Create data source using Dropbox ODBC Driver
Watch this quick walkthrough to see how to configure your Dropbox ODBC data source, or scroll down for the step-by-step written guide.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Dropbox Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Dropbox" from the list of Popular Connectors. If "Dropbox" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    DropboxDSN
    Dropbox
    • Configure the authentication in Dropbox.
    User Account
    Dropbox authentication
    To use OAuth authentication, firstly, you need to create OAuth application:
    1. Log into your Dropbox account.
    2. Go to Dropbox My Apps.
    3. Then press Create app button to create a new app: My OAuth apps in Dropbox
    4. Once a new page opens, select Scoped access option: Create OAuth app to get Dropbox REST API data
    5. Next, select Full Dropbox to access all files and folders or App folder to access specific folder's files and folders option.
    6. Continue by giving your app a name.
    7. Then check I agree to Dropbox API Terms and Conditions checkbox.
    8. Click Create app button.
    9. Once a new page opens, click Enable additional teams and Enable additional users buttons: Configure OAuth app in Dropbox
    10. Then copy App key and App secret and copy paste them into your favorite text editor (you will need them later).
    11. Proceed by setting a Redirect URI and clicking Add button.
      NOTE: If you don't have a working Redirect URI, you can use https://zappysys.com/oauth (it's safe).
    12. Then click on Permissions tab and select application scopes: Set OAuth app permissions in Dropbox
    13. Select all Individual Scopes and Team Scopes if you want to manage team data.
    14. Click Submit button.
    15. Now go to SSIS package or ODBC data source and in User Account authentication set these parameters:
      1. For ClientId field use App key value.
      2. For ClientSecret field use App secret value.
      3. For ReturnUrl field use Redirect URI value.
    16. Done! Now you are ready to use Dropbox Connector!
    NOTE: If you are planning to use your current data connection/token for automated processes, we recommend that you use a generic account for token generation when the login box appears (e.g. sales_automation@mycompany.com instead of bob_smith@mycompany.com). When you use a personal account which is tied to a specific employee profile and that employee leaves the company, the token may become invalid and any automated processes using that token will fail. Another potentially unwanted effect of using a personal token is incorrect logging; the API calls (e.g. Read, Edit, Delete, Upload) made with that token will record the specific user as performing the calls instead of an automated process.
    1. Set Authentication Type to User Account [OAuth]
    DropboxDSN
    Dropbox
    https://api.dropboxapi.com/2/
    UseCustomApp Fill-in the parameter...
    ClientId
    ClientSecret
    Scope
    Find full details in the Dropbox Connector authentication reference.
    ZappySys API Driver - Dropbox
    Read and write Dropbox data effortlessly. Integrate, manage, and automate files and folders — almost no coding required.
    DropboxDSN
    Url /something/123
    Filter
    Request Method POST
    IsMultiPart False
    Body {$rows$}
    JsonOutputFormat Multicontent
    DoNotOutputNullProperty False
    Batch Size (Default=1) 1
    Request Format Default
    Response Format Default
    Csv - Column Delimiter ,
    Csv - Row Delimiter {NEWLINE}
    Csv - Quote Around Value True
    Encoding
    CharacterSet
    Writer DateTime Format
    Csv - Has Header Row True
    Xml - ElementsToTreatAsArray
        "Url" = '/something/123',
        "RequestMethod" = 'POST'
    DropboxDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Dropbox API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Dropbox servers).
Dropbox SQL query examples
Make generic rest api request
  6. Once the ODBC window opens, click Connect Asset and select your DropboxDSN DSN from the list.
Dropbox Connector actions
Need another use case? Pick the next Dropbox action in Alteryx below.
You now know how to make generic REST API request (bulk write) in Alteryx without writing complex code. Dropbox ODBC Driver handled pagination and authentication automatically.
