — almost no coding required.FastspringDSN--Insert or Update --UPSERT INTO Products --Insert or Update UPSERT INTO Products ( [Id] , [Display] , [Summary] , [Description] , [Action] , [Format] , [Sku] , [TaxCode] , [Image] , [Renew] , [Interval] , [IntervalLength] , [IntervalCount] , [QuantityBehavior] , [QuantityDefault] , [PriceUSD] , [PriceEUR] , [PriceGBP] , [PriceCAD] , [PriceNZD] , [PriceCHF] , [PriceSEK] , [PriceCZK] , [PriceDKK] , [PricePLN] , [PriceSGD] , [PriceJPY] , [PriceCNY] , [PriceHKD] , [PriceINR] , [PriceBRL] , [PriceAUD] , [Trial] , [TrialPriceUSD] , [TrialPriceEUR] , [TrialPriceGBP] , [PaymentCollected] , [PaidTrial] , [FulfillmentInstructions] , [DateLimitsEnabled] , [CancellationInterval] , [CancellationIntervalLength] , [SetupFeeTitle] , [SetupFeePriceUSD] , [SetupFeePriceEUR] , [SetupFeePriceGBP] , [Badge] , [Rank] , [Attributes] ) VALUES('test-std-id' , '3Year **standard** subscription edition' , 'summary **standard edition** _some italic_ ' -- markdown syntax allowed , 'long description **test STD** and many more lines' --markdown syntax allowed , 'action text with **markdown** ' , 'digital' -- e.g. digital OR physical OR digital-and-physical , 'TEST-STD-001' , 'DC010500' , 'https://zappysys.com/api/images/ZappySys-icon.png' , true , 'year' , 1 , 1 , 'allow' -- e.g. allow Or lock Or hide , 3 --stop renewal after 3 periods , 10.12 , 11.12 , 12.12 , 13.12 , 14.12 , 15.12 , 16.12 , 17.12 , 18.12 , 19.12 , 20.12 , 21.12 , 22.12 , 23.12 , 24.12 , 25.12 , 26.12 , 14 --how many days trial allowed , 10.12 , 11.12 , 12.12 , 'true', true , 'Thank you for shopping, **here are** license instructions' --markdown supported , false, 'day', 5 , 'Setup title' --setup fees in common currencies , 10.50 , 11.50 , 12.50 , 'badge-1' , 1 , '{"mykey-1" : "some-value-1", "mykey-2" : "some-value-2"}' --JSON fragment --, '[... fullfillments.. ]' --JSON fragment )
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the FastSpring API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in FastSpring servers).
FastSpring SQL query examples
Create or update product (upsert)
Creates a new product or updates an existing one by ID (upsert). Use UPSERT INTO Products with the same columns as for insert or update. If the ID exists, the row is updated; otherwise a new product is created.
--Insert or Update
--Insert or Update
, [Trial]
, [SetupFeeTitle]
, [Badge] , [Rank]
, [Attributes]
, 'TEST-STD-001'
, 'DC010500'
, true , 'year' , 1
, 'true', true
, false, 'day', 5
, 'Setup title'
, 'badge-1' , 1
post_product endpoint belongs to
Products
Create product in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your FastspringDSN DSN from the list.
FastSpring Connector actions
- Get Account By Id
- Get Account Charges
- Get Account Charges by Id
- Get Account Orders (For a single account)
- Get Account Orders (For all accounts)
- Get Accounts
- Get Order by Id
- Get Order Items
- Get Order Items by OrderId
- Get Orders
- Get Product
- Get Product IDs
- Get Product Prices
- Get Products
- Get Products Publish Status
- Get Quote By Id
- Get Quotes
- Get Revenue Report
- Get Subscription By Id
- Get Subscription Report
- Get Subscriptions
- Get Subscriptions Ids
- Update Product
You now know how to create product in Alteryx without writing complex code. FastSpring ODBC Driver handled pagination and authentication automatically.
