You can connect to your Zoho SalesIQ data from C# via the high-performance Zoho SalesIQ ODBC Driver. We'll walk you through the entire setup.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Zoho SalesIQ Connector.
To get data from Zoho SalesIQ using C#, we first need to create an ODBC data source. We will later read this data in C#. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoho SalesIQ" from the list of Popular Connectors. If "Zoho SalesIQ" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ZohoSalesiqDSN
    Zoho SalesIQ
    • Configure the authentication in Zoho SalesIQ.
    Zoho SalesIQ authentication
    1. Go to Zoho API Console
    2. Click Add Client link
    7. Click CREATE.
    ZohoSalesiqDSN
    Zoho SalesIQ
    OAuth [OAuth]
    https://salesiq.zoho.com/api/v2/[$Compnay$]
    Company Screen Name for URL (e.g. mycompany)
    ClientId
    ClientSecret
    Permissions SalesIQ.operators.READ SalesIQ.conversations.READ SalesIQ.feedbacks.READ SalesIQ.departments.READ
    Find full details in the Zoho SalesIQ Connector authentication reference.
    ZappySys API Driver - Zoho SalesIQ
    Read and write Zoho SalesIQ data effortlessly. Integrate, manage, and automate chats and visits — almost no coding required.
    ZohoSalesiqDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in C# to retrieve data from Zoho SalesIQ. Hit OK button to use this query in the next step.
    SELECT * FROM Departments
    Some parameters configured in this window will be passed to the Zoho SalesIQ API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
  8. Now hit Preview Data button to preview the data using the generated SQL query. If you are satisfied with the result, use this query in C#:
    ZohoSalesiqDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Zoho SalesIQ API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoho SalesIQ servers).
Read data in C#
Using ODBC DSN
  1. Use this code snippet to read the data using ZohoSalesiqDSN data source:
    "ZohoSalesiqDSN" ;
    Make ZappySys Driver call in c#
  2. Press F5 to run the code and read the data:
    ZappySys Driver Output in c#
  3. Here is the code in text format:
    using System;
    using System.Data.Odbc;
    namespace ConsoleApp {
        class Program {
            static void Main() {
                var dsn = "ZohoSalesiqDSN";
                using (var conn = new OdbcConnection(String.Format("DSN={0}", dsn)))
                    conn.Open();
                    var cmd = new OdbcCommand("SELECT * FROM Products", conn);
                    //Increase the timeout duration from the default 30 seconds, which may be insufficient in certain scenarios
                    cmd.CommandTimeout=600; // 600-Seconds
                    var rdr = cmd.ExecuteReader();
                    while (rdr.Read())
                        for (int i = 0; i < rdr.FieldCount; i++)
                                Console.Write("{0}\t", rdr[i]);
                        Console.WriteLine();
                Console.ReadKey();
Using a full ODBC connection string
If you want to avoid being dependent on a DSN and creating multiple DSNs for each platform (x86, x64), then you can use a fully qualified connection string. Simply go to your DSN and copy the Connection String:
    ZohoSalesiqDSN
  3. Then in your C# code, pass the connection string as an argument when calling the OdbcConnection object's constructor, for example:
    var connectionString = @"DRIVER={ZappySys API Driver};ServiceUrl=https://salesiq.zoho.com/api/v2/[$Compnay$];Provider=Custom;OAuthVersion=OAuth2;ScopeSeparator={space};ReturnUrl=[$RedirectUrl$];ExtraAttributesForAuthRequest=access_type=offline&prompt=consent;AuthUrl=[$AccountUrl$]/oauth/v2/auth;TokenUrl=[$AccountUrl$]/oauth/v2/token;ClientId=[$ClientId$];ClientSecret=[$ClientSecret$];Scope=[$Permissions$];ExpiresInAttribute=expires_in_sec;";
    using (var conn = new OdbcConnection(connectionString))
        // your code goes here
  6. Our troubles are over! Now you should be able to use this connection string in C# with no problems.
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Zoho SalesIQ operations directly in C#, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide Zoho SalesIQ data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
To achieve this, you must first create a data source in the Data Gateway (server-side) and then create an ODBC data source in C# (client-side) to connect to it.
Create Zoho SalesIQ data source in the gateway
In this section we will create a data source for Zoho SalesIQ in the Data Gateway. Let's follow these steps to accomplish that:
    ZohoSalesiqDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Zoho SalesIQ ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ZohoSalesiqDSN
      ZohoSalesiqDSN
      ZohoSalesiqDSN
In this part we will create an ODBC data source to connect to the ZappySys Data Gateway from C#. To achieve that, let's perform these steps:
  5. Then set the default database property to ZohoSalesiqDSN (the one we used in the Data Gateway):
    ZohoSalesiqDSN
    ZohoSalesiqDSN
Access data in C# via the gateway
Finally, we are ready to read data from Zoho SalesIQ in C# via the Data Gateway. Follow these final steps:
  1. Go back to C#.
  2. Use this code snippet to read the data using ZappySysGatewayDSN data source:
    "ZappySysGatewayDSN" ;
  3. Read the data the same way we discussed at the beginning of this article.
  4. That's it!
Now you can connect to Zoho SalesIQ data in C# via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Zoho SalesIQ using C# and integrate your data — all without writing complex code.
