While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the FastSpring Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "FastSpring" from the list of Popular Connectors. If "FastSpring" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    FastspringDSN
    FastSpring
    • Configure the authentication in FastSpring.
    API Credentials
    FastSpring authentication
    1. In the FastSpring portal, navigate to Developer Tools > APIs > API Credentials.
    2. Click Create, FastSpring will automatically generate your Username and Password. Copy them, we will need them in the next step: Use credentials to get FastSpring data via REST API
      WARNING: Securely store the credentials for future reference.
    3. Now go to SSIS package or ODBC data source and use this token in API Credentials authentication configuration:
      • In the UserName field paste the Username value you copied in the previous step.
      • In the Password field paste the Password value you copied in the previous step.
    4. Click Test Connection to confirm the connection is working.
    5. Done! Now you are ready to use FastSpring Connector!
    1. Set Authentication Type to API Credentials [Http]
    FastspringDSN
    FastSpring
    https://api.fastspring.com
    Your Webstore URL (Only used by get_products_visibility endpoint) https://YOUR-STORE.onfastspring.com
    Find full details in the FastSpring Connector authentication reference.
    ZappySys API Driver - FastSpring
    Read and write FastSpring data effortlessly. Integrate, manage, and automate orders, subscriptions, quotes, products, and accounts — almost no coding required.
    FastspringDSN
  8. Then simply select the Get Product Prices endpoint (action).
    Get Product Prices
    Country Code
    Currency Code
    PageSize 200
    EnablePivot True
    NextUrlAttributeOrExpr $.nextPage
    NextUrlEndIndicator regex=^$
    StopIndicatorAttributeOrExpr $.nextPage
    NextUrlSuffix page=<%nextlink%>
     Product,
     Country,
     Currency,
     Price,
     PriceDisplay,
     Discount2DiscountPercent,
     Discount2DiscountValue,
     Discount2DiscountValueDisplay,
     Discount2UnitPrice,
     Discount2UnitPriceDisplay,
     Discount3DiscountPercent,
     Discount3DiscountValue,
     Discount3DiscountValueDisplay,
     Discount3UnitPrice,
     Discount3UnitPriceDisplay,
     Discount4DiscountPercent,
     Discount4DiscountValue,
     Discount4DiscountValueDisplay,
     Discount4UnitPrice,
     Discount4UnitPriceDisplay,
     Discount5DiscountPercent,
     Discount5DiscountValue,
     Discount5DiscountValueDisplay,
     Discount5UnitPrice,
     Discount5UnitPriceDisplay,
     DiscountReasonEn,
     DiscountPeriodCount,
     AvailableStart,
     AvailableEnd,
     SetupFeePrice,
     SetupFeePriceDisplay,
     SetupFeeReasonEn
    FROM ProductPrices
    -- WITH (Country='US') -- get prices for a specific country
    -- WITH (Currency='USD') -- get prices for a specific currency
    FastspringDSN
     Product,
     Country,
     Currency,
     Price,
     PriceDisplay,
     Discount2UnitPrice,
     Discount3UnitPrice,
     Discount4UnitPrice,
     Discount5UnitPrice,
     DiscountReasonEn,
     AvailableStart,
     AvailableEnd,
     SetupFeePrice,
     SetupFeeReasonEn
    FROM ProductPrices
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the FastSpring API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in FastSpring servers).
FastSpring SQL query examples
Read product prices
Gets product prices per country or currency. Use the ProductPrices table. Optionally pass Country or Currency in the WITH clause to filter; if omitted, prices for all countries are returned.
 Product,
 Country,
 Currency,
 Price,
 PriceDisplay,
 Discount2UnitPrice,
 Discount3UnitPrice,
 Discount4UnitPrice,
 Discount5UnitPrice,
 DiscountReasonEn,
 AvailableStart,
 AvailableEnd,
 SetupFeePrice,
 SetupFeeReasonEn
FROM ProductPrices
get_product_prices endpoint belongs to ProductPrices table(s), and can therefore be used via those table(s).
Get product prices in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your FastspringDSN DSN from the list.
FastSpring Connector actions
You now know how to get product prices in Alteryx without writing complex code. FastSpring ODBC Driver handled pagination and authentication automatically.
