You can connect to your Jira data from Excel via the high-performance Jira ODBC Driver. We'll walk you through the entire setup.
To get data from Jira using Excel, we first need to create an ODBC data source. We will later read this data in Excel. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already, then select "Jira" from the list of Popular Connectors. If "Jira" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
JiraDSNJira
- Configure the authentication in Jira.
API Key based Authentication
Jira authentication
Firstly, login into your Atlassian account and then go to your Jira profile:- Go to Profile > Security.
- Click Create and manage API tokens.
- Then click Create API token button and give your token a label.
- When window appears with new API token, copy and use it in this connection manager.
- That's it!
API Key based Authentication [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
JiraDSNJiraAPI Key based Authentication [Http]https://[$Subdomain$].atlassian.net/rest/api/3Required Parameters Subdomain Fill-in the parameter... Atlassian User Name (email) Fill-in the parameter... API Key Fill-in the parameter... Optional Parameters CustomColumnsRegex RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Jira Connector authentication reference.Personal Access Token (PAT) Authentication
Jira authentication
Follow official Atlassian instructions on how to create a PAT (Personal Access Token) for JIRAAPI Connection Manager configuration
Personal Access Token (PAT) Authentication [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
JiraDSNJiraPersonal Access Token (PAT) Authentication [Http]https://[$Subdomain$].atlassian.net/rest/api/3Required Parameters Subdomain Fill-in the parameter... Token (PAT Bearer Token) Fill-in the parameter... Optional Parameters CustomColumnsRegex RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Jira Connector authentication reference.OAuth (**Must change API Base URL to V3 OAuth**)
Jira authentication
Firstly, login into your Atlassian account and then create Jira application:- Go to Atlassian Developer area.
Click Create and select OAuth 2.0 integration item to create an OAuth app:
Give your app a name, accept the terms and hit Create:
To enable permissions/scopes for your application, click Permissions tab, then hit Add button, and click Configure button, once it appears:
Continue by hitting Edit Scopes button to assign scopes for the application:
Select these scopes or all of them:
Then click Authorization option on the left and click Add button:
Enter your own Callback URL (Redirect URL) or simply enter
https://zappysys.com/oauth, if you don't have one:
Then hit Settings option and copy Client ID and Secret into your favorite text editor (we will need them in the next step):
Now go to SSIS package or ODBC data source and in OAuth authentication set these parameters:
- For ClientId parameter use Client ID value from the previous steps.
- For ClientSecret parameter use Secret value from the previous steps.
- For Scope parameter use the Scopes you set previously (specify them all here):
- offline_access (a must)
- read:jira-user
- read:jira-work
- write:jira-work
- manage:jira-project
- manage:jira-configuration
NOTE: A full list of available scopes is available in Atlassian documentation. -
For Subdomain parameter use your Atlassian subdomain value
(e.g.
mycompany, if full host name ismycompany.atlassian.net).
- Click Generate Token to generate tokens.
- Finally, select Organization Id from the drop down.
- That's it! You can now use Jira Connector!
OAuth (**Must change API Base URL to V3 OAuth**) [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
JiraDSNJiraOAuth (**Must change API Base URL to V3 OAuth**) [OAuth]https://[$Subdomain$].atlassian.net/rest/api/3Required Parameters ClientId Fill-in the parameter... ClientSecret Fill-in the parameter... Scope Fill-in the parameter... ReturnUrl Fill-in the parameter... Organization Id (Select after clicking [Generate Token]) Fill-in the parameter... Optional Parameters Custom Columns for output (Select after clicking [Generate Token]) RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Jira Connector authentication reference. -
ZappySys API Driver - JiraRead and write Jira data effortlessly. Track, manage, and automate issues, projects, worklogs, and comments — almost no coding required.JiraDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Excel to retrieve data from Jira. Hit OK button to use this query in the next step.
SELECT * FROM Issues --//Query single issue by numeric Issue Id --SELECT * FROM Issues Where Id=101234 --//Query issue by numeric Issue Ids (multiple) --SELECT * FROM Issues WITH(SearchBy='Key', Key='101234,101235,101236') --//Query issue by Issue Key(s) (alpha-numeric) --SELECT * FROM Issues WITH(SearchBy='Key', Key='PROJ-11') --SELECT * FROM Issues WITH(SearchBy='Key', Key='PROJ-11,PROJ-12,PROJ-13') --//Query issue by project(s) --SELECT * FROM Issues WITH(SearchBy='Project', Project='PROJ') --SELECT * FROM Issues WITH(SearchBy='Project', Project='PROJ,KAN,CS') --//Query issue by JQL expression --SELECT * FROM Issues WITH(SearchBy='Jql', Jql='status IN (Done, Closed) AND created > -5d' )
Some parameters configured in this window will be passed to the Jira API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
Now hit Preview Data button to preview the data using the generated SQL query. If you are satisfied with the result, use this query in Excel:
ZappySys API Driver - JiraRead and write Jira data effortlessly. Track, manage, and automate issues, projects, worklogs, and comments — almost no coding required.JiraDSNSELECT * FROM Issues --//Query single issue by numeric Issue Id --SELECT * FROM Issues Where Id=101234 --//Query issue by numeric Issue Ids (multiple) --SELECT * FROM Issues WITH(SearchBy='Key', Key='101234,101235,101236') --//Query issue by Issue Key(s) (alpha-numeric) --SELECT * FROM Issues WITH(SearchBy='Key', Key='PROJ-11') --SELECT * FROM Issues WITH(SearchBy='Key', Key='PROJ-11,PROJ-12,PROJ-13') --//Query issue by project(s) --SELECT * FROM Issues WITH(SearchBy='Project', Project='PROJ') --SELECT * FROM Issues WITH(SearchBy='Project', Project='PROJ,KAN,CS') --//Query issue by JQL expression --SELECT * FROM Issues WITH(SearchBy='Jql', Jql='status IN (Done, Closed) AND created > -5d' )
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Jira API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Jira servers). -
Read data in Excel from the DSN
In Excel click Data, then select Get Data, proceed with From Other Sources and choose From ODBC item. This will get data from ODBC data source we created:
A small window opens, then simply select the data source you created in previous steps:
JiraDSN
JiraDSN
Finally, finally, use data extracted from Jira API in an Excel worksheet:
Refresh data source in Excel
When data updates in Jira, it is not automatically refreshed in Excel. To update the worksheet, go to Data or Table Design tab and click the Refresh button:
Jira Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Jira operations directly in Excel, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Read Resources
- Read Fields
- Read Custom Fields
- Read Issue Types
- Read Application Roles
- Read Groups
- Read Users
- Create User
- Delete User
- Read Projects
- Create Project
- Upsert Project
- Delete Project
- Read Issues
- Read Issue (By Id)
- Create Issues
- Update Issue
- Delete Issue
- Read Worklogs
- Read Worklogs modified after a specified date
- Create Worklog
- Update Worklog
- Delete Worklog
- Read Comments
- Create Issue Comment
- Update Issue Comment
- Delete Issue Comment
- Read Changelogs
- Read Changelog Details
- Read Changelogs by IDs
- Get custom field contexts
- Get custom field context options
In some situations, you may need to provide Jira data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
To achieve this, you must first create a data source in the Data Gateway (server-side) and then create an ODBC data source in Excel (client-side) to connect to it.
Create Jira data source in the gateway
In this section we will create a data source for Jira in the Data Gateway. Let's follow these steps to accomplish that:
JiraDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Jira ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
JiraDSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - JiraRead and write Jira data effortlessly. Track, manage, and automate issues, projects, worklogs, and comments — almost no coding required.JiraDSN
In this part we will create an ODBC data source to connect to the ZappySys Data Gateway from Excel. To achieve that, let's perform these steps:
JiraDSN(the one we used in the Data Gateway):JiraDSNJiraDSN
Access data in Excel via the gateway
Finally, we are ready to read data from Jira in Excel via the Data Gateway. Follow these final steps:
Go back to Excel.
Now you can connect to Jira data in Excel via the ZappySys Data Gateway.
john and your password.
In this guide, we demonstrated how to connect to Jira in Excel and integrate your data — all without writing complex code.
