Create data source using Salesforce ODBC Driver
Watch this quick walkthrough to see how to configure your Salesforce ODBC data source, or scroll down for the step-by-step written guide.
Create a User data source (User DSN) based on the ZappySys Salesforce Driver driver:
When the Configuration window appears give your data source a name if you haven't done that already, then select "Salesforce" from the list of Popular Connectors. If "Salesforce" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
SalesforceDSNSalesforce
- Configure the authentication in Salesforce.
ZappySys API Driver - SalesforceRead and write Salesforce data effortlessly. Query, sync, and manage objects and records with SOQL for analytics, reporting, and data pipelines — almost no coding required.SalesforceDSN
Then simply select the Make Generic REST API Request (Bulk Write) endpoint (action).
ZappySys API Driver - SalesforceRead and write Salesforce data effortlessly. Query, sync, and manage objects and records with SOQL for analytics, reporting, and data pipelines — almost no coding required.SalesforceDSNSELECT * FROM __DynamicRequest__ WITH ( "Url" = '/something/123', "RequestMethod" = 'POST' )
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Salesforce API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Salesforce servers).
Salesforce SQL query examples
Make generic rest api request
generic_request_bulk_write endpoint belongs to
__DynamicRequest__
Once the ODBC window opens, click Connect Asset and select your SalesforceDSN DSN from the list.
Salesforce Connector actions
Need another use case? Pick the next Salesforce action in Alteryx below.
You now know how to make generic REST API request (bulk write) in Alteryx without writing complex code. Salesforce ODBC Driver handled pagination and authentication automatically.
