Create data source using Nativo ODBC Driver
Watch this quick walkthrough to see how to configure your Nativo ODBC data source, or scroll down for the step-by-step written guide.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Nativo Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Nativo" from the list of Popular Connectors. If "Nativo" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    NativoDSN
    Nativo
    • Configure the authentication in Nativo.
    Http
    Nativo authentication
    Please refer to external API reference
    1. Set Authentication Type to Http [Http]
    NativoDSN
    Nativo
    Http [Http]
    https://api.nativo.com/v2
    Api Key
    Api Secret
    Find full details in the Nativo Connector authentication reference.
    ZappySys API Driver - Nativo
    Read and write Nativo advertising data effortlessly. Integrate, manage, and automate campaigns and performance — almost no coding required.
    NativoDSN
    Url /something/123
    Filter
    Request Method POST
    IsMultiPart False
    Body {$rows$}
    JsonOutputFormat Multicontent
    DoNotOutputNullProperty False
    Batch Size (Default=1) 1
    Request Format Default
    Response Format Default
    Csv - Column Delimiter ,
    Csv - Row Delimiter {NEWLINE}
    Csv - Quote Around Value True
    Encoding
    CharacterSet
    Writer DateTime Format
    Csv - Has Header Row True
    Xml - ElementsToTreatAsArray
    Pagination Mode ByUrlParameter
    Pagination URL Parameter page
        "Url" = '/something/123',
        "RequestMethod" = 'POST'
    NativoDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Nativo API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Nativo servers).
Nativo SQL query examples
Make generic rest api request
  6. Once the ODBC window opens, click Connect Asset and select your NativoDSN DSN from the list.
Nativo Connector actions
Need another use case? Pick the next Nativo action in Alteryx below.
You now know how to make generic REST API request (bulk write) in Alteryx without writing complex code. Nativo ODBC Driver handled pagination and authentication automatically.
