You can connect to your Jira data from SAP Crystal Reports via the high-performance Jira ODBC Driver. We'll walk you through the entire setup.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Jira Connector.
To get data from Jira using SAP Crystal Reports, we first need to create an ODBC data source. We will later read this data in SAP Crystal Reports. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Jira" from the list of Popular Connectors. If "Jira" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    JiraDSN
    Jira
    API Key based Authentication
    Jira authentication
    1. Go to Profile > Security.
    5. That's it!
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
      Name OAuth app in Atlassian
        • offline_access (a must)
        • read:jira-user
        • read:jira-work
        • write:jira-work
        • manage:jira-project
        • manage:jira-configuration
    JiraDSN
    Jira
    ZappySys API Driver - Jira
    JiraDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in SAP Crystal Reports to retrieve data from Jira. Hit OK button to use this query in the next step.
    SELECT * FROM Issues
    --//Query single issue by numeric Issue Id
    --SELECT * FROM Issues Where Id=101234
    --//Query issue by numeric Issue Ids (multiple)
    --SELECT * FROM Issues WITH(SearchBy='Key', Key='101234,101235,101236')
    --//Query issue by Issue Key(s) (alpha-numeric)
    --SELECT * FROM Issues WITH(SearchBy='Key', Key='PROJ-11')
    --SELECT * FROM Issues WITH(SearchBy='Key', Key='PROJ-11,PROJ-12,PROJ-13')
    --//Query issue by project(s)
    --SELECT * FROM Issues WITH(SearchBy='Project', Project='PROJ')
    --SELECT * FROM Issues WITH(SearchBy='Project', Project='PROJ,KAN,CS')
    --//Query issue by JQL expression
    --SELECT * FROM Issues WITH(SearchBy='Jql', Jql='status IN (Done, Closed) AND created > -5d' )
    Some parameters configured in this window will be passed to the Jira API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
  8. Now hit Preview Data button to preview the data using the generated SQL query. If you are satisfied with the result, use this query in SAP Crystal Reports:
    JiraDSN
Read data in SAP Crystal Reports from the ODBC data source
  1. First of all, open SAP Crystal Reports and create the new Crystal Report.
    Create New Crystal Report
  2. And it will open the new data source selection window. Under ODBC(RDO) double click on the Make New Connection and Select the desired ODBC DSN, in our case we need to select JiraDSN which we created in upper section. And Click on Next.
    JiraDSN
    SAP Crystal Report - Select ODBC JiraDSN DSN
  3. Expand the Connection and under the data select the desired table(s) or view(s) and click Add > button and click on Next. The list also shows the custom views (virtual tables, named vt__...) you created in the JiraDSN data source, so you can select a saved SQL query just like a table. To type a SQL query instead, double click Add Command under the connection.
    Tip: Save frequently used SQL queries as custom views on the Custom Objects tab of the JiraDSN data source. Each view appears here as a separate object, so one DSN can serve many API endpoints (e.g. /restaurants, /users) and every report reuses the same query instead of keeping its own Add Command SQL. See ODBC Drivers Custom Objects feature.
    JiraDSN
    JiraDSN
    SAP Crystal Report - Add ODBC JiraDSN DSN Tables
  4. Add the desired Fields to Display in the Reports. Here we are adding all fields and click on Finish.
    SAP Crystal Report - Add Display Fields
  5. That's it and you will be able to load the data in the Report.
    SAP Crystal Report - JiraDSN Data Output
Add JiraDSN data to an existing Crystal Report
The steps above use the new report wizard. To use the JiraDSN data source in a report you already have, add it with the Database Expert:
  1. Open the report and go to Database > Database Expert...
  2. Under Available Data Sources expand Create New Connection > ODBC (RDO), select the JiraDSN DSN, click Next and then Finish. If you used this DSN before, it is listed under My Connections instead.
  3. Expand the connection and select the table(s), custom view(s) (vt__...) or Add Command for a SQL query, then click the > button to move them to Selected Tables and click OK.
  4. If the report already has other tables, Crystal Reports opens the Links tab. Link the new object to the existing tables on a common column (or remove the suggested links if they are not related).
  5. Open View > Field Explorer, expand Database Fields and drag the new fields onto the report.
Point an existing table to the JiraDSN data source
To switch a table the report already uses (e.g. one from another DSN) to an object of JiraDSN without rebuilding the report, go to Database > Set Datasource Location..., select the table in Current Data Source, select the new table or custom view under the JiraDSN connection in Replace with and click Update. Then run Database > Verify Database to refresh the field list.
Tip: Prefer a custom view over a long Add Command query: the SQL lives in the DSN, so many reports can reuse it, and Set Datasource Location handles a view like a regular table (a command is harder to repoint). See ODBC Drivers Custom Objects feature.
Using ZappySys Driver Custom Views and Stored Procedure in SAP Crystal Report
You can create parameterized Stored Procedure and Virtual Tables on the same Data Source (ODBC DSN or Data Gateway Data Source). Please refer to this article for the same. You can create procedures to encapsulate custom logic and then only pass handful parameters rather than long SQL to execute your API call.
Using Custom Views in the SAP Crystal Report
After establishing the connection with JiraDSN Data Source you can use the custom view in SQL Crystal Report. Custom views are listed next to the regular tables, both in the new report wizard and in Database Expert of an existing report.
JiraDSN
JiraDSN
SAP Crystal Report - Custom Views
Using Custom Stored Procedure in the SAP Crystal Report
  1. First of all, create the custom stored procedure in the ZappySys Driver. Please refer to this article to create the custom stored procedure.
    ZappySys Driver Custom Stored Procedure
  2. After establishing the connection with JiraDSN Data Source you can use the custom Stored Procedure in SQL Crystal Report. Same way you can write custom queries also in the query box.
    JiraDSN
Jira Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Jira operations directly in SAP Crystal Reports, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide Jira data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
To achieve this, you must first create a data source in the Data Gateway (server-side) and then create an ODBC data source in SAP Crystal Reports (client-side) to connect to it.
Create Jira data source in the gateway
In this section we will create a data source for Jira in the Data Gateway. Let's follow these steps to accomplish that:
    JiraDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Jira ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      JiraDSN
      JiraDSN
      JiraDSN
In this part we will create an ODBC data source to connect to the ZappySys Data Gateway from SAP Crystal Reports. To achieve that, let's perform these steps:
  5. Then set the default database property to JiraDSN (the one we used in the Data Gateway):
    JiraDSN
    JiraDSN
Access data in SAP Crystal Reports via the gateway
Finally, we are ready to read data from Jira in SAP Crystal Reports via the Data Gateway. Follow these final steps:
  1. Go back to SAP Crystal Reports.
  2. First of all, open SAP Crystal Reports and create the new Crystal Report.
  3. And it will open the new data source selection window. Under ODBC(RDO) double click on the Make New Connection and Select the desired ODBC DSN, in our case we need to select ZappySysGatewayDSN which we created in upper section. And Click on Next.
    SAP Crystal Report - Select ODBC ZappySysGatewayDSN DSN
  4. Read the data the same way we discussed at the beginning of this article.
  5. That's it!
Now you can connect to Jira data in SAP Crystal Reports via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Jira in SAP Crystal Reports and integrate your data — all without writing complex code.
