SSIS Azure Blob Destination Connector for CSV File can be used to write data in CSV file format to Azure Blob Storage. You can automatically split large files by row count or size at runtime. It also supports writing files directly in compressed format such as GZip (*.gz).
In this tutorial you will learn how to write data into Azure Blob Storage CSV file using Azure Blob CSV File Destination. You can use ZS DummyData Source for practice it(In this case its from SQL Server).
  5. Here, In Visual Studio, drag and drop the OLE DB Source and ZS Azure Blob CSV File Destination in the design surface and join the components with the blue arrow..
    SSIS Azure Blob CSV File Destination - Drag and Drop
  6. Now, we need OLE DB Connection and Azure Blob Storage connection. Click here to Create Azure Blob Storage Connection.
    SSIS OLEDB - Connection
  4. Double click on OLE DB Source for configure it.
How to Extract Data from SQL Server Table to Azure Blob CSV File Destination.
  1. Firstly, Double click on OLE DB Source to configure it.
  2. Click OK to Save OLEDB Source Editor UI Settings.
  3. Now, double click on Azure Blob CSV File Destination to configure it, in the Connection Managers, select the connection created before.
    SSIS Azure Blob CSV File Destination - Select Connection Manager
  4. In the Component Properties, set the Append property to False, enter the File Path and set the Overwrite file if exists to True.
  5. In the Input Columns Tab, check the columns that you want as load data.
    SSIS Azure Blob CSV File Destination - Input Columns
  6. Click on OK button to save configure setting UI.
  7. Finally, run the package and the data will be exported from source to destination immediately.
    Loading data from SQL Server to Azure Blob file
AccessMode File path access mode (e.g. direct or variable)
Direct [0] Direct
Variable [1] Variable
FilePathVariable Variable name which holds file path where you want to write data
CompressionType Compression format for source file (e.g. gzip, zip). If you compress files then add correct extension to file path manually (e.g. *.gz or *.zip).
None [0] None
GZip [1] GZip
Zip [2] Zip
TarGZip [3] TarGZip
FilePath File path where you want to write data. You can also use variable placeholders anywhere in the path. Example: myroot/folder/{{User::FileName}}  --OR--  myroot/folder/file_{{System::StartTime,yyyyMMdd}}.dat
Append Append data to file
RowDelimiter Row separator for data files (If this is not specified then New line is used). (NOTE: use \t for tab, \r\n for new line (This is default), \r for carriage return, \n for new line). You can type any string here including special values such as {SPACE}, {NEWLINE}, {TAB}, {CR}, {LF}, {CRLF}. To use Hex code for seperator you may use \xNN (for ascii) or \xNNNN (for unicode charcter). For example \x221E will use infinity symbol as column seperator.
OverwriteFileIfExists Indicates whether you want to overwrite target file if exists. This setting is ignored if Append=true
ColumnDelimiter Field separator for data files. (NOTE: use \t for tab, \r\n for new line (This is default), \r for carriage return, \n for new line). You can type any string here including special values such as {SPACE}, {NEWLINE}, {TAB}, {CR}, {LF}, {CRLF}. To use Hex code for seperator you may use \xNN (for ascii) or \xNNNN (for unicode charcter). For example \x221E will use infinity symbol as column seperator.
FirstRowHasColumnNames Indicates whether first row has column names (Default is true)
QuotesAroundValue Wrap quotes around value in data files
QuoteChar Character for quote indicator around value
DateTimeFormat Date time format string for any column with DT_DBDATETIME, DT_DBDATETIME2 or DB_DATE format
EnableFileSplit Enable splitting large file into multiple files (see FileSplitMode to configure splitting mode).
FileSplitMode Specifies file splitting method (i.e. split by row count).
ByRowCount [0] ByRowCount
BySize [1] BySize
MaxRowsPerFile Specifies maximum rows per file when FileSplitMethod is set to ByRowCount. When this row count is reached data is written to new file.
MaxSizePerFile Specifies maximum size per file when FileSplitMethod is set to BySize. Enter size in following size format specifier allowed bytes, kb, mb, gb, tb (e.g. 100mb)
CharacterSet Character set name (i.e. ISO-8859-1) or code page number. If you set this property then Encoding property will be ignored. To output without BOM set this property to blank and use Encoding instead.
DoNotCreateFileIfNoRows Indicates if empty file should be created or not if no input records found. This option is ignored if you enabled Append option (some destination i.e. S3 may not support append). By default empty file is created if zero input records. Set this to true if you do not want empty file on zero records.
EnableCustomEscapeSequence Enable this option to define custom replacement rules (See also CustomEscapeSequenceRule). Replacement rule should contain key=value pairs separated by semicolon. You can hard code character directly or use designated keyword (e.g. supported keywords are {doublequote} {semicolon} {tab}, {cr}, {lf}, {null}). You can also use Hex chars to search (e.g. \xff44=something). Use blank value in the second part to replace with blank. Example: {null}=\0;"="";{semicolon}=\{semicolon};{cr}=\r;{lf}=\n;{tab}=\t;{columndelimiter}=\{columndelimiter};\xff32=;\xff31=;{null}=;
CustomEscapeSequenceRule Define custom replacement rules to search and replace certain characters. This option is only valid when EnableCustomEscapeSequence=true. Replacement rule should contain key=value pairs separated by semicolon (i.e. ; ). In the key=value pairs, left side you have to define character to be searched and on the right side replacement value. You can hard code character directly or use designated keyword (e.g. supported keywords are {doublequote} {semicolon} {tab}, {cr}, {lf}, {null}). You can also use Hex chars to search (e.g. \xff44=something). Use blank value in the second part to replace with blank. Example: {null}=\0;"="";{semicolon}=\{semicolon};{cr}=\r;{lf}=\n;{tab}=\t;{columndelimiter}=\{columndelimiter};\xff32=;\xff31=;{null}=;
SSIS Azure Blob CSV File Destination - Setting UI
Click here to see all articles for [SSIS Azure Blob CSV Destination] category
SSIS Data Load – SQL Server to Azure Blob (Split Files, GZip)
Introduction In this blog post you will see how easy it is to load large amount of data from SQL Server to Azure Blob Storage using SSIS. We will export / compress data to multiple files. For demo purpose we will use SQL Server as relational source but you can use same steps for any […]
