This connector is deprecated.
Amazon's MWS (Marketplace Web Service) has been retired and replaced by the Amazon Selling Partner API (SP-API). For a secure, fully supported integration, we strongly recommend using AWS Selling Partner (SP-API) Connector instead.
You can connect to your Amazon MWS data from Power BI via the high-performance Amazon MWS ODBC Driver. We'll walk you through the entire setup.
  • Configuring a secure connection to Amazon MWS
  • Working with Amazon MWS data directly inside Power BI
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Amazon MWS Connector.
Create data source using Amazon MWS ODBC Driver
To get data from Amazon MWS using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Amazon MWS" from the list of Popular Connectors. If "Amazon MWS" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    AmazonMwsDSN
    Amazon MWS
    • Configure the authentication in Amazon MWS.
    Amazon MWS authentication
    Please refer to external API reference
    AmazonMwsDSN
    Amazon MWS
    OAuth [OAuth]
    https://mws.amazonservices.com
    AWSAccessKeyId Fill-in the parameter...
    Secret Key Fill-in the parameter...
    SellerId Fill-in the parameter...
    Find full details in the Amazon MWS Connector authentication reference.
    ZappySys API Driver - Amazon MWS
    Read and write Amazon MWS data effortlessly. Integrate, manage, and automate listings, orders, payments, and reports — almost no coding required.
    AmazonMwsDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Amazon MWS. Hit OK button to use this query in the next step.
    SELECT * FROM Orders
    Some parameters configured in this window will be passed to the Amazon MWS API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    AmazonMwsDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Amazon MWS API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Amazon MWS servers).
Connect to Amazon MWS data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose AmazonMwsDSN and continue:
    AmazonMwsDSN
    AmazonMwsDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Amazon MWS in a Power BI report:
If you wish to import Amazon MWS data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
AmazonMwsDSN
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Amazon MWS ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=AmazonMwsDSN"}
    dsn=AmazonMwsDSN
    dsn=AmazonMwsDSN
    = Odbc.Query("dsn=AmazonMwsDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Amazon MWS data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Amazon MWS Service
    SELECT * FROM OPENQUERY([LS_TO_AMAZON_MWS_IN_GATEWAY], 'SELECT * FROM Orders')
    DirectQuery option for Power BI (read Amazon MWS data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Amazon MWS data is now linked live rather than imported.
    AmazonMwsDSN
    AmazonMwsDSN
    DRIVER={ZappySys API Driver};ServiceUrl=https://mws.amazonservices.com;Provider=AmazonMWS;RetryMode=RetryWhenStatusCodeMatch;RetryStatusCodeList=503;RetryCountMax=6;RetryWaitTimeMs=10000;RetryMultiplyWaitTime=True;
Amazon MWS Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Amazon MWS operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide Amazon MWS data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Amazon MWS data source in the gateway
In this section we will create a data source for Amazon MWS in the Data Gateway. Let's follow these steps to accomplish that:
    AmazonMwsDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Amazon MWS ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      AmazonMwsDSN
      AmazonMwsDSN
      AmazonMwsDSN
  5. Then set the default database property to AmazonMwsDSN (the one we used in the Data Gateway):
    AmazonMwsDSN
    AmazonMwsDSN
Finally, we are ready to read data from Amazon MWS in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Amazon MWS data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Amazon MWS in Power BI and integrate your data — all without writing complex code.
