Create data source using Nativo ODBC Driver
Watch this quick walkthrough to see how to configure your Nativo ODBC data source, or scroll down for the step-by-step written guide.
When the Configuration window appears give your data source a name if you haven't done that already, then select "Nativo" from the list of Popular Connectors. If "Nativo" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
NativoDSNNativo
- Configure the authentication in Nativo.
Http
Nativo authentication
Please refer to external API reference
Http [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
NativoDSNNativoHttp [Http]https://api.nativo.com/v2Optional Parameters Api Key Api Secret RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Nativo Connector authentication reference. -
ZappySys API Driver - NativoRead and write Nativo advertising data effortlessly. Integrate, manage, and automate campaigns and performance — almost no coding required.NativoDSN
Then simply select the Read Demand Campaign Data endpoint (action).
ZappySys API Driver - NativoRead and write Nativo advertising data effortlessly. Integrate, manage, and automate campaigns and performance — almost no coding required.NativoDSNSELECT * FROM get_demand_managed
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Nativo API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Nativo servers).
Nativo SQL query examples
Read demand campaign data
Read demand campaign data in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your NativoDSN DSN from the list.
Nativo Connector actions
Need another use case? Pick the next Nativo action in Alteryx below.
- Read Advertisers Data
- Read Auction Campaign Data
- Read Campaign Data
- Read DirectCampaign Data
- Read Inventory Campaign Data
- Read Managed Campaign Data
- Read Metrics
- Read Performance Campaign Data (Depriciated)
- Read Preferred Campaign Data
You now know how to read demand campaign data in Alteryx without writing complex code. Nativo ODBC Driver handled pagination and authentication automatically.
