You can connect to your Zoho SalesIQ data from Excel via the high-performance Zoho SalesIQ ODBC Driver. We'll walk you through the entire setup.
To get data from Zoho SalesIQ using Excel, we first need to create an ODBC data source. We will later read this data in Excel. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoho SalesIQ" from the list of Popular Connectors. If "Zoho SalesIQ" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
ZohoSalesiqDSNZoho SalesIQ
- Configure the authentication in Zoho SalesIQ.
Zoho SalesIQ authentication
- Click Add Client link
- Click CREATE.
ZohoSalesiqDSNZoho SalesIQOAuth [OAuth]https://salesiq.zoho.com/api/v2/[$Compnay$]Optional Parameters Company Screen Name for URL (e.g. mycompany) ClientId ClientSecret Permissions SalesIQ.operators.READ SalesIQ.conversations.READ SalesIQ.feedbacks.READ SalesIQ.departments.READ AccountUrl https://accounts.zoho.com RedirectUrl https://zappysys.com/oauth RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Zoho SalesIQ Connector authentication reference. -
ZappySys API Driver - Zoho SalesIQRead and write Zoho SalesIQ data effortlessly. Integrate, manage, and automate chats and visits — almost no coding required.ZohoSalesiqDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Excel to retrieve data from Zoho SalesIQ. Hit OK button to use this query in the next step.
SELECT * FROM Departments
Some parameters configured in this window will be passed to the Zoho SalesIQ API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
Now hit Preview Data button to preview the data using the generated SQL query. If you are satisfied with the result, use this query in Excel:
ZappySys API Driver - Zoho SalesIQRead and write Zoho SalesIQ data effortlessly. Integrate, manage, and automate chats and visits — almost no coding required.ZohoSalesiqDSNSELECT * FROM Departments
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Zoho SalesIQ API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoho SalesIQ servers). -
Read data in Excel from the DSN
In Excel click Data, then select Get Data, proceed with From Other Sources and choose From ODBC item. This will get data from ODBC data source we created:
A small window opens, then simply select the data source you created in previous steps:
ZohoSalesiqDSN
ZohoSalesiqDSN
Finally, finally, use data extracted from Zoho SalesIQ API in an Excel worksheet:
Refresh data source in Excel
When data updates in Zoho SalesIQ, it is not automatically refreshed in Excel. To update the worksheet, go to Data or Table Design tab and click the Refresh button:
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Zoho SalesIQ operations directly in Excel, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Get Feedbacks
- Get Conversations
- Get Operators
- Get Departments
In some situations, you may need to provide Zoho SalesIQ data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
To achieve this, you must first create a data source in the Data Gateway (server-side) and then create an ODBC data source in Excel (client-side) to connect to it.
Create Zoho SalesIQ data source in the gateway
In this section we will create a data source for Zoho SalesIQ in the Data Gateway. Let's follow these steps to accomplish that:
ZohoSalesiqDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Zoho SalesIQ ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
ZohoSalesiqDSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - Zoho SalesIQRead and write Zoho SalesIQ data effortlessly. Integrate, manage, and automate chats and visits — almost no coding required.ZohoSalesiqDSN
In this part we will create an ODBC data source to connect to the ZappySys Data Gateway from Excel. To achieve that, let's perform these steps:
ZohoSalesiqDSN(the one we used in the Data Gateway):ZohoSalesiqDSNZohoSalesiqDSN
Access data in Excel via the gateway
Finally, we are ready to read data from Zoho SalesIQ in Excel via the Data Gateway. Follow these final steps:
Go back to Excel.
Now you can connect to Zoho SalesIQ data in Excel via the ZappySys Data Gateway.
john and your password.
In this guide, we demonstrated how to connect to Zoho SalesIQ in Excel and integrate your data — all without writing complex code.
