You can connect to your Zoho SalesIQ data from SAP Crystal Reports via the high-performance Zoho SalesIQ ODBC Driver. We'll walk you through the entire setup.
To get data from Zoho SalesIQ using SAP Crystal Reports, we first need to create an ODBC data source. We will later read this data in SAP Crystal Reports. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoho SalesIQ" from the list of Popular Connectors. If "Zoho SalesIQ" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
ZohoSalesiqDSNZoho SalesIQ
- Configure the authentication in Zoho SalesIQ.
Zoho SalesIQ authentication
- Click Add Client link
- Click CREATE.
ZohoSalesiqDSNZoho SalesIQOAuth [OAuth]https://salesiq.zoho.com/api/v2/[$Compnay$]Optional Parameters Company Screen Name for URL (e.g. mycompany) ClientId ClientSecret Permissions SalesIQ.operators.READ SalesIQ.conversations.READ SalesIQ.feedbacks.READ SalesIQ.departments.READ AccountUrl https://accounts.zoho.com RedirectUrl https://zappysys.com/oauth RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Zoho SalesIQ Connector authentication reference. -
ZappySys API Driver - Zoho SalesIQRead and write Zoho SalesIQ data effortlessly. Integrate, manage, and automate chats and visits — almost no coding required.ZohoSalesiqDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in SAP Crystal Reports to retrieve data from Zoho SalesIQ. Hit OK button to use this query in the next step.
SELECT * FROM Departments
Some parameters configured in this window will be passed to the Zoho SalesIQ API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
Now hit Preview Data button to preview the data using the generated SQL query. If you are satisfied with the result, use this query in SAP Crystal Reports:
ZappySys API Driver - Zoho SalesIQRead and write Zoho SalesIQ data effortlessly. Integrate, manage, and automate chats and visits — almost no coding required.ZohoSalesiqDSNSELECT * FROM Departments
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Zoho SalesIQ API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoho SalesIQ servers). -
Read data in SAP Crystal Reports from the ODBC data source
First of all, open SAP Crystal Reports and create the new Crystal Report.
And it will open the new data source selection window. Under ODBC(RDO) double click on the Make New Connection and Select the desired ODBC DSN, in our case we need to select ZohoSalesiqDSN which we created in upper section. And Click on Next.
ZohoSalesiqDSN
Expand the Connection and under the data select the desired table(s) or view(s) and click Add > button and click on Next.
ZohoSalesiqDSNZohoSalesiqDSN
Add the desired Fields to Display in the Reports. Here we are adding all fields and click on Finish.
That's it and you will be able to load the data in the Report.
Using ZappySys Driver Custom Views and Stored Procedure in SAP Crystal Report
You can create parameterized Stored Procedure and Virtual Tables on the same Data Source (ODBC DSN or Data Gateway Data Source). Please refer to this article for the same. You can create procedures to encapsulate custom logic and then only pass handful parameters rather than long SQL to execute your API call.Using Custom Views in the SAP Crystal Report
After establishing the connection with ZohoSalesiqDSN Data Source you can use the custom view in SQL Crystal Report.
Using Custom Stored Procedure in the SAP Crystal Report
First of all, create the custom stored procedure in the ZappySys Driver. Please refer to this article to create the custom stored procedure.
After establishing the connection with ZohoSalesiqDSN Data Source you can use the custom Stored Procedure in SQL Crystal Report. Same way you can write custom queries also in the query box.
ZohoSalesiqDSN
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Zoho SalesIQ operations directly in SAP Crystal Reports, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Get Feedbacks
- Get Conversations
- Get Operators
- Get Departments
In some situations, you may need to provide Zoho SalesIQ data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
To achieve this, you must first create a data source in the Data Gateway (server-side) and then create an ODBC data source in SAP Crystal Reports (client-side) to connect to it.
Create Zoho SalesIQ data source in the gateway
In this section we will create a data source for Zoho SalesIQ in the Data Gateway. Let's follow these steps to accomplish that:
ZohoSalesiqDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Zoho SalesIQ ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
ZohoSalesiqDSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - Zoho SalesIQRead and write Zoho SalesIQ data effortlessly. Integrate, manage, and automate chats and visits — almost no coding required.ZohoSalesiqDSN
In this part we will create an ODBC data source to connect to the ZappySys Data Gateway from SAP Crystal Reports. To achieve that, let's perform these steps:
ZohoSalesiqDSN(the one we used in the Data Gateway):ZohoSalesiqDSNZohoSalesiqDSN
Access data in SAP Crystal Reports via the gateway
Finally, we are ready to read data from Zoho SalesIQ in SAP Crystal Reports via the Data Gateway. Follow these final steps:
Go back to SAP Crystal Reports.
And it will open the new data source selection window. Under ODBC(RDO) double click on the Make New Connection and Select the desired ODBC DSN, in our case we need to select ZappySysGatewayDSN which we created in upper section. And Click on Next.
Now you can connect to Zoho SalesIQ data in SAP Crystal Reports via the ZappySys Data Gateway.
john and your password.
In this guide, we demonstrated how to connect to Zoho SalesIQ in SAP Crystal Reports and integrate your data — all without writing complex code.
